Author Topic: SOLD: Colin's 92 Turbo Legacy  (Read 3976 times)
January 11, 2016, 03:49 PM #25
3 octane shouldnt make that much difference should it? ive ran 91 in a pinch and i still make good boost(rated for 98 in japan), ill admit ive never had a problem with 94 though. If not boosting that sounds like a fault in the system. a loose clamp, faulty wastegate.... perhaps spring pressure is only 5 psi? by the looks of the system you are completly catless so there is no restriction. Narrows down the problem a bit.. is it stock turbo, ecu, piping, intercooler, wastegate, BOV?
Turbo is stock, ecu has a revtronix tune (according to previous owner), piping is mostly stock, car has no intercooler ???, wastegate pressure is 8psi and its the oem bpv.
    « Reply #25 on: January 11, 2016, 03:49 PM »
    January 11, 2016, 04:15 PM #26
    Its the direct reason why mine went into limp mode. Used 91, limp. Back to 94, no limp.
      January 11, 2016, 04:24 PM #27
      Never knew that it could make that much difference. That is very good to know.
      The new FA20DIT Forester XT's can be ran with 87 or 91 with no negative side effects except loss of power. Im not going to say they are designed for it but they are mapped to allow it. Kinda cool
        January 11, 2016, 04:30 PM #28
        The tune on mine should allow for some lenience but I've run both types 91 and 94 in the past and never felt a difference. Ill have to try again once its back on the road.
          January 11, 2016, 06:35 PM #29
          bobjacobson Offline
          • Real Name: Rob
          • bobjacobson has no influence.
          Octane ratings in Japan are different than in North America. They use RON we use AKI.
          Basically AKI is equal to about 0.95 of the RON number.
          So your 98 RON car should be running approximately 93 AKI. So you are right where you ahould be running 94 AKI from Husky.
          Pretty confusing that an octane rating is not equal.
            January 11, 2016, 06:49 PM #30
            If you want to get real crazy, there are two Petro stations (keewatin and st marys) that offer Ultra 94. The RON of this is 101.5... I may have to try it out
              January 11, 2016, 06:57 PM #31
              delete
                January 12, 2016, 09:08 AM #32
                Put a fresh coat of rocker guard on the oil pan after I cleaned it, got the gasket all prepped and stuck it back on last night. Put the engine back in once it was torqued to spec. Must say our engine pulling assembly was a great idea.
                Last Edit: January 12, 2016, 09:10 AM by Ctown8
                  January 12, 2016, 09:52 AM #33
                  You should do a sweet Hertz audio system in it! I know a guy selling one!
                    January 12, 2016, 09:04 PM #34
                    daveh Offline
                    • Real Name: daveh
                    • Vehicle: Subaru
                    • daveh has no influence.
                    Wow Colin, that's going to be a pretty nice winter beater! Great work cleaning it up.
                    While you have it apart, clean up the grounds, and check that the ecm is grounded properly. Maybe look into that switch and circuit for the valet mode or whatever that is on the Revtronix, that could be what's limiting boost. I'd even check that the chip hasn't come loose. Revtronix isn't around anymore, but there may still be some info on legacycentral.
                      January 12, 2016, 10:48 PM #35
                      I did some chatting around today... Do you have a 2.2L in this?
                        January 13, 2016, 09:09 AM #36
                        I'll have to check that, seems unlikely that the chip would come loose. but the grounds are definitely a possibility.
                        And yes, it's the EJ22T!
                          January 13, 2016, 09:32 AM #37
                          Originally posted by Ctown8
                          I'll have to check that, seems unlikely that the chip would come loose. but the grounds are definitely a possibility. And yes, it's the EJ22T!
                          The EJ22T never had an intercooler. It was originally designed for the Rally world but didnt make it to Colin McRae because of the 2.0 engine size restriction.
                          The cool thing is this in the EJ22T and EJ20 of that era(89-93) is that they are the only engines produced to have piston oil squirters. There is a tech at subaru who has done some minor work and is making 360 HP out of his
                            January 13, 2016, 09:35 AM #38
                            Yep, these things are gems! I love mine!
                              January 25, 2016, 11:09 AM #39
                              Had a small fire in the garage this past week, electrical box where the main power comes into the house was arking somehow and started a fire, then of course the power went out cause the wire snapped. Put the fire out but covered my car with dust in the process... Picture is the new box obviously.
