Author Topic: DIY Dent Repair  (Read 988 times)
January 03, 2016, 01:51 PM #0
Fantiniastic Offline
  • Vehicle: 2015 Galaxy Blue WRX STi Limited
  • Fantiniastic has no influence.
So I'm pretty sure I know the answer to this but hey it's winter so I thought what the hell :)
I have a small dent in my rear quarter panel (sorry no pic atm).  It's not on a crease at all, pretty minor.  I've seen a couple of methods for getting the dents out at home.
One involves using a hairdryer to heat up the area, and then a duster can upside down to blast it with ice cold fluid which pops out the dent.
The other way is using a small suction cup.
I know that the smart answer is don't **** with it and take it to a PDR (which is what I am leaning towards).  For curiosities sake I thought I'd ask if anyone had tried the above methods and what was the result?
    DIY Dent Repair
    « on: January 03, 2016, 01:51 PM »
    January 03, 2016, 02:16 PM #1
    • cluelessk has no influence.
    It all depends on the type of dent.
    If it's a door ding/ stretched a bit the heat and cooling method you mentioned probably won't work.
    In our body shop we often use a small torch to bring up hail dents and door dings. It usually damages the finish though. But in our case it doesn't matter
    If it's a big "oil can" type dent your process might work but will most likely leave some creases or waves.
    Last Edit: January 03, 2016, 02:18 PM by cluelessk
      January 03, 2016, 03:01 PM #2
      dolan Offline
      • Real Name: Dyllan
      • Vehicle: 2000 civic si
      • Reputation Power: 0
      • dolan is looked down upon.
      That heating with the hair dryer and cooling can will only work on plastic bumpers.
      Best thing you can do to fix it yourself is see if you can access the dent from the inside and try to remove the dent paintlessly
      Dyllan Angelkovski (aka) Dyllan Africa
      [Mar 27 22:16:27] Uncle Hugh Myron:i bet PEAVEY MART NOW OPEN has it
        January 03, 2016, 05:13 PM #3
        Not True.
          January 03, 2016, 09:18 PM #4
          • Reputation Power: 236
          It's hard to get the dryer/duster to work properly. I've tried it 3 times with no success. PDR Tech can fix it for really cheap if you want to go that route.
            January 03, 2016, 09:44 PM #5
            You mean rubber bumpers
              January 03, 2016, 09:56 PM #6
              dolan Offline
              • Real Name: Dyllan
              Most bumpers other than truck bumpers (chrome plated ones) are made of polypropylene making them plastic.
                DIY Dent Repair
                « Reply #6 on: January 03, 2016, 09:56 PM »
