Author Topic: 2014 Mitsubishi Ralliart part out  (Read 1718 times)
August 30, 2015, 06:19 PM #0
Hilux Offline
  • Real Name: Will
  • Vehicle: WRC Rex, GTB wagon, Evo VII
  • Reputation Power: 24
  • Hilux barely matters.Hilux barely matters.
Picked up a 2014 Mitsubishi Ralliart Sedan (14,430 km) for parts to use on my other car.  Seems I didn't need that much, so a lot is for sale! Lots of these parts will fit regular Lancers too as upgrades.
Or perhaps an AWD swap? :D
Let's get to it! All parts have 14,000 km on them unless otherwise stated. No airbags deployed.
Engine bay/ Drivetrain ---------------------
6 speed TC-SST transmission. Shifts perfectly, have video of it driving and shifting 1-6. $3500
AWD transfer case $1400
OEM turboback exhaust, mufflers. $200
Invidia titanium catback exhaust for Evo X (Single tip), also fits Ralliart $400
Rear Differential, and axles. Will be sold together as this can be used for an Evo X AYC differential swap $1500
ACD awd pump. $600
Driveshaft (Center - front to rear) $150
Front axles, LH or RH $150 each
Turbo set -> Intercooler, turbocharger, exhaust manifold, and all piping. Perhaps you'd like make that Lancer GTS a turbo.... :D  $800
Windshield washer tank $50
4B11T Evo X, Ralliart Engine Parts - All engine parts have 22,000 km on them and do not come from this car ----------
Head with valves $800
Block, very light scuffs on cylinder walls. $1100
Crankshaft, ground for 1-step oversize bearings, never used. $500
Wisco pistons, set of 4, $100
OEM rods set of 3 $80
Intake manifold with injectors, throttle body $250
Camshafts with gears $300
Brand new, never opened Manley Turbo H-Beam connecting rods $450
Brand new, unopened ACL Race main / rod bearings -.25 $130 each set.
Suspension / Brakes / Wheels -------------
Springs, all 4 $250
Front RH strut $100
Rear shocks $100 each
Front control arms $ 60 each
Rear control arms, toe arms, multi-link $30 each
Front hubs / knuckles $60 each
Rear hubs / knuckles with parking brakes, and cables $80 each
Brake rotors with matching pads $60 each
Brake calipers $40 each
Full brake upgrade kit for Lancer SE, DE, GTS (all calipers, rotors, pads, hoses) $320
ABS pump $100
Set of 4 rims with tires -SOLD-
Steering rack $150
Subframe, front or rear $60
Body panels / Lights -----------
Doors RH front, or RH rear $300 each
Door LH rear, has damaged corner $100
Front bumper, complete with grille $500
Rear bumper $400
Side skirts / rocker panel guards $100 each
Front RH fender $90 with fender liner $110
Rear RH quarter panel $400
Sunroof conversion parts (roof, sunroof, wiring, interior panel) $400
Frame rails, floor, other structural sections please contact me for pricing.
Bumper rebars front or rear $60
RH headlight, HID projector. Perfect condition $400
LH headlight, HID projector. Lens and part of housing broken. Can be used to retofit into your current headlights $150
LH headlight, NOT HID, standard halogen. $150
Tail lights -SOLD-
Interior / Electrical -------------
Recaro leather / alcantara seat set. Airbags intact, no damage. Front and rear $1600, Front only $1500
Piano black dashboard, door trim $100
Steering wheel (bluetooth, stereo) with airbag.  This wheel feels so nice, and will fit Lancers back to 1996 including Evo 4,5,6 $500
Dashboard and passenger airbag $300
Front seatbelt retractors, no deployment. $80 each
Roof rail, side curtain airbags $100 each
Airbag SRS control unit, undeployed. $150
Complete airbag set - $1100
Rockford-Fosgate touchscreen head unit stereo with bezel $350 Speakers, sub, amp NOT available.