                                January 25, 2016, 11:13 AM #40
                                Got the car all put back together over this last week, parts were pretty difficult to find, but we managed. Turbo is back in, trans is in, new plugs, new seals, a few new gaskets and O rings here and there. Tidied up some wiring so nothings hanging like before (can be seen in picture 1). Wired up to new trans with neutral safety switch and reverse lights are operational.
                                  January 25, 2016, 11:17 AM #41
                                  Filled up all fluids and stated checking for leaks, a couple banjo bolts had to be tightened at bit, but nothing seems to be leaking anymore, except one pesky power steering bolt... But thats   for another day.
                                    January 25, 2016, 11:26 AM #42
                                    Couple annoying parts, the speed sensor is a cable on the 92 models, but on the 02 that the trans came from its a digital part with a plug. So we had to take out the digital part which was made of plastic. Obviously it didn't turn so we basically had to cut it out until it would turn in the hole. It was a huge pain but we got all the plastic bits out of the hold and when finished it looked just like the old trans.
                                      January 25, 2016, 11:38 AM #43
                                      Next issue was what we though was a failed release bearing, actually turned out to be a leaking clutch hose (no pressure). this would not have been a big deal if the old hose has the same size ends... The ends were roughly 1/4" in depth and the new one was roughly 3/8" to make the skinnier hose work, some one had previously cut the banjo bolt shorter on one end (slave cylinder side) so with the new hose the bolt didn't have enough bit for me to feel comfortable (1 full turn).
                                      So my adventure to find a longer banjo bolt began on Friday, it was awful, no one in the city had one, ended up going to see Subaru Gerry off Sturgeon rd. walked through his yard with him for almost an hour in my shoes (not boots). Eventually found one on an old fozzy. Missed my birthday dinner because of it but that okay, Subaru > Steak dinner.
                                        January 25, 2016, 11:47 AM #44
                                        Once we got it all assembled we bled the clutch, this was more difficult than expected but turned out really good, it feels even better than before now. (this was this morning).
                                        Last night we had it bled to the point where it worked but was engaging the pressure plate the second you moved your foot off the floor. We did let the car idle for a while last night just to make sure there were no drips left and luckily there was only one. But it was coming off the flange before the up pipe meets the turbo DDD so we got worried thinking why the heck is the exhaust leaking a liquid and smoking like no ones business? Turns out when I washed the up pipe (was coated with dried burnt oil from before) I soaked it in our parts washer, it just hadn't quite dried yet. After running it for 10 minutes and watching was looked like burning plastic drippings to the floor (except smoking not burning) the drips slowed. I took it to the car wash for a test drive (2 km away) it was smoking pretty bad when I got there, but it had a distinct smell of solvent. Drove it home and called it an night (still smoking a bit). This morning I fired it up and the smoke took a lot longer to start but it did after a while. But much less than yesterday. We finished bleeding the clutch and I drove it to work this morning. When I got to work there was no more smoke and everything looked dry.  :banana: I am very happy and hope this is the last serious repair job I'll have to do for a while. Oh thats right. Celica needs a new trans and seals too...
                                          January 25, 2016, 12:28 PM #45
                                          omaid Offline
                                          • Real Name: Omaid A
                                          • Vehicle: GC STI chevy tahoe
                                          • Reputation Power: 37
                                          • omaid is working their way up.omaid is working their way up.omaid is working their way up.
                                          Nice work any idea twin turbo engine from 1997 or 98 with with fit in 1993 or 1994 4 doors sedan legacy
                                          1996 GC STI for sale
                                          1997 GC STI for sale
                                          2009 chevy tahoe for sale
                                          GC GF parts for sale
                                            January 25, 2016, 12:44 PM #46
                                            I don't see why it wouldn't, as long as you have the right wiring harness, trans and diff. Most of these engines are interchangable.
                                              January 25, 2016, 12:45 PM #47
                                              Big thanks to @daveh for helping source a few parts! Super knowledgeable guy this would have been a lot more work without his help.
                                                January 25, 2016, 01:06 PM #48
                                                Are you throwing into a LHD vehicle?
                                                  January 25, 2016, 02:53 PM #49
                                                  omaid Offline
                                                  Yes
                                                    « Reply #49 on: January 25, 2016, 02:53 PM »
