Author Topic: NEED HELP: car had a remote starter i didnt know about now car has no power  (Read 1009 times)
June 26, 2015, 05:17 PM #0
bobjacobson Offline
  • Real Name: Rob
  • bobjacobson has no influence.
Ok car is an 06 RSX USDM. I was trying to install daytime running lights. I found what i thought was a good ignition wire and spliced into it.
I then turned the keys to "on" the lights started flashing so i turned it off disconnected the DRLs and now nothing works no power to anything.
I peaked around under the dash and found an aftermarket remote start module and a transmitter bypass all spliced in to the ignition.
I can only assume i somehow screwed this thing up. Model is a "crimestoppers cool start 1304 dp.
Now i need advice.... would my best bet be to take the whole unit out and patch up the wiring?
I try not to mess with electrical for this exact reason.... please help!
    June 26, 2015, 07:27 PM #1
    bobjacobson Offline
    • Real Name: Rob
    Disregard. Ripped the bastard out and its all good
      June 26, 2015, 09:56 PM #2
      fruitloops Offline
      • Reputation Power: 23
      • fruitloops barely matters.fruitloops barely matters.
      Lmao. Not an immobilizer then?
      Bought, not Built.
        June 26, 2015, 10:16 PM #3
        Bmoney Offline
        • Real Name: Bmoney
        • Bmoney has no influence.
        not on that new a Honda.  And they're not labelled.  The flashing lights you saw were likely parklamps indicating an alarm condition - and no power = starter/ignition kill.  I bet you cut a relay or two that were "inline" with ign and starter wires
          June 27, 2015, 12:15 AM #4
          bobjacobson Offline
          • Real Name: Rob
          I had tapped into what i thought was an ignition 12v but was some jumper cable between a transmitter by pass box and the "brain" of the unit.
          I guess it fried the transmitter by pass box so it wouldnt start.
          luckily it wasnt installed very well so she came apart pretty easily. Now its back the way that the good lord Honda intended.
            July 03, 2015, 02:18 PM #5
            Bmoney Offline
            • Real Name: Bmoney
            the bypass box was likely a data module for the remote start.  I would have wanted to see ign, and only used that circuit as sense (not trigger).  You tapping into the same ign lead should have done nothing to fry the bypass.  It also does not "cut" any data wires/etc, so it being dead would not have interfered with the vehicle starting.  It sounds as if you caused a circuit fault - perhaps blown a fuse - and without ign, the car will not start.
