Author Topic: 2013 FRS and BRZ part out  (Read 3176 times)
November 03, 2015, 09:44 PM #0
Hilux Offline
  • Real Name: Will
  • Vehicle: WRC Rex, GTB wagon, Evo VII
  • Reputation Power: 24
  • Hilux barely matters.Hilux barely matters.
Putting these two into one thread. 2013 Subaru BRZ (Sport-tech) 26,700 km, and  parts, and parts from a 2013 Scion FR-S, 25,005 km.
If parts are not either listed below, or pictured, they are sold.
Engine/Drivetrain:
-Two transmissions 6mt $700 each.
-Rear differential $350
-Axles LH and RH $100 each
-Driveshaft $80
-Two OEM headers with catalytic converters $150 each
-OEM complete catback exhaust $180
Interior:
-Proximity (smart key) key and push button start system, complete with ECU, door handles, ignition, all sensors and all wiring  $250
-Base FR-S seats, not heated. Will fit many cars, has flat rails. $400 pair. Very clean.
-Steering wheels $100 each
-Steering wheel airbag FRS $400
-Door cards/interior panels $20-60 each
-Manual climate control panel $30
-Manual Climate control HVAC unit $120
Electrical:
-Body ECU, miscellaneous sensors, control units $20-60
-Complete wiring harness $200
-Various wiring connectors, pigtails $10 each.
-Tail lights $50 each side
-Rear bumper fog/reverse lights $50
Suspension / Brakes:
-Brake calipers $40 each
-Brake rotors front or rear with low mileage matching pads $80 per axle
-Control arms, front, rear, upper, lower, toe, etc $40-70 each
-Hubs/knuckles with or without wheel bearings $80 each
-Steering rack with tie rod ends $150
-Brake hoses $20 each
-ABS pump/computer $80
Body/Chassis:
-Rear bumper in white, has double sided tape residue, but can be cleaned. $200
-RH mirror $80
-Rear subframe $100
- 5 Axis genuine body kit $650 (rear spats, side skirts, and front bumper - front bumper has some damage, but is fixable. Other parts ok)
Located in Winnipeg, MB. Will ship anywhere.
Last Edit: January 31, 2017, 11:37 AM by Hilux
    « on: November 03, 2015, 09:44 PM »
    November 04, 2015, 11:14 PM #1
    Juan Offline
    • Real Name: Jon
    • Vehicle: FRS
    • Reputation Power: 26
    • Juan barely matters.Juan barely matters.
    I am interested in the trunk lip. Do you have any info on the wheels? Any other aftermarket parts on it?
    FAHRVERGNÜGEN
      November 05, 2015, 08:45 AM #2
      "Volks LE37 5x100 17x7.5 +48 Offset"
      This is Julian's old car.
      Here's a link to his build thread http://toptierimports.com/index.php?topic=3730.msg96161#msg96161
      (∩ ͡° ͜ʖ ͡°)⊃━☆ ─=≡Σ((( つ◕ل͜◕)つ
        November 05, 2015, 12:02 PM #3
        heiyuu Offline
        • Vehicle: 06 Civic, 05 Frontier, 98 Integra, 93 180sx
        • Reputation Power: 35
        • heiyuu is working their way up.heiyuu is working their way up.heiyuu is working their way up.
        are the rims good?
          November 05, 2015, 05:15 PM #4
          Hilux Offline
          • Real Name: Will
          3 rims are perfect, one has a bent lip. I imagine it could be fixed.
          Thanks for the link, I thought this car must have an interesting history!
          Aftermarket parts are:
          5 AXIS bodykit (lip, skirts, spats) All parts are perfect, except the front lip with fixable damage.
          5 AXIS trunk lip
          Password JDM engine covers
          As stated above, LE37s
          Steering wheel hub (Bell works)
          HSD 6k Monopro coils
            December 31, 2015, 07:27 AM #5
            In your Frs parts, you don't happen to have a blown airbag do you?  Im needing the cage/frame to make a custom insert. If not I'll start looking at wreckers/body shops.
