Author Topic: 2013 Sti brakes  (Read 1098 times)
February 27, 2016, 09:06 PM #0
Tonyj204 Offline
  • Real Name: Tony J
  • Vehicle: 2013 STI
  • Tonyj204 has no influence.
Hey just see if anyone can answer some of my questions. I was reading the manual and it says if you can feel some grinding when you brake I should get them checked. But I think I feel it only once in awhile. Should I take it in to the shop? Also if I change pads do I also have to change the calipers?
(Note : as my question shows I'm not very mechanicly incline lol)
    2013 Sti brakes
    « on: February 27, 2016, 09:06 PM »
    February 27, 2016, 10:39 PM #1
    depends on the grinding noise. Worn our pads will screech when constant pressure is applied. Sometimes grinding means there is dirt between the pad and the rotor and would go away eventually. If you think there might be an issue I would suggest taking it to Jim Pattison Subaru and having one of the techs check it out.
    My 2014 STI makes grinding noises in the winter when the rotors are rusted up or after dirt gets in them but goes away after a couple of hard brakes.
    No, calipers do not need to be replaced but it is good practice to replace rotors (or resurface to original ones) at the same time as pads so that you have a clean and even mating surface.
      February 28, 2016, 08:46 AM #2
      Tonyj204 Offline
      • Real Name: Tony J
      • Vehicle: 2013 STI
      Thanks for the info, I gave it a couple heavy applications and it seems to be gone. I'm planning to hose the brakes down this week as well to clean all the crap out.
        February 28, 2016, 11:47 AM #3
        Good idea would be to pull the pads off in the spring and give a quick wipe down and blow some air through the calipers to get rid of all the brake dust. You can check pad life while you're at it.
        Very easy to do with brembos.
          March 02, 2016, 12:39 AM #4
          • Reputation Power: 20
          Pins in the STi Brembo's don't seize?
            March 02, 2016, 07:21 AM #5
            Not if you anti-seize them :)
              March 02, 2016, 01:23 PM #6
              ZAKU Offline
              • Reputation Power: 28
              • ZAKU barely matters.ZAKU barely matters.
              Don't do this, airborne brake dust is a bad idea. Soak it down with brake cleaner instead.
              I consider every deleted post a small victory.
                March 04, 2016, 11:20 AM #7
                Tonyj204 Offline
                • Real Name: Tony J
                • Vehicle: 2013 STI
                Thanks for the tips guys.
                  2013 Sti brakes
                  « Reply #7 on: March 04, 2016, 11:20 AM »
