Author Topic: Carson's '99 stb  (Read 4664 times)
May 14, 2016, 09:44 PM #25
C.J974 Offline
  • Real Name: Carson
  • Vehicle: 1987 Porsche 924S, JDM 1999 Subaru Forester stb
  • C.J974 has no influence.
Originally posted by Ctown8
How do the new speakers sound?
They're great, will be better with a new head unit. The balance is off, the one that came in my car has terrible eq presets.
Sent from my SM-N910W8 using Tapatalk
You can't ruin my life Reality, my safe space will keep you out! -Cartman
    Carson's '99 stb
    « Reply #25 on: May 14, 2016, 09:44 PM »
    May 16, 2016, 10:18 PM #26
    C.J974 Offline
    • Real Name: Carson
    Got my half shaft replaced without incident. Just took a bit of time to un seize the strut bolts.
    This is the old one
    New one in place
    And if they get sticky with my not having reflectors in my signals,
    Should pass safety tomorrow , no problem.
      May 16, 2016, 10:34 PM #27
      thomasmarzec Offline
      • Real Name: Thomas
      • Vehicle: '04 G35 Coupe 6MT
      • thomasmarzec has no influence.
      Nice car man, super clean. How much did you pick her up for?
        May 17, 2016, 06:20 AM #28
        C.J974 Offline
        • Real Name: Carson
        $5700 landed.
          May 17, 2016, 07:54 AM #29
          I'm curious how hard was it to figure out which axel to purchase. It was the right side / driver side correct? But since the car is right hand drive did that mean you had to purchase a USDM left side axel?
            May 17, 2016, 09:36 PM #30
            C.J974 Offline
            • Real Name: Carson
            I walked into part source, asked for a left side cv axle, mentioned it was for a jdm car, they said that didn't matter. (they are the same length jdm left /usdm left) plus the engine/transmission is in the exact same place in usdm and jdm models and neither has to go around anything. plus I figured if it didn't fit I'd return it and find the right one. I think it's the same part that goes on the Gc8 (and bugeye etc?)
            I belive in the case of an sf5 forester, you can get any usdm part, other than the steering rack, and it will work on a jdm one.
            In any case, it worked for me and I got my safety.
              May 17, 2016, 10:09 PM #31
              great job!
                May 18, 2016, 08:04 PM #32
                C.J974 Offline
                • Real Name: Carson
                Got my plates! Will probably get other plates soon.
                  June 05, 2016, 06:33 PM #33
                  C.J974 Offline
                  • Real Name: Carson
                  Found a crazy deal on a set of sti seats. Had to grab them. Easy bolt up, but the jdm back rail covers don't fit, and since they are out of a usdm car the driver seat doesn't have the option to raise or lower. Other than that, they feel a lot better in that the bolstering holds you in much better.
                    June 05, 2016, 08:23 PM #34
                    C.J974 Offline
                    • Real Name: Carson
                    Forgot to mention, these seats have heat packs in them already, just need to wire them up properly to get them to work. I don't know where to start looking into how to do that. Any suggestions?
                      June 05, 2016, 09:21 PM #35
                      Not off the top of my head... but if you find a solution, let me know :). I'll probably want to do something similar.... Good thing is we have lots of spare buttons next to the fog light button.
                      Looks like you can get a heated seat switch (this is from an SG (next generation) Forester):
                      http://www.ebay.com/itm/282021332361?rmvSB=true
                      I think the North American subaru forester S had a heated seat option, so there's might be a better switch you can find somewhere. I think it will fit in the two change trays next to the e-brake. Unsure if there's wiring that goes there already.
                      Edit: Found this:
                      http://www.subaruforester.org/vbulletin/f77/how-heated-seat-repair-install-62332/
                      Last Edit: June 05, 2016, 09:41 PM by dano
                        June 05, 2016, 09:29 PM #36
                        Also, IF you have to do wiring as well, might be good to look into doing a heated mirror mod as well. The Japanese foresters came with power folding mirrors, but not heated. I'm pretty sure I read somewhere that you could wire them into the rear defroster circuit, but you'd need to add the wiring and the heater coil.
                          June 05, 2016, 09:54 PM #37
                          C.J974 Offline
                          • Real Name: Carson
                          Speaking of rear defrosters. Are these side trunk windows supposed to have defrosters? Cuz there is no way these are functioning from how they look, and, will this be breaking the circuit to the hatch window?  Also, are there any stand out amazing wiring diagrams availible for sf5 that you know of?
                          Are defroster lines a diy kind of thing? or do I need to go to a shop?
