Author Topic: Get a dashcam  (Read 4958 times)
November 20, 2015, 12:06 PM #25
Stone Offline
  • Real Name: Dean
  • Vehicle: 2004 Subaru WRX
  • Stone has no influence.
Saw 2 accidents yesterday, 1 was one car behind me. I think I'm going to invest in one.
    Get a dashcam
    « Reply #25 on: November 20, 2015, 12:06 PM »
    April 07, 2016, 03:03 AM #26
    jon08 Offline
    • Real Name: Jon
    • Vehicle: 5th Gen WRX
    • Reputation Power: 29
    • jon08 barely matters.jon08 barely matters.
    Originally posted by carterjalil
    Just ordered one of these
    http://www.amazon.com/AUTO-VOX-Capacitance-G-Sensor-Stealth-Dashboard/dp/B00UUQD9L6/ref=cm_cr_pr_product_sims?ie=UTF8
    I'll write a review on "weather performance" as soon as I get it
    Hey! Thinking of getting the same (or latest if there's any) model, how's the performance so far (night and cold)? Please send me a link if you already wrote a review. Thanks!
    Last Edit: April 07, 2016, 03:07 AM by jon08
    Check this page and see if your vehicle is in one of the photos! - www.flickr.com/jonaduna
      September 02, 2016, 08:41 AM #27
      carterjalil Offline
      • Real Name: Max
      • Vehicle: 2010 Maxima SV - Sport
      • carterjalil barely matters.carterjalil barely matters.
      Hey all, the cam performs very well .
      This model is with a capacitor and not an internal battery, so you have to leave it plugged all the time or hardwire it somewhere.
      The reason i went with the capacitor is because the model with a battery is known to fail when temperatures dip below 15 degrees..and we live in Winnipeg.
      So far this one hasn't failed at minus 30 or +30 this summer and night vision is awesome. I'll probably get another one for the rear windshield.
      Last Edit: September 02, 2016, 08:49 AM by carterjalil
        April 10, 2017, 02:35 PM #28
        Bumping this. After getting rear ended a third time (2 of which were hit and runs and I was stuck paying the deductible) I think it's time to pick up a dash cam. Looking for some recommendations on 2 channel cams for the front and back. Quality and parking mode are on the top of my requirement list. Did a bit of research already but want to see if anyone has had any experience with any of these.
        Blackvue DR650S - 2CH
        • ~$450
        • Wi-Fi and GPS
        • Front Camera: 1080p @ 30fps w/ 129 degree view
        • Rear Camera: 720p @ 30fps w/ 129 degrees view
        • Bit rate: 10 mbps
        • Parking mode built in
        • 128gb Max memory
        Thinkware F770
        • ~$520
        • Wi-Fi and GPS
        • Front Camera: 1080p @ 30fpss w/ 140 degree view
        • Rear Camera: 1080p @ 30fps w/ 140 degree view
        • Bit rate: 9 mbps
        • 64GB max memory
        BlackSys CH-100B
        • ~$430 with external GPS ($400 without GPS)
        • Wi-Fi and optional GPS
        • Front Camera: 1080p @ 30fps w/ 135 degree view
        • Rear Camera: 720p @ 30fps w/ 130 degree view
        • Bit rate: 6 mbps
        • 128gb max memory
        I'm kind of thinking to go with the Blackvue because I like the sleeker look of it but i'm not sure if the 720p rear camera is a bottleneck or not.
        Thoughts?
          April 10, 2017, 03:30 PM #29
          if you need to zoom in to get a plate, the 720 will be a little worse off than the 1080. That's about the only time I can see 720 not being good enough. it will be plenty good to show what happens in case you get rear ended and someone tries to say you backed into them.
            April 10, 2017, 04:01 PM #30
            • ~$450
            • Wi-Fi and GPS
            • Bit rate: 10 mbps
            • 128gb Max memory
            Thinkware F770
            • ~$520
            • Wi-Fi and GPS
            • Bit rate: 9 mbps
            • 64GB max memory
            BlackSys CH-100B
            • Bit rate: 6 mbps
            • 128gb max memory
            Thoughts?
            I have access to all of these, pm me for pricing if you like
              April 10, 2017, 07:42 PM #31
              Thoughts?
              Do each of those choices have some sort of motion or bump detector while your parked? If not then the rear dash camera wouldn't help in your particular situation.
                April 10, 2017, 07:48 PM #32
                They all have an internal g shock sensor yes.
                  April 10, 2017, 09:22 PM #33
                  Imprzme Offline
                  • Vehicle: '16 Legacy 3.6R
                  • Reputation Power: 20
                  • Imprzme barely matters.Imprzme barely matters.