              January 02, 2016, 03:35 PM #6
              Sahba Offline
              • Real Name: Sahba
              • Vehicle: Legacy Spec.B, Toyota Supra Turbo, '99 Ninja Cafe
              • Reputation Power: 27
              • Sahba barely matters.Sahba barely matters.
              Sorry I don't know if I missed it, how much for the the complete car?
                January 02, 2016, 08:20 PM #7
                N1ck Offline
                • Real Name: Nick
                • N1ck has no influence.
                I want those seats!! Just left Winnipeg two days ago though...
                1993 Del Sol Si
                2015 Kia Sportage EX Luxury AWD
                2015 Chrysler 300 Limited
                  January 08, 2016, 01:41 PM #8
                  Rx7rotary Offline
                  • Vehicle: '85 RX-7 GSL-SE, '03 IS300
                  • Rx7rotary has no influence.
                  If you would consider $250 for that rear diff, shoot me a PM.
                  Shiftin gears, eatin cheeseburgers
                    January 16, 2016, 12:05 AM #9
                    Hilux Offline
                    • Real Name: Will
                    Yes, I have a blow bag, you can have it.
                    Complete, as explained (no engine) would be $3500
                    Well, shipping seats to Regina would only cost about $80 :)
                    PMed.
                      January 18, 2016, 08:08 PM #10
                      Shoot me a msg/pm with contact info. Thanks!
                        February 04, 2016, 01:13 PM #11
                        Coach Offline
                        • Vehicle: 1994 Toyota Corolla 20v 4AGE Silvertop
                        • Coach has no influence.
                        Looking for a rear left tail light, do you still have the car ?
                        1995 Nissan GT-R33 - sold
                          February 04, 2016, 08:14 PM #12
                          Hilux Offline
                          • Real Name: Will
                          Yes, still have it and am parting it.
                          I have the tail light, pm me to meet up.
                            February 23, 2016, 09:29 AM #13
                            Alex2NF Offline
                            • Real Name: Alex
                            • Vehicle: 2013 Subaru BRZ - 2004 Toyota 4Runner
                            • Reputation Power: 234
                            • Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!
                            Hey man, do you have the axles?
                            13 Boosted Subaru BRZ
                            04 Toyota 4Runner V6 Sport
                            ∞ Toyota Echo Race Car
                            98 Acura Integra Race Car 2
                            IG: @alexdbrz / Twitter: @ToyotaWinnipeg / Snap: OilMyPencil
                              February 25, 2016, 10:11 PM #14
                              Hilux Offline
                              • Real Name: Will
                              Yes, I still have the axles. Ready to go.
                                February 26, 2016, 10:09 AM #15
                                RIP Axles
                                  March 01, 2016, 05:01 PM #16
                                  Hilux Offline
                                  • Real Name: Will
                                  New listing and pics up!
                                    April 21, 2016, 05:51 PM #17
                                    supraexcited Offline
                                    • Real Name: Sam
                                    • Vehicle: 1994 GT-Four
                                    • supraexcited has no influence.
                                    Hey man I'm looking for a pair of tail lights any left?
                                      April 22, 2016, 08:49 AM #18
                                      kiraamzsy Offline
                                      • Vehicle: 240Z
                                      • kiraamzsy has no influence.
                                      Do the seats have red accents or are they all black?
                                      Could I get pics?
                                        May 02, 2016, 11:20 AM #19
                                        Hilux Offline
                                        • Real Name: Will
                                        Yes, I have tail lights, one has a very short crack in the lens. Doesn't leak or look that obvious.
                                          June 02, 2016, 08:32 AM #20
                                          RWP Offline
                                          • Real Name: Ryan
                                          • Vehicle: 91 240sx (Under reconstruction)
                                          • RWP has no influence.
                                          Interested in the seats PM sent.
                                            June 21, 2016, 09:46 AM #21
                                            Exposed Offline
                                            • Vehicle: 10 Speed
                                            • Exposed has no influence.
                                            would you be willing to part with the shifter assembly?
                                            Last Edit: June 21, 2016, 09:51 AM by Exposed
                                              « Reply #21 on: June 21, 2016, 09:46 AM »
