Author Topic: classic impreza springs (jdm/usdm)  (Read 752 times)
June 10, 2015, 01:01 PM #0
awd_ftw Offline
  • awd_ftw has no influence.
Hey guys I need to replace 2 blow struts on my MY98 STi. I may as well try to upgrade my springs. I found a set of UK Impreza Prodrive P1 springs which are rated 215/195 linear(0.5" drop front/rear stays same height) and a set of Prodrive wr15 rated at 230/200(0.5" drop front/rear). My stock V4 are apparently 196/174. Been reading that the Prodrive P1 springs are designed on bumpy and crappy roads.
In my quick search the 215 means 215lbs and the spring will compress 1inch? For a DD car would these springs be an upgrade? The rates are pretty much the same imo. If i stayed with my stock springs I would just buy KYB Excel gs. If I were to get either one of the Prodrive springs I'd get the KYB AGX.
    « on: June 10, 2015, 01:01 PM »
    June 10, 2015, 02:22 PM #1
    • Reputation Power: 109
    If you want a slightly stiffer ride, then yes.
      June 10, 2015, 07:26 PM #2
      awd_ftw Offline
      Do springs need to be replaced like struts? Or they should last the life of the car?
      If its a minimal difference that I cant tell I may as well use the money for something else.
        June 10, 2015, 08:47 PM #3
        From what I've read, and i'm no expert, they should typically last the lifetime of the car unless it was really beaten on (for a normal coil spring - not coilover).
          June 10, 2015, 09:11 PM #4
          Springs can chip/rust/snap at which point you might want to consider replacing, haha. But other than that they don't lose their spingyness, or at least not enough that you would notice.
            « Reply #4 on: June 10, 2015, 09:11 PM »
