Author Topic: Plastic Toyota Push Pins.  (Read 2770 times)
September 11, 2015, 08:13 AM #0
Does anyone know where I could get these from? Or have/know where to get a tool to remove them?
I got a bunch from the toyota dealer when I ordered the hardware to install my skirts (I thought they were screws, it was hard to tell in the diagram), but i need to remove and re-install becuase the 3M tape isn't holding the greatest.
I went to Canadian tire with no success and got some from piston ring but they turned out to be slightly to small.
They need to fill a 3/8" hole.
When pushed in, the four "arms" so to say, expand, holding the plug and side skirt in place.
    « on: September 11, 2015, 08:13 AM »
    September 11, 2015, 08:48 AM #1
    ZAKU Offline
    • Reputation Power: 28
    • ZAKU barely matters.ZAKU barely matters.
    NAPA on Ellice has a reference book and decent selection of plastic fasteners, if you bring one in they should be able to find a match. Bring a caliper just in case for taking measurements.
    You could also go to the dealer if you want to spend $$$.
    I consider every deleted post a small victory.
      September 11, 2015, 08:51 AM #2
      Time Lord Offline
      • Real Name: John Jackson
      • Vehicle: Audi
      • Time Lord has no influence.
      Cattons has a huge selection of these fasteners.
      427 Berry St
      http://cattons.ca/
        September 11, 2015, 08:51 AM #3
        Thanks, Ill give that a shot.
        I got them from the dealer(The one pictured)  for about a buck a piece, which surprisingly is really close to the price I paid for the ones from piston ring.
        Which are essentially the exact same, just slightly smaller
          September 11, 2015, 09:09 AM #4
          • Reputation Power: 110
          I've seen this stuff at Rondex, and I'm certain other bodyshop supply stores will also carry clips and fasteners.
          Part Source on Pembina had a rack with a good selection, possibly other locations do too.
            September 11, 2015, 09:12 AM #5
            Totally forgot to even check rondex, but now that you mention it I recall seeing something simlar to them there, but I didn't look closely. Ill have to check that out.
            Thanks for the suggestions guys @firelizard @Time Lord @ZAKU
              September 11, 2015, 10:09 AM #6
              dolan Offline
              • Real Name: Dyllan
              • Vehicle: 2000 civic si
              • Reputation Power: 0
              • dolan is looked down upon.
              How many do you need Colin? I could possibly grab you some from my work or even something similar that will work.
              Dyllan Angelkovski (aka) Dyllan Africa
              [Mar 27 22:16:27] Uncle Hugh Myron:i bet PEAVEY MART NOW OPEN has it
                September 11, 2015, 10:25 AM #7
                10, unless I manage to break/mangle some :lol:
                That'd be cool, but if not, no worries. Keep me posted!
                  September 11, 2015, 11:05 AM #8
                  I have a eBay bag of them. I'll check how many left when I get home. Cheapest source.  6$ for 50.
                    September 11, 2015, 11:06 AM #9
                    Dang not bad.
                    I didn't think to check ebay, was hoping to get local so I didn't end up with the wrong size, after waiting for shipping.
                    Thanks!
                      September 11, 2015, 11:47 AM #10
                      JayPe3 Offline
                      • Reputation Power: 67
                      Yours are easy. You should see the ones I can't find for the Tundra.
                      That said, if I see anything on the shelves I'll let you know.
                        September 11, 2015, 11:03 PM #11
                        Aaron.H Offline
                        • Vehicle: 2014 FR-S
                        • Aaron.H has no influence.
                        I'd say eBay or Canadian tire if not lookup oem Toyota parts. On google. Worst case scenario go to the dealer
                          September 12, 2015, 09:29 AM #12
                          You could try a Toyota body shop. They should have a large supply from either cattons or wurth.
                            September 12, 2015, 10:08 PM #13
                            Miguel Offline
                            • Miguel has a powerful will.Miguel has a powerful will.Miguel has a powerful will.Miguel has a powerful will.Miguel has a powerful will.Miguel has a powerful will.Miguel has a powerful will.
                            My dad had ordered two huge bags full of the Honda ones off of ebay for a fraction of the price and you couldn't tell the difference. You could most likely find something similar.
                            #DRIVEN2017 #IMPORTSOMETHING2017
                            [Mar 13 11:28:02] Shaun:ur gonna play 20 questions with me like that oil cap arent u
                              September 15, 2015, 12:48 PM #14
                              Yurek Offline
                              • Real Name: Tony
                              • Vehicle: '92 Soarer x2, '92 SC300, '97 Civic, '98 Soarer
                              • Yurek has no influence.
                              +1
                              eBay for sure if you aren't in a rush for them and can wait for them to arrive.
                              By far the best bang for your buck in terms of quantity.
                              1/4 ET 15.7650 @ 95.14 MPH
                                September 15, 2015, 01:48 PM #15
                                j.onathan Offline
                                • Vehicle: 06 Sierra CCSB, '89 240sx 7mgte swapped
                                • j.onathan is working their way up.j.onathan is working their way up.j.onathan is working their way up.
                                Part source on regent has a decent selection of clips like that
                                  September 15, 2015, 02:26 PM #16
                                  JonnyAE86 Offline
                                  • Real Name: John
                                  • Vehicle: 84 Corolla, 2011 Ford Escape
                                  • Reputation Power: 24
                                  • JonnyAE86 barely matters.JonnyAE86 barely matters.
                                  This is what you want to buy to help remove them...I love these tools
                                  http://www.amazon.com/Popper-Window-Molding-Upholstery-Removal/dp/B00JX47EU8
                                    September 15, 2015, 03:17 PM #17
                                    Does this remove them without mangling them to pieces like my flat heads do? :lol:
                                    I wonder if these are available locally.
                                      September 15, 2015, 03:39 PM #18
                                      Pretty sure princess auto carries something like this.
                                        September 15, 2015, 03:42 PM #19
                                        JonnyAE86 Offline
                                        • Real Name: John
                                        Yea they should. They even come with some Mastercraft screwdriver sets. This is a common tool for autobody/autoglass shops.
                                          September 16, 2015, 03:22 PM #20
                                          j.onathan Offline
                                          Yeah they do, I had one and they work awesome
                                            November 18, 2015, 08:02 PM #21
                                            ALTIMIT Offline
                                            • Real Name: Ryan Orlesky
                                            • Vehicle: Anything Subaru
                                            • ALTIMIT has no influence.
                                            the PA one is too thick, but i've ground mine down to the thickness of a butter knife and works like a beautifully now.
                                            Wholesale Auction Access for Consumers.
                                            Ryan: 204-955-5091
                                              November 19, 2015, 08:28 AM #22
                                              Time Lord Offline
                                              • Vehicle: Audi
                                              The use of these wretched plastic fasteners on lower panels that are removed often for service jobs is ridiculous.
                                              Quite often I'll toss them and use Nutserts and bolts:
                                              http://www.avdel-global.com/en/products/threaded-inserts/thin-sheet-nutsertr.html
                                              They run under a buck each and hand install tools are cheap enough.
                                                « Reply #22 on: November 19, 2015, 08:28 AM »
