Author Topic: Varrstoen Wheels  (Read 2488 times)
October 13, 2015, 11:07 AM #0
Thebrowntornado Offline
  • Real Name: JD
  • Vehicle: 2015 Chrysler 200 2.4l
  • Thebrowntornado has no influence.
Anyone know of a shop that sells varrstoen specifically the ES3 Model 17in Hyper Black?   Or the Es6 17in :P
I also have a few questions about rims...I found an adapter from 73.1 - 65.1 for the CB  but my bolt pattern is 5X110 and the site has two ptions of 5X100 or 5x114.3 ...  if I grab the bigger size will that affect my lugs at all?  also  my offset is 44mm and these are as big as 35, does that matter?
and last thing, the Width is 9-10 but my cars stock width for rims is 8?
Thanks  :banana:
http://shop.varrstoen.com/p/es3-17-hyper-black?pp=24
    Varrstoen Wheels
    « on: October 13, 2015, 11:07 AM »
    October 13, 2015, 11:08 AM #1
    • Real Name: JD
    I would buy a 18/19 in set but I wana just swap my current tires to the new ones and use my old hubs as a winter set.
      October 13, 2015, 11:17 AM #2
      • Reputation Power: 353
      No you cannot use 5x100 or 5x114.3 on 5x110.
      http://www.willtheyfit.com/
        October 13, 2015, 11:17 AM #3
        • Reputation Power: 173
        Well for one, the bolt pattern won't even fit your car.
        Yes offset matters. But it is relative to the wheel width, so because a wheel has the same offset as your current wheels (for example) doesn't mean it will fit same, if the width isn't the same.
        Edit: Shaun beat me to it.
          October 13, 2015, 11:19 AM #4
          • Real Name: JD
          Oh okay are there any adapters I can buy for this or do i need to look at a different set?
            October 13, 2015, 11:26 AM #5
            There are adapters like http://www.ebay.ca/itm/4pc-1-5x110-to-5x114-3-Wheel-Adapters-Spacers-12x1-5-for-Cadillac-Saturn-/151688246052?hash=item235152f324&vxp=mtr but personally I would never use them.
            You are better off searching for wheels that come in your bolt pattern.
              October 13, 2015, 11:28 AM #6
              • Real Name: JD
              Thanks man, are there any negative impacts of using these spacers?
                October 13, 2015, 11:30 AM #7
                Well they push the wheels out another 1" so they might stick outside the fender...and possible quality issues...
                  October 13, 2015, 11:33 AM #8
                  • Real Name: JD
                  Damn, do you know of any similar brands ?
                    October 13, 2015, 11:39 AM #9
                    • Vehicle: '15 Fiesta ST, '00 MX5 S/C
                    • Reputation Power: 120
                    Just buy wheels with the proper bolt pattern.
                    Sent from my C6506 using Tapatalk
                      October 13, 2015, 11:41 AM #10
                      • Real Name: JD
                      I don't know where to look lol
                        October 13, 2015, 11:51 AM #11
                        October 13, 2015, 12:08 PM #12
                        x2 on wheels with the proper bolt pattern.
                        Or if you really can't find anything, find parts to change your bolt pattern, but that'll be pricey, and likely difficult for your application.
                          October 13, 2015, 12:53 PM #13
                          • Real Name: JD
                          Okay :( Ill just go to a local shop then
                            October 13, 2015, 02:55 PM #14
                            Go to Speed Factor on Pembina, they sell Varrstoen's and will get you setup with what will fit your car properly.
                              October 13, 2015, 07:45 PM #15
                              • Reputation Power: 98
                              • firelizard has great potential!firelizard has great potential!firelizard has great potential!firelizard has great potential!firelizard has great potential!firelizard has great potential!firelizard has great potential!firelizard has great potential!firelizard has great potential!
                              Rota probably makes something you like in a 5x110 bolt pattern, and the price point is similar (bit lower, actually) to Varrstoen
                                October 14, 2015, 08:07 AM #16
                                • Real Name: JD
                                Thanks dude Ill check em out today! do you know if they will swap my tires as well?
                                If they do Ill buy them today and post some pictures up!
                                Awesome!  Ill google them too
                                  October 14, 2015, 08:24 AM #17
                                  Yeah I'm pretty sure they have the equipment to mount and balance tires at their shop.
                                    October 14, 2015, 03:14 PM #18
                                    • cluelessk has no influence.
                                    Varrstoen does custom drilling for bolt patterns. Just costs a little more.
                                      October 14, 2015, 05:50 PM #19
                                      • Real Name: JD
                                      Thought I'd give you all an update lol, apparently speed factor thinks they're above talking about competitors.   I walked in with a quote from a new shop right around the corner for cheap rims, they offered me 160 per rim and the guy just said no way they can touch our stuff don't match it.    I think the fact that they are cheap rims to begin with may have gone over their head, there are defiantly high profit margins if the msrvps are listed at 250+ and they "Drop" the price almost 100 bucks.   I work in sales, yall can eat a bag of fermented dicks.  I should mention the same rims they offered me where at 179, not very far off.
                                      Unless you don't own that shop then don't do that.
                                      On the nicer note I found some cool two piece rsgts I might pick up in 18in instead of 17s and just let those new all season 17ins go to waste :'(
                                      Last Edit: October 14, 2015, 05:51 PM by Thebrowntornado
                                        October 14, 2015, 06:00 PM #20
                                        • Real Name: JD
                                        yeh its 25 extra per wheel and they price in USD
                                          October 14, 2015, 06:36 PM #21
                                          Were you comparing the EXACT same rim or two different rims for price?
                                            October 14, 2015, 06:51 PM #22
                                            • Real Name: JD
                                            I had the same rim and a second one I asked to see if they had, fast is **** any ways though.
                                              October 14, 2015, 07:37 PM #23
                                              October 14, 2015, 07:50 PM #24
                                              • Real Name: JD
                                              What
                                              Yes
                                                Varrstoen Wheels
                                                « Reply #24 on: October 14, 2015, 07:50 PM »
