Author Topic: Impacts 1998 Mitsubishi Evolution V  (Read 9336 times)
July 07, 2015, 03:40 PM #50
Impact Offline
  • Real Name: Jhay
  • Vehicle: 1998 Mitsubishi Evo V GSR / 2001 Toyota Vitz RS
  • Reputation Power: 61
  • Impact is a rising star!Impact is a rising star!Impact is a rising star!Impact is a rising star!Impact is a rising star!Impact is a rising star!
Originally posted by E36
that color. How much did Ultimate charge you?
PM'd
1998 Mitsubishi Evolution V GSR - Evo-la
2001 Toyota Vitz RS
Got a Mitsubishi? Come join Mitsubishi Club of Manitoba (MCM) on Facebook or follow on IG Mitsubishi_Club_of_Manitoba
    Impacts 1998 Mitsubishi Evolution V - Evo.la -
    « Reply #50 on: July 07, 2015, 03:40 PM »
    July 08, 2015, 09:55 AM #51
    Impact Offline
    • Real Name: Jhay
    Picked up some gold lugs from Speed Factor the other day
    Went in this morning to finally get the tires/rims swapped over, as I now have the tuner lugs.
    Now need some center caps and get the Enkei sticker back on
    Can't wait, hopefully the coils come in next week!
    2001 Toyota Vitz RS
      July 08, 2015, 10:13 AM #52
      Impact Offline
      • Real Name: Jhay
      2001 Toyota Vitz RS
        July 08, 2015, 10:28 AM #53
        Nice nuts! What brand are they? How many carrots?
          July 08, 2015, 10:37 AM #54
          Impact Offline
          • Real Name: Jhay
          its from Speedfactor and its called drop ENGINEERING lugs
          and as far as karats..i will need to find an appraiser
          2001 Toyota Vitz RS
            July 16, 2015, 09:53 AM #55
            Impact Offline
            • Real Name: Jhay
            Well found out I need to do some replacing suspension wise. Had some front end clunking and got it checked out.
            - Front right ball joint
            - Front right outer tie rod end
            - 2 rear sway bar bushings
            So I purchased these items brand new. If I'm going to replace 1 part, might as well do another
            New front lower control arms
            New ball joints and bushings
            New inner and outer tie rods
            New rear sway bar bushings
            All oem and amazingly under 400 CDN shipped!
            And got a few things wrapped/made at Bomex grahics as well
            - spoiler blade
            - roof
            - hood scoop
            - fog light
            - made enkei decal for rims
            2001 Toyota Vitz RS
              July 17, 2015, 10:56 AM #56
              Impact Offline
              • Real Name: Jhay
              Sweet got my plates today!
              Funny telling people I got Evola in the mail..
              Last Edit: July 29, 2015, 10:34 PM by Impact
              2001 Toyota Vitz RS
                July 17, 2015, 10:59 AM #57
                Originally posted by Impact
                Sick keyboard bro. I use the same one at work too!
                  July 29, 2015, 09:56 PM #58
                  Impact Offline
                  • Real Name: Jhay
                  Got my coils in today...my cat wanted in, in the box asap!
                  Tanabe Sustec Pro's
                  Going to wait for my ball joints, control arms, inner/outer tie rods and sway bar bushings to come in, before getting these installed.
                  2001 Toyota Vitz RS
                    August 07, 2015, 03:38 PM #59
                    Impact Offline
                    • Real Name: Jhay
                    So upon further inspection, this is just a late update. But it seems Tanabe never sent me pillow mounts for the coils. It just came with a cap of some sort. The company/guy that sold me the coils got on it right away and contacted Tanabe.
                    So waiting on Tanabe Japan.
                    But he said that they will be throwing me some goodies for the incomplete set.
                    Also my suspension bits should be in on Mon or Tues. Can't wait for that! Then the pillow mounts. Do it all at once.
                    Also picked up the rear strut tower bar from Chazz on the written off 6.
                    2001 Toyota Vitz RS
                      August 13, 2015, 11:51 PM #60
                      Impact Offline
                      • Real Name: Jhay
                      Did some work on the Evo today. as I had the day off.
                      The center vent piece on the hood is blue. I don't know why, but it is.
                      So I decided to give it a color change. And take several pics of my process, also a pic with no vent.
                      Under the hood, yeah I have to fix the cloth stuff. Prob double sided take to keep it together.
                      The vent from top view(yeah that dimple dent bugs me too guys)
                      Then removed the vent and dropped the hood. Looks pretty sweet, be nicer if I had some engine mods/bling.
                      Vent removed and brought in to get cleaned up.
                      Other side(the side that faces out)
                      Side view to see its very thin and flimsy. And my cat loves smelling new things..
                      Used this color
                      Some scrubbing and washing.
                      I then took the vent outside and sprayed it against the wall. I have no place to do it inside as I have no windows(apartment basement unit).
                      Was a bit windy too and that sucked. And this was the first time I spray painted something since 2003, which was when I received my Silvia K's front end and did the hood in primer.
                      This is what it turned out looking like.
                      You can see some over spray
                      Installed
                      Looks much better, just now need to spray the screen on top of the vent area.
