Author Topic: 06 STI Hesitation + Idle Problems..  (Read 470 times)
February 09, 2016, 12:38 AM #0
valeeraa Offline
  • Real Name: Sani (Sunny)
  • Vehicle: 2006 Aspen White WRX STI
  • valeeraa has no influence.
Alright.. Here's the run down.. Changed the tranny fluid, rear diff fluid and oil change Jan 28. January 31 and Feb 1, i noticed a slight problem while cruising.. It felt a little hesitant after work feeling like the car was pulling you back and releasing every few seconds. Plugged my Accessport in and looked up the A/F ratio, and holy eff.. It was going from 11 - 20 on cruise and during idle.
https://vid.me/UAxI
This video was from Feb 1. And to this day it's still going on. No CEL happening and also changed my MAF sensor and realized that wasn't the problem. Spark plugs was next on the list to change but I can go changing everything and realize that it's still causing the same problems. I was wondering if anyone would have any idea what would be going on? Or if any Subaru owners have any knowledge of what's going on?
Here's a forum on what this guy found on his. But I'm sure it could be anything..
http://forums.nasioc.com/forums/showthread.php?t=1789829
Was going to change both O2 sensors, but wow, that isn't cheap.
    « on: February 09, 2016, 12:38 AM »
    February 09, 2016, 09:43 AM #1
    Did you check to make sure all your vacuum lines are on tight and that you don't have a leak somewhere?
      February 10, 2016, 12:30 AM #2
      awd_ftw Offline
      • awd_ftw has no influence.
      I had an issue like this. I found the rubber hose from my manifold to the FPR dry rot and cracked. Could also be a clogged fuel filter?
        « Reply #2 on: February 10, 2016, 12:30 AM »
