Author Topic: SOLD: Colin's 92 Turbo Legacy  (Read 3684 times)
January 11, 2016, 09:51 AM #0
  • Reputation Power: 120
Been doing so much work on this thing, and I take pictures of nearly everything, though I might as well share it. Might be useful to someone.
Anyway, I picked this baby up a little over a year ago from Dave here on the forum, it was in awesome condition aside from a couple minor oil leaks, and a few old hoses.
After driving it for the winter, I only had to replace one of the turbo coolant lines (soft and burst), after that the rad went (old cracked plastic). Other than that, there were no real issues. I did the coffee cup mod that everyone recommends on the legacy forums and installed some hertz speakers, a pioneer head unit w/ BT. And a boost guage.
About a month after installing the boost gauge, one day i noticed the car wasn't hitting full boost (12 - 14 psi) it was only hitting 5psi - really consistently. This frustrates the heck out of me because I still haven't figured out why its doing this. The car seems to just randomly go into limp mode, some times its fine, sometimes its not. Luckily it drives just fine even when its in limp mode, just has less balls.
I decided I would fix the oil leaks this summer... That never happened though.
So this fall when I pulled the car out of its shed (when I messed up the trans on the Celica) I made a oil catch... Literally i took a peice of aluminum and bent it so it would catch the oil dripping from the timing cover so it wouldn't drip onto the headers. Then I messed up the trans on it doing a pull on the highway, shifted a bit too hard..
Current Mod Lists
Revtronix Tune w/ 14 psi Boost
3.5" Turbo Back Exhaust
Coffee Cup Mod
ACT Stage 2 Clutch
Diamond Racing Coil Pack
NGK Plug Wires (it counts)
02 WRX Transmission
Hertz Speakers
Pioneer Head Unit
Royal Wheel
Works Engineering Quick Release
Ice Guard Winter Tires
Plasti Dip Grille and Hood Scoop
Copper Spark Plugs
Cobb Shifter Bushings
And tons of new parts
Last Edit: December 23, 2016, 02:54 PM by Ctown8
    « on: January 11, 2016, 09:51 AM »
    January 11, 2016, 10:29 AM #1
    • Reputation Power: 125
    In 4 Pics
    only 5 psi... have you checked the connections on the boost gauges inline T? Try also pulling the battery for 10 minutes. during that time try to turn the car on to drain any capacitors. after 10, reconnect and go for a rip. see if that helps.
      January 11, 2016, 10:53 AM #2
      So the first thing I had to deal with was the bad coolant line, I didn't bother taking pics of this but i did take pics of the crack in the radiator. I tried to fix it with JB Weld but it just wouldn't hold, so I ended up getting one of ebay for $99.
      Last Edit: January 11, 2016, 11:19 AM by Ctown8
        January 11, 2016, 10:56 AM #3
        The next thing I did was the coffee cup mod, cause who doesn't love whooosh noises! First is the original resonator, then the modded exhaust reducer is my "coffee cup" (a lot of people use coffee cups). Subaru bites! watch out.
        Last Edit: January 11, 2016, 11:16 AM by Ctown8
          January 11, 2016, 11:01 AM #4
          Car felt like it was misfiring, so i replaced the spark plug wires (could see wear on them) and that when i noticed the coil was right messed up, so I sourced a new one. Currently doing the plugs, pics to come of that.
          Last Edit: January 11, 2016, 11:18 AM by Ctown8
            January 11, 2016, 11:39 AM #5
            Got a new horn switch, got tired of the old one falling out. Also installed some bad ass dixie horns for when I'm hooning
              January 11, 2016, 11:41 AM #6
              AAAAND the tear down started.
                January 11, 2016, 11:42 AM #7
                Found this little guy while draining the trans fluid....
                  January 11, 2016, 11:43 AM #8
                  With the trans out, this was my view.
                    January 11, 2016, 11:46 AM #9
                    Since I knew this was going to take a while, I decided to replace all those leaky front seals.
                      January 11, 2016, 11:58 AM #10
                      A whole lot of cleaning and a few seals later.
                      Last Edit: January 11, 2016, 12:02 PM by Ctown8
                        January 11, 2016, 12:03 PM #11
                        So I did both cam seals, the oil pump seal, the O ring behind the oil pump and behind the driver side cam. Was in the neighborhood so I did the Cam Cover gaskets as well.
                          January 11, 2016, 12:06 PM #12
                          Had to pull the turbo to get access to a leaky cover in the back, so I decided to clean that too... and WOW, it was dirty, cleaned up nice though!
                            January 11, 2016, 12:07 PM #13
                            I was very happy to find ZERO shaft play ;) :(
                              January 11, 2016, 12:09 PM #14
                              This is the seal that the turbo was covering. Never got a great after shot, but its clean now.
                              Last Edit: January 11, 2016, 12:11 PM by Ctown8
                                January 11, 2016, 12:16 PM #15
                                Yesterday my dad helped me swap out the transfer gears in the two transmissions we have. The rear diff is the original so we had to make swap the transfer gears to make the ratios the same from the old trans. Current trans is from an 02 WRX which has 1:1.1 ratios, original legacy trans had 1:1 ratio.
                                  January 11, 2016, 12:18 PM #16
                                  Oil pan was leaking something awful as well, so I pulled the engine up a few inches to clear the cross member and pulled the pan off. Not much left of the gasket. Also pulled the flywheel and clutch, sadly the rear seals were fine... I didn't  need to pull the flywheel, but it did make removing the oil pan easier.
                                    January 11, 2016, 12:21 PM #17
                                    managed to break off on of the hoses going into the coolant tank. These are the definition of obsolete. not made or sold anymore. Had to mod it to make it work. ended up using a brass fitting and jb weld.
                                      January 11, 2016, 12:32 PM #18
                                      Front end is now complete and all re assembled.
                                        January 11, 2016, 12:34 PM #19
                                        Ill be finishing up the oil pan tonight, and if time allows it I'll be putting the flywheel and clutch back on. Then this week or weekend the transmission will go back in along with everything else.
                                          January 11, 2016, 12:40 PM #20
                                          Originally posted by Colby
                                          In 4 Pics
                                          Resetting the ECU doesnt really fix the issue, sometimes when I pull the terminals it feels great for a while, then it goes back to limp. But sometimes it will randomly go back to normal. Its very strange, but its not my top priority atm.
                                            January 11, 2016, 02:51 PM #21
                                            What gas are you using?
                                            Also, depending on the vacuum lines and intake cleanliness, you might want to a) clean the maf and b) think about a catch can (if not already - I just looked at the pictures)
                                              January 11, 2016, 03:02 PM #22
                                              Shell premium, and I'm thinking a catch can is a good idea because of how much oil is coming out from the intake, but now that its clean I'm going to monitor it. And the MAF is clean, the weird part is that its intermittent, why not always limp mode or always good. Also no check engine lights.
                                                January 11, 2016, 03:30 PM #23
                                                Drive it till empty then fill like 1/8 with 94 then when empty fill with 94 and see if it changes.
                                                  January 11, 2016, 03:38 PM #24
                                                  3 octane shouldnt make that much difference should it? ive ran 91 in a pinch and i still make good boost(rated for 98 in japan), ill admit ive never had a problem with 94 though. If not boosting that sounds like a fault in the system. a loose clamp, faulty wastegate.... perhaps spring pressure is only 5 psi? by the looks of the system you are completly catless so there is no restriction. Narrows down the problem a bit.. is it stock turbo, ecu, piping, intercooler, wastegate, BOV?
                                                    « Reply #24 on: January 11, 2016, 03:38 PM »