                      2001 Toyota Vitz RS
                        August 14, 2015, 12:36 AM #61
                        August 14, 2015, 12:44 AM #62
                        Impact Offline
                        • Real Name: Jhay
                        Cats pimp bro.
                        Thanks.
                        She's a Scottish Fold
                        2001 Toyota Vitz RS
                          August 18, 2015, 01:59 PM #63
                          Impact Offline
                          • Real Name: Jhay
                          Parts came in today. All oem new parts for the Evo.
                          Now can get the coil's installed at the same time
                          2001 Toyota Vitz RS
                            August 19, 2015, 01:10 PM #64
                            Canadian CD9A Offline
                            • Vehicle: AP1 - CD9A - 5F07F
                            • Reputation Power: 51
                            • Canadian CD9A is on the verge of being accepted.Canadian CD9A is on the verge of being accepted.Canadian CD9A is on the verge of being accepted.Canadian CD9A is on the verge of being accepted.Canadian CD9A is on the verge of being accepted.
                            Are you sure you got the right control arms? That rear bushing is completely wrong and the arm isn't aluminum. I'd return those and put new ball joints in your original arms, personally.
                            Originally posted by: Forced Performance
                            Your significant other can only be mad for a while but your car can be slow forever.
                            The perfect race car is the fastest thing on the track and then explodes after crossing the finish line.
                            AWD Turbo Whiners Club
                              August 19, 2015, 04:34 PM #65
                              Impact Offline
                              • Real Name: Jhay
                              forgot to mention he didn't send me the rear bushings yet he forgot..but ill ask him with what you said for the rest
                              2001 Toyota Vitz RS
                                August 20, 2015, 02:02 AM #66
                                This is what they should look like...if you were told they were Evo 5 arms, you were lied to. They look like base model Lancer arms.
                                  August 20, 2015, 08:15 AM #67
                                  Impact Offline
                                  • Real Name: Jhay
                                  Problems been rectified..his supplier sent us Mirage arms..
                                  So he's sending me the proper arms again at no cost..and he's paying my labor charges as well.
                                  Thanks man..if you didn't mention it. I wouldn't have known..
                                  I'm gonna grab you a gas card just for mentioning that out...thanks!
                                  2001 Toyota Vitz RS
                                    August 20, 2015, 09:07 AM #68
                                    Impact Offline
                                    • Real Name: Jhay
                                    So for now..coils and tie rods are being installed
                                    Then when the proper control arm and ball joint come in..those will be done at the same time with LSD and transmission fluid.
                                    Possibly gonna look for rear arms already and sway bars too..since we will be under again anyways.
                                    Just sucks as it should have been done all at once  :s
                                    Should have pics soon with the drop!
                                    2001 Toyota Vitz RS
                                      August 21, 2015, 01:45 PM #69
                                      Impact Offline
                                      • Real Name: Jhay
                                      Well went ahead with the install. Got @Sharino to continue all my work.
                                      Coils and tie rods got done. Found out it was the tie rods that were giving me the clunking.
                                      So this is the car..not slammed but lowered.
                                      Appointment next week with Nissan for alignment.
                                      And pic from when it was in Japan..
                                      Will have better shots eventually!
                                      2001 Toyota Vitz RS
                                        August 21, 2015, 04:33 PM #70
                                        SavageTaco Offline
                                        • Vehicle: Evo9 GG MR
                                        • SavageTaco has no influence.
                                        Sweet! looking forward to seeing it in person. I prefer the "race car stance" look anyway, its functional.
                                        Evo 9 aka "The Grinch" pump gas warrior
                                        Self tuned on an AEM V2
                                        2000 Aristo V300 - Daily
                                        "When in doubt run flat out"- C Mcrae
                                          August 24, 2015, 12:37 PM #71
                                          Impact Offline
                                          • Real Name: Jhay
                                          Thanks man.
                                          I guess I'm just used to a little lower. My friend with his Evo VI is a little bit lower than mine. So I think I may want to be around his height as well.
                                          Also did you upgrade your BOV? As most people upgrade to the 9MR, wondering if you have your stock around.
                                          2001 Toyota Vitz RS
                                            August 24, 2015, 07:44 PM #72
                                            SavageTaco Offline
                                            Im running a forge BOV. I honestly ditched the stock one 6 years ago when i bought the car....unfortunately i have no idea where it is. I have to clean out my garage before winter, so if i come across it and you're still in need of one ill let you know.
                                              August 25, 2015, 10:47 AM #73
                                              Impact Offline
                                              • Real Name: Jhay
                                              Last night went back to drop another inch on the coils.
                                              Pic of the rear coils
                                              After the gym today, in the light with the side shot to show the drop/gap.
                                              Custom plates, sent my design to Bomex and got them to put it on a plate!
                                              And got them to red out my ambers on my tail
                                              Now off to Nissan for alignment at 1pm!
                                              2001 Toyota Vitz RS
                                                August 25, 2015, 05:52 PM #74
                                                Impact Offline
                                                • Real Name: Jhay
                                                2001 Toyota Vitz RS
                                                  « Reply #74 on: August 25, 2015, 05:52 PM »