                  I run my Blackvue (front only, mind you) in 720p - zero issues with viewing anything
                  sample:
                  Save your breath - you'll need it to inflate your girlfriend
                    April 10, 2017, 09:59 PM #34
                    I think im sold on the blackvue. Lmao clearly that person could not tell they had a flat
                      April 10, 2017, 11:10 PM #35
                      • ~$450
                      • Wi-Fi and GPS
                      • Bit rate: 10 mbps
                      • 128gb Max memory
                      Hey Igor, I have the DR650S - 1Ch. I got mine from Blackmycar.ca. @Ctown8 can hook you up though... I forgot at the time of purchase. Its a solid unit. High quality, low profile, customizable and a great price for the specs. Good night quality too, either low beams or full on light bar. It will not disappoint.
                      Mine had an issue, It wouldnt keep time. Every boot it would have to reboot once it connected to GPS. I mentioned it to Blackbox, they are doing a full RMA and waiving the Dead On Arrival - 7 Day period and I just sent it back to them. Great customer service, if you end up going through them. It appears that my camera is a fluke though, so dont be wary of them. Boot up time is generally about 20-35 seconds depending on temperature. 9 times out of 10 its recording by the time you hit the road.
                      The wifi works really well. The app itself has a good and intuitive layout. You can do Over-The-Air Firmware upgrades and video downloads. You never have to pull out the SD card. The PC/Mac Blackvue Viewer app is junk IMO however.
                      Parking mode will only work if you add in the Power Magic thingy. That will pull power as needed to provide the Dashcam with the parking capability. It has voltage cutoff and what not as to not drain the battery.
                      Opposed to direct wiring, you can do a Cellink B. Long lasting battery option. It can do a Single Channel up to 23 hours and a Dual Channel for 15 Hours or so. Blackboxmycar has good kit options and info. Colin can probably hook you up with the camera at a great price and then you could get a Cellink off the site.
                      To add on, Parking Modes only work on Li-Ion Batteried devices. Anything with a Super Capacitor will not be able to Park Mode without additional Power. However, Super Capacitors wont blow up while baking at 60degrees, will boot faster, and will have a longer life span than a Li-Ion.
                      Last Edit: April 10, 2017, 11:17 PM by Colby
                        April 11, 2017, 09:52 AM #36
                        Were making an order of dash cams right now so if you guys want to do a group buy I can arrange that.
                          April 11, 2017, 10:27 AM #37
                          Thanks for the feedback Colby. I would definitely go with the Power Magic Pro. I'd say 75% of the reason I want a dash cam is for parking. What size card do you have in yours? Is the 16gb enough or should I purchase something larger? I was planning on picking up a 64gb from Amazon since they have some good deals going on right now.
                            April 11, 2017, 10:37 AM #38
                            I have a 64gb in mine. They have to be a minimum class card... U1 I think? I'd have to check the manual/website but the read/write speeds need to be met otherwise the card will fail to initialize for BlackVue dashcam use.
                            64 allows about about 15 hours of continuous footage IIRC. The 16 is only like 3 hours. I would assume that the dual channel is even less than that. So you would only have like 2 hours of parking recordings. If you park longer than that and someone hit you early enough, it'll be wiped and recorded over. I'd say go 64 or 128. That way you are much less likely to get boned. And you won't be forced to use a lower quality bit rate/resolution because you cheaped on the card
                              April 11, 2017, 10:46 AM #39
                              Ordered the Blackvue through BRA.
                              If someone hit my car wouldn't the camera automatically lock the footage from getting erased as it flags it as an incident?
                              I checked a few pages online and most people are recommending the Lexar 663x cards which are U1 class 10 cards.
                                April 11, 2017, 10:50 AM #40
                                It tags it as event footage. I don't know if it "locks" it however. I haven't looked to see if that's the case.
                                That's the card I have! It will work
                                  April 21, 2017, 11:20 PM #41
                                  Blackboxmycar pulled a real solid and waived their Dead on Arrival 7 day policy and did a RMA. They covered shipping, diagnoses based on my experience, tested and replaced it promptly. Only 2 weeks down time, not bad at all considering they are in Vancouver.... new one seems to be working 100%. I'll have more time with it this upcoming week as I'm gone for the weekend. If BRA can't help you out, I'd recommend them as a backup option
                                    April 22, 2017, 09:47 AM #42
                                    We had one DOA too yesterday, luckily we had one as back up in stock!
                                      April 22, 2017, 11:23 AM #43
                                      Hmmm maybe I should wire mine up soon and see if it's working
                                        April 22, 2017, 12:11 PM #44
                                        It was the pmp that had an issue, the cam worked fine at least.
                                          Get a dashcam
                                          « Reply #44 on: April 22, 2017, 12:11 PM »