                            June 06, 2016, 10:58 AM #38
                            I could probably help you with the heated seats, and the lines on your rear windows, those are antennas.
                              June 22, 2016, 08:00 PM #39
                              C.J974 Offline
                              • Real Name: Carson
                              @savageajames took some nice shots of my car the other day. Nothing new done to it, but this is how she sits right now.
                                July 05, 2016, 11:32 AM #40
                                Hey, I have the new FH-X730 in stock and the new DEH-X6800 is on the way!
                                  July 05, 2016, 03:55 PM #41
                                  barrett Offline
                                  • Vehicle: 1999 Subaru Forester S/TB
                                  • barrett has no influence.
                                  It's looking good!
                                  93 Del Sol Si - B18C1, YS1 cable GSR trans, Work Stark II's, Powerslot rotors, Hawk HPS pads, Momo Millenium steering wheel
                                  1999 Subaru Forester S/TB - SRT4 ACR BBS rims, Pioneer P3200BT, stock everything else
                                    July 06, 2016, 10:07 PM #42
                                    I would not be 100% about this. my Legacy has USDM Legacy Front Axles. Last year I went to replace a rear, found out the hard way, the rear axles are from a USDM Impreza. 1" shorter, same spline count, deeper circlip slot. At first it wouldnt go in, had to groove the circlip on the lathe, for the half shaft, than had to face and regroove the circlip on the hub side too. Since the JDM leggy had more power it used stonger parts aka imprezas... just a piece of advice, never try and buy parts on saturday to install sunday stores are closed :( :P
                                      July 06, 2016, 10:27 PM #43
                                      C.J974 Offline
                                      • Real Name: Carson
                                      I probably should have looked in to it more, but they are the right ones in the front, and I had my safety appointment on the Monday so it was my last option (other than making another appointment lol)
                                      And I'll probably come pick up that deck this week if I get off work on time for once.
                                        July 09, 2016, 08:52 AM #44
                                        C.J974 Offline
                                        • Real Name: Carson
                                        Picked up a set of ISC coilovers yesterday, and proceeded to install them.
                                        It was taking me a lot longer than I expected it to, starting at 7:30pm, I got 3 in by 12:00pm. It was taking so long due to a number of reasons,
                                        1, it's 15 year old suspension bolts, so, a lot of corrosion.
                                        2, I had to saw open the bracket holding the brake lines to the strut (carefully). The "proper" way is to disconnect the brake line and pull it through, but that means bleeding the brakes, and I don't feel like doing that.
                                        And 3, I was test fitting the first one for a reference to the rest.
                                        This is what the front will be at, I might need to raise it, but I don't know until I take it for a run after.
                                        Sawing the back bracket is really awkward and thus takes forever, so when I finally got one rear one in, assuming I should adjust it to the same height as the fronts, I didn't feel like doing the other side, and will leave it for morning. I still need to raise the driver side as I am currently tucking the tire at the coils current height.
                                          July 10, 2016, 07:23 AM #45
                                          C.J974 Offline
                                          • Real Name: Carson
                                          Finished putting my coils in yesterday.
                                          I lowered it 2" all around, there is no rubbing. I think I could still lower it another half inch before needing to roll the fenders, but I'll leave it like this for now because I don't feel like messing around with it anymore.
                                          I have my dampening set about half way, 16 clicks from the hardest setting. It is a stiff but still good ride.
                                          After having it together and going for a quick ride I noticed axle grease droplets scattered around my front right wheel well. I must have clipped the boot slightly while installing. I'll just leave it for a while then replace the whole shaft just like the left side.
                                          I also put in my new head unit
                                          This is the old jdm alpine
                                          And this is the new pioneer unit
                                          It amazes me how much a new head unit can improve stereo quality.
                                          Removing the centre console trim to get at the head unit was very easy, no busted clips.
                                          I'll probably still put an amp and sub in later, but I think I'm done spending money on my car for a few months.
                                            July 11, 2016, 08:16 AM #46
                                            barrett Offline
                                            Looks good lowered like that.
                                              July 11, 2016, 07:17 PM #47
                                              C.J974 Offline
                                              • Real Name: Carson
                                              Dropped down another inch, and it still doesn't rub!
                                                July 11, 2016, 09:23 PM #48
                                                At least in the fenders ... Probably close to bottoming out?
                                                  July 11, 2016, 09:31 PM #49
                                                  C.J974 Offline
                                                  • Real Name: Carson
                                                  Still have 6" to spin down in the rear, and about 3.5" in the front.
                                                    Carson's '99 stb
                                                    « Reply #49 on: July 11, 2016, 09:31 PM »
