Author Topic: manifold header  (Read 567 times)
February 13, 2015, 09:29 PM #0
omaid Offline
  • Real Name: Omaid A
  • Vehicle: GC STI chevy tahoe
  • Reputation Power: 37
  • omaid is working their way up.omaid is working their way up.omaid is working their way up.
Hey I am looking to clean my car header manifold shiny is there anyone in Winnipeg nows as well as I want repaint supframe crass member train mount maybe sunblast and paint????????? :alien: :banana:
Last Edit: February 13, 2015, 10:02 PM by omaid
1996 GC STI for sale
1997 GC STI for sale
2009 chevy tahoe for sale
GC GF parts for sale
    manifold header
    « on: February 13, 2015, 09:29 PM »
    February 13, 2015, 11:20 PM #1
    • Reputation Power: 199
    I think you would need a high heat coating on a header like this. try contacting some of our powdercoating vendors and they may be able to help.
    Or if you're cheap, just order heat wrap.
      February 14, 2015, 10:36 AM #2
      Header wrap would be my suggestion for keeping it cheap as well.  You can always try using a polish as well, but will most likely fade away after a few hours.  If you're feeling like a baller, powdercoating would be my 2nd suggestion.      Keep in mind, due to the work involved for a manifold/downpipe you're probably looking at a few hundred$ to get it done properly, if not more.
        February 14, 2015, 12:52 PM #3
        omaid Offline
        thanks much help good header are some costly
          February 15, 2015, 12:52 PM #4
          Ænimal Offline
          • Vehicle: Miater, so many bikes
          • Reputation Power: 76
          • Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.
          powder coating will not work due to temp, as even the high temp powders can't withstand that. You can wrap it or spray with VHT for a cheap fix. If you want to clean it up, there are plenty of guides online on polishing SS exhausts. Same principles apply.
          For everything else, check the sticky at the top of this section regarding vendors for blasting/powder. You can expect a crossmember on a subaru to be ~$100 to powder and blast depending on where you go.
          [Aug 01 15:48:26] dolan:Guys i really dont care, im still young enough to learn from all my mistakes.
            manifold header
            « Reply #4 on: February 15, 2015, 12:52 PM »
