Author Topic: What size muffler do i need for my B4 RSK?  (Read 598 times)
February 04, 2016, 01:01 PM #0
OkanaganSubie Offline
  • Vehicle: 1999 Subaru B4 RSK Legacy
  • OkanaganSubie has no influence.
Hey so i have a b4 rsk and want to put a magnaflow glasspack on it. Looking at them online, there are different lengths? how do i know which length muffler i need?! i cant go physically measure my stock muffler at the moment but if someone knows how long of a muffler i need, id lo e to know!
    « on: February 04, 2016, 01:01 PM »
    February 04, 2016, 09:04 PM #1
    • Reputation Power: 44
    Sedan or wagon?
      February 05, 2016, 03:36 PM #2
      Calling @CKlass @bshaw @robot
      Does Magnaflow make a OEM swap? If not, get a a nice 3-4" can and get it fabbed up at a muffler shop. Tanabe, HKS, Cobb, Invidia, Nameless, anything can be thrown on there. '99 is Gen 3, I have a Gen 2, I got a custom 3" Cat-back to a Tanabe done up. Search for some sounds you like, purchase, and head to a shop :)
        February 05, 2016, 05:36 PM #3
        5hurlin Offline
        • 5hurlin has no influence.
        The longer the glass pack, the more sound it will reduce, and more restriction will be created. There won't be a specific length that will be best unless you are looking for maximum performance which would be best not to have one at all ie. straight pipe.
        The internal diameter of the core is what matters. unless your going to be upgrading to huge turbos, 3 inch will be more than enough. depending on how much boost you end up running a 2 1/2 should be sufficient as that is most likely slightly larger than the stock diameter.
          February 05, 2016, 10:27 PM #4
          Second gen twin turbo legacy has 2.5" piping stock. I am going to guess the third gen does too. When I bumped it up I felt a bit quicker spool time do to the reduced backpressure. dont go to big or youll be dumping fuel, running lean and it may cause heating/cooling issues
            « Reply #4 on: February 05, 2016, 10:27 PM »
