Author Topic: linex rocker panels  (Read 545 times)
August 17, 2015, 06:04 PM #0
astro Offline
  • astro has no influence.
i got rust starting to set in on my truck an 08 but still really low KM diesel so i wanted to make it last longer
if i had someone spray linex over everything think it would stop the rust? also what shop it good to get the rocker panels sprayed with linex or rhino liner
    linex rocker panels
    « on: August 17, 2015, 06:04 PM »
    August 17, 2015, 10:29 PM #1
    • Reputation Power: 109
    Spraying things over rust does nothing to stop the rust. Eventually you'll have eaten-away rockers clinging together by a film of bedliner.
    A protective anti-chip coating is good at preventing rust before it happens though, when properly installed. It's on most vehicles from the factory, in vary degrees of effectiveness.
      August 18, 2015, 08:18 AM #2
      Your best bet would be to take a wire wheel, and grind most of the rust off, and use some sort of rust inhibiter and then have it line-x'd or whatever coating you're planning to use.
      Covering it up is essentially useless.
        linex rocker panels
        « Reply #2 on: August 18, 2015, 08:18 AM »