Various interior trims, plastics $10-30
Engine ECU ECM $250
Other interior electrical control units $30-100
Gauge cluster, full colour display $300
Steering column with SmartKey system, and complete wiring harness $400
Aluminum brake and gas pedals $40
Last Edit: August 31, 2015, 03:25 PM by Hilux
    « on: August 30, 2015, 06:19 PM »
    August 31, 2015, 12:10 AM #1
    agzii Offline
    • Real Name: Agzii
    • Vehicle: '04 Chevrolet Venture
    • Reputation Power: 23
    • agzii barely matters.agzii barely matters.
    Hmm I wonder if the wheels will clear big brembo brakes? I think I want it for my winter set up :)
      August 31, 2015, 12:43 AM #2
      Yurek Offline
      • Real Name: Tony
      • Vehicle: '92 Soarer x2, '92 SC300, '97 Civic, '98 Soarer
      • Yurek has no influence.
      1/4 ET 15.7650 @ 95.14 MPH
        September 02, 2015, 11:41 PM #3
        Bayabas4B11 Offline
        • Real Name: Mark
        • Vehicle: Lancer Gt 09
        • Bayabas4B11 has no influence.
        ooohh, the seats...
          September 03, 2015, 10:07 AM #4
          Ralliart Guy Offline
          • Real Name: Jack
          • Vehicle: 2009 Mitsubishi Ralliart
          • Reputation Power: 14
          • Ralliart Guy has no influence.
          PM sent!
          Too much to list. Check out my build thread
          http://www.clubralliart.com/showthread.php?t=1066
            September 14, 2015, 08:48 PM #5
            Hilux Offline
            • Real Name: Will
            Few more pics
              September 15, 2015, 07:49 PM #6
              fruitloops Offline
              • fruitloops barely matters.fruitloops barely matters.
              Bought, not Built.
                September 30, 2015, 03:25 AM #7
                EVOXGSR Offline
                • Real Name: Braeden
                • Vehicle: 2012 Evo Gsr
                • EVOXGSR has no influence.
                Still have stock sub housing ?
                Not sponsored  By Mom & Dad,
                 2nd Place Is always the 1st Losser,
                  October 01, 2015, 08:38 AM #8
                  Hilux Offline
                  • Real Name: Will
                  No sub at all.
                  I do have the stock amp, Rockford head unit and trim, and speakers though.
                    June 13, 2016, 11:37 PM #9
                    ayrton.cs89 Offline
                    • Real Name: Ayrton soares
                    • Vehicle: Mitshubishi lancer ralliart
                    • ayrton.cs89 has no influence.
                    Hi still have head unit? Wonder if it will fit my 2010 lancer.
                      June 14, 2016, 01:10 AM #10
                      Impact Offline
                      • Real Name: Jhay
                      • Vehicle: 1998 Mitsubishi Evo V GSR / 2001 Toyota Vitz RS
                      • Reputation Power: 61
                      • Impact is a rising star!Impact is a rising star!Impact is a rising star!Impact is a rising star!Impact is a rising star!Impact is a rising star!
                      yah whats still avail?
                      1998 Mitsubishi Evolution V GSR - Evo-la
                      2001 Toyota Vitz RS
                      Got a Mitsubishi? Come join Mitsubishi Club of Manitoba (MCM) on Facebook or follow on IG Mitsubishi_Club_of_Manitoba
                        July 04, 2016, 12:00 PM #11
                        Hilux Offline
                        • Real Name: Will
                        **Update**
                        I have a second, nearly identical Ralliart that I am now parting out, same colour 2013 instead of 2014. PM me for what you need, almost all parts are still available only the following are sold:
                        Transmission (without transfer case)
                        Hood
                        Front bumper
                        Rear bumper
                        Windshield
                        Inner door trim panels, RH side only
                        Pictures in this thread are still of the 2014 model, but are representative of the 2013
                          « Reply #11 on: July 04, 2016, 12:00 PM »
