Author Topic: Commanderwiggins' 2012 Supercharged Tacoma  (Read 3900 times)
July 19, 2012, 04:34 PM #25
Sahba Offline
  • Real Name: Sahba
  • Vehicle: Legacy Spec.B, Toyota Supra Turbo, '99 Ninja Cafe
  • Reputation Power: 27
  • Sahba barely matters.Sahba barely matters.
Nice Truck.
Might I make a suggestion?
http://www.pulleyboys.com/store/product.php?productid=64&cat=90&page=1
Some of this will make your truck happy. I know alot of the Camry guys in the past used these guys pulleys as the Stock TRD SC for them only put out like ... 4psi of boost or something. This is like taking the Restrictor plate off the Red Dragon ;)
    « Reply #25 on: July 19, 2012, 04:34 PM »
    July 19, 2012, 06:22 PM #26
    Commanderwiggin Offline
    • Vehicle: BMW M3
    • Commanderwiggin has no influence.
    Originally posted by c2Baz
    Nice Truck.
    The restrictor plate will be coming off sooner or later...I plan on getting a pulley that looks completely OEM ;)  Allen Phillips Racing used to make them but Underdog Racing Development is making a new batch of 2.85" (or 2.825") Pulleys that look completely OEM that should bump the boost up from 6psi to 8psi and my tune/injectors is still well within safety zones.
    900rwhp Turbo E46 M3
    Supercharged Tacoma
      July 19, 2012, 06:29 PM #27
      1.8turbo Offline
      • Real Name: Andy
      • Vehicle: 2002 VW Golf GTI 337, 2008 Toyota Tundra 5.7L
      • 1.8turbo has no influence.
      I thought the numbers would be higher.. but its better then nothing..
        July 19, 2012, 06:53 PM #28
        • Vehicle: BMW M3
        I also was expecting around 260rwhp and 300rwtq but w/e; very poor conditions today to be doing a dyno in such high humidity and heat.  It still has an OEM intake and both sets of cats.  Going to get a cold air intake along with a URD Y-Pipe which eliminates the rear cats (doesn't throw codes).  Gotta okay this through the dealership but shouldn't be a problem.  I'm also going to see about getting Doug Thorley Short Tube (Retains primary cats) headers.
        Supercharged Tacoma
          July 19, 2012, 11:34 PM #29
          BADWAGN Offline
          • Real Name: David Sr. [A.K.A. Big D]
          • Vehicle: AUDI B7 Avant Stage II+
          • Reputation Power: 46
          • BADWAGN might someday be someone...BADWAGN might someday be someone...BADWAGN might someday be someone...BADWAGN might someday be someone...
          I'm sure with better conditions and the air flow change of CAI and cat delete, you will see another bump yet. Looks good either way :-)
          'I Hold The Worlds Record for Holding Worlds Records'
          'It looks like you were talking when you should have been listening'
          'I stuffed it in the lady hole one too many times today'
            « Reply #29 on: July 19, 2012, 11:34 PM »
