Author Topic: Fixing a slow leak in a tire?  (Read 551 times)
October 03, 2015, 12:39 PM #0
JTM Offline
  • Real Name: James
  • Vehicle: Mazda 3
  • JTM has no influence.
I was wondering how a tire shop goes about fixing a slow leak in a tire?
With winter coming up, I'm starting to think about switching rim/tires and I remember last year I had 2 tires that would lose air.
One after about 5 days and another after about 10 days.  I have a compressor in the garage so I would just check and air them up as often as needed.
If I take them to a tire shop can they detect a slow leak or do they just dismount/remount the tire with new valve stems and hope the problem goes away?
Mazda 3, so green it starts decomposing as soon as it's built.
    « on: October 03, 2015, 12:39 PM »
    October 03, 2015, 12:42 PM #1
    • Reputation Power: 109
    Soapy water.
      October 03, 2015, 02:02 PM #2
      Leak could be coming from a number of different areas.
      Could be a puncture, bead leak, bad valve stem or even a damaged wheel.
      But like it was already suggested just inflate them and use soapy water.
        October 03, 2015, 06:52 PM #3
        chesterfaustino Offline
        • Real Name: Chester Dave Faustino
        • Vehicle: 2008 Dodge Caliber SRT 4
        • Reputation Power: 29
        • chesterfaustino barely matters.chesterfaustino barely matters.
        We usually pump up the air pressure and dunk it in soapy water. With the Colder weather most slow leaks (that I've noticed) are usually from the bead. Sometime it's a very corroded wheel or just a bad seal.
        ~ 08 Dodge Caliber SRT 4 (summer daily)
        ~ 93 Toyota Camry le (winter beater)
          « Reply #3 on: October 03, 2015, 06:52 PM »
