Author Topic: how to prevent and remove rust?  (Read 1936 times)
August 11, 2015, 05:12 PM #0
Kc_ Offline
  • Kc_ has no influence.
i got rust starting to form on my left rear fender, but its really really small and not even noticeable unless you look really really close, and small little bubbles too. Do you guys have any tips or advice so that rust wont spread and shops that repair rust in case mine gets worst. Also, i dont know what it is called but its like a spray that prevents rust? like you spray it on your whole car... not sure  :lol: then it won't rust again
    « on: August 11, 2015, 05:12 PM »
    August 11, 2015, 08:05 PM #1
    After it starts rusting you can't do a whole bunch besides cutting it out. There are rust converters but they don't work well for the type of rust on cars.
      August 11, 2015, 08:53 PM #2
      Kc_ Offline
      just a noob question, if i get my car detailed will they fix the rust spots? And approx how much will it cost?
        August 11, 2015, 08:58 PM #3
        Nope, detailing just corrects defects in the paint. If it's just surface rust you could get them to sand/grind it out and then paint it, but there's a good chance it will return.
          August 11, 2015, 11:48 PM #4
          CodyLoewen Offline
          • Real Name: Cody Loewen
          • Reputation Power: 39
          • CodyLoewen is working their way up.CodyLoewen is working their way up.CodyLoewen is working their way up.
          Your best bet is to either replace the panel or have it cut out, welded, and re-painted.  It isn't always cheap to fix rust, but it is possible.
          1999 Honda Civic
          [Feb 22 16:57:22] Shaun:i dont wanna be friends with fence posts
          Faken:if i get this promtion.. i might get a convertible..
          Shaun:a convertible what? pen? yes this pen turns into a coupon holder.
            August 12, 2015, 10:22 AM #5
            Kc_ Offline
            What shop do you recommend that does it? Cause i dont want to do it myself as i dont have enough knowledge
              August 12, 2015, 10:45 AM #6
              Even if you cut it and weld in new metal you might have rust come back if it's daily driven in rain and snow. Depending on the severity of the rust you could be looking at $1000-$1500 a side at a good shop. If the paint is bubbling it often means the rust is coming from the opposite side. If you are going to repair it then I would advise getting some rust proofing done to prevent it from coming back. Unfortunately rust is inevitable.
                August 12, 2015, 02:34 PM #7
                Being a mazda owner, i can tell you rust is impossible to avoid.  Once its starts, it doesnt go away easily.
                  August 12, 2015, 04:34 PM #8
                  Kc_ Offline
                  yea, planning to use it as my winter beater then sell it after i have enough money to import a car. Can you tell me more about this rust proofing? and is it worth it? im guessing it would cost like 2000$ or more lol
                    August 12, 2015, 04:45 PM #9
                    if you are planning on getting rid of the car in a short time then I wouldn't waste your money trying to fix the rust. If you really want to get rid of it just sand it down, use a rust inhibitor like rustcheck or por15 and paint the spot just to cover it up. It's a quick and cheap fix but the rust will be back in 2-3 years. If you do the prep work yourself you can take it to a place like maaco and they will paint both quarters for about $300. The quality is eh but it's better than seeing rust in most cases.
                    Rustproofing is done to cars to prevent rust from occuring but it will most likely happen regardless. For rust proofing to be applied the area will have to be free of rust otherwise it won't work. There are three major rustproofing options; electronic module, tar like spray/undercoating, and an oil based spray. Not sure how well the electronic one works but it's supposed to change the charge of the metal and make it rust resistant.  The tar based one is essentially just a goopy tar they spray to the underside of your car or in wheel wells. It's dirty and messy but it stops water and salt from penetrating it. Oil based sprays get sprayed into different areas of the car (doors, fenders, etc.) and the oil prevents water and salt from getting to exposed metal. Price can range from $100-$1000+ and results may vary.
                      August 12, 2015, 09:14 PM #10
                      Kc_ Offline
                      Thanks for the detailed answer! I might try rust proofing the car that im going to import since they're more prone to rust. Guess i'll just sand it down for now... Or till wait next summer lol
                      +rep
                        August 13, 2015, 08:26 AM #11
                        Another way to avoid rust is to not winter drive it, if you can afford / put up with having a second mode of transportaiton.
                          August 13, 2015, 10:18 AM #12
                          Kc_ Offline
                          Thats the opposite of what im planning to do lol. It's my first car using it as a daily til i save up enough money
                            « Reply #12 on: August 13, 2015, 10:18 AM »
