Author Topic: 2012 Si winter lowering advice!!!???  (Read 1115 times)
October 22, 2015, 01:56 PM #0
m350z Offline
  • Real Name: Matej
  • Vehicle: Nissan 350Z, Civic Si
  • m350z has no influence.
Hey toptier,
So i just bought a 2012 si for a winter car after realizing my 350z in our glorious winter wonderland is a deathtrap.
So with the si im just looking to shorten that wheel gap a bit NOTHING DRASTIC...
Because ill be using it as a daily come winter.
I heard tein s-techs are the most mild drop, but is this advised for the stock shocks for our roads which are comparable to a post apocalyptic WW3 movie?
    « on: October 22, 2015, 01:56 PM »
    October 22, 2015, 02:01 PM #1
    • Reputation Power: 366
    Why would you want to lower a winter car?
      October 22, 2015, 02:31 PM #2
      • Reputation Power: 236
      lowering a winter car probably isn't the best idea and will save you headaches in the long run. if you still want to go through with it than yeah s.techs will be fine. You stock struts will be able to handle them but will wear them out a lot quicker than if you were on oem suspension.
        October 22, 2015, 03:04 PM #3
        • cluelessk has no influence.
        It's not like the civic sits that high anyway.
          October 22, 2015, 03:12 PM #4
          • Reputation Power: 190
          One time I ran over a nice ice chunk, you guys what I am talking about. Made a nice dent in the bottom on my car, lucky not my exhaust. I had a lowered beater, would never do that again. Not to mention getting stuck in snow, but I always got a nice under carriage cleaning because the body of the car would be dragging.
            October 22, 2015, 03:39 PM #5
            m350z Offline
            • Real Name: Matej
            All good points. Maybe ill stay off the springs for the civic, or just do a lip kit to give it that lower look.
            If tein comes out with an h-tech... that would be ideal.
            Thanks all!
              October 22, 2015, 05:39 PM #6
              • Reputation Power: 106
              Yes, S.Tech spring rates should be okay with stock style struts and shocks, but something performance oriented would serve you better. A mildly dropped car is fine in winter, everybody else is being big pussies. Arch gap looks awful, even a mild drop improves a stock car very much.
                October 23, 2015, 12:14 AM #7
                Christian Offline
                • Real Name: Christian
                • Vehicle: 13 Civic
                • Reputation Power: 46
                • Christian might someday be someone...Christian might someday be someone...Christian might someday be someone...Christian might someday be someone...
                you could probably find HFP suspension for cheap? its a 1 inch drop very mild thats what i did
                  October 23, 2015, 12:20 AM #8
                  SpeedPls Offline
                  • Real Name: Greg
                  • Vehicle: BCNR33 V-Spec
                  • Reputation Power: 69
                  • SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!
                  Was just going to suggest this
                  My Flickr
                  1995 Skyline GTR V-Spec
                  1991 Skyline GTR - sold
                  1995 Skyline GTR - sold
                    October 23, 2015, 01:05 AM #9
                    m350z Offline
                    • Real Name: Matej
                    Massive wheel arch is the main reason for wanting to do a mild lower. Secondly, not a fan of the body roll on the 2012 si.
                    HFP looks pretty pricy tho... from what i see 700-800
                    Plus instal alignment and all that im looking at over a grand.
                    Stechs are only like $250
                      October 23, 2015, 01:14 AM #10
                      m350z Offline
                      • Real Name: Matej
                      [/quote
                      Where did u find them and total $$$?
                        October 23, 2015, 01:17 AM #11
                        Christian Offline
                        • Vehicle: 13 Civic
                        really? i paid 1/3 of that price but i also found it locally
                          October 23, 2015, 08:22 AM #12
                          seanf Offline
                          • Real Name: Sean
                          • seanf has no influence.
                          THIS ^^^^^
                          I've driven lowered cars in winter lots, its not nearly as bad as people say, and 1 or 1.5 inches isnt going to make a difference in the grand scheme of things, you don't drive a truck so don't drive the car like one and you'll be fine
                            October 24, 2015, 09:28 AM #13
                            • Vehicle: '93 Land Cruiser HDJ81/'99 MB E55t AMG
                            • Reputation Power: 41
                            H&R OEM Sport springs are a very slight drop and a bit firmer ride, spec out to roughly ITR spec if such a thing existed for your gen car.  I've also driven a lowered car in the winter (Acura 1.6EL), and it's doable for the most part, but it's not ideal for winter.  I'd recommend against a lip kit for a winter beater, that's the opposite of what would make it functionally better IMO.
                            If this car is seriously a winter beater for you, then I'd leave it on stock springs, and get some winter tires in one sidewall profile TALLER than stock which will actually RAISE the car slightly, and give you taller gearing, and it would actually be really good to get around in the winter.  It's not going to look like a summer car that you're driving year round, but that's not what it is either.
                            '99 MB E55t AMG - DD
                              « Reply #13 on: October 24, 2015, 09:28 AM »
