Author Topic: Carson's '99 stb  (Read 3369 times)
July 11, 2016, 09:40 PM #50
C.J974 Offline
  • Real Name: Carson
  • Vehicle: 1987 Porsche 924S, JDM 1999 Subaru Forester stb
  • C.J974 has no influence.
Or do you mean the lip hitting the street? Because I still have about 5" clearance on the front lip. A little less on the side skirt.
Sent from my SM-N910W8 using Tapatalk
You can't ruin my life Reality, my safe space will keep you out! -Cartman
    Carson's '99 stb
    « Reply #50 on: July 11, 2016, 09:40 PM »
    July 11, 2016, 10:06 PM #51
    • Vehicle: 2013 Nissan Leaf SL
    • Reputation Power: 90
    This. That some part is going to scrape the bottom. I had the h&r lowering springs on mine with the Koni yellows and it was too low for dailying. I cracked my side skirts and on my back lane which has a steep incline it was very close to the front lip. Looks good though :)
    New business opening soon...
      July 12, 2016, 06:31 AM #52
      AA_ron Offline
      • Real Name: Aaron
      • Vehicle: 99 JDM Forester STB Type A 5MT
      • AA_ron barely matters.AA_ron barely matters.
      Yes but our Type A body kit is muuuch chunkier than the other body kits. :D
      @C.J974 Foz is looking good! Keep it up!
        July 12, 2016, 06:37 AM #53
        C.J974 Offline
        • Real Name: Carson
        Seems to be fine, well see what happens when I have 4 passengers in it, but this seems to be a very manageable height. I may not even have to spin the coils up in the winter. If I had the type A lip, it might be a different story, I don't know how much lower it is, but it is lower by a bit.
          October 31, 2016, 10:45 PM #54
          C.J974 Offline
          • Real Name: Carson
          While digging around under my dash figuring out the (surprisingly well done) existing aftermarket sub wiring, I found this mysterious box that doesn't appear to be a factory item. Any ideas as to what it could be? I'm not in the mood for tracing wires.
          And as I mentioned, I put subs into my foz on Saturday.
          The power, ground and rca cables were already in place, I just had to replace a small section of wire from the battery to the fuse, which turned out to be garbage and had to be replaced, (thanks @ctown8 for the help) but the rest of the wiring as I said, was done very well, labeled, stuck down, easy to get at.
          Subs are dual focal 10" 25A4, amp is a single channel clarion, box is a chambered bassworx 13x30x16".
          The amp fits perfectly into the in floor compartment behind the back seat and looks really clean. The box fits snugly under the trunk cover.
           Next I'll need to wire up my heated seats, if anyone has, or knows somewhere I can get switches and wiring or at least connectors please let me know.
          Sent from my SM-G935W8 using Tapatalk
            November 01, 2016, 07:08 AM #55
            @ctown8 should have some for reference. You can get the switches off eBay.
              November 04, 2016, 12:49 PM #56
              • Reputation Power: 114
              • Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!Ctown8 is leading the good life!
              I have the heated seat kit i plan on putting into the foz, if i get to it before you ill let you know how i do it. Ill send you some pics of the switch panel etc.
                March 25, 2017, 06:39 PM #57
                C.J974 Offline
                • Real Name: Carson
                I had some money burning a hole in my pocket, after not doing anything to my foz over the winter. With it being too miserable to start on my much needed body work (Ice Racing is a little destructive) I figured I should throw money at my interior, my audio quality to be exact. My subs were very overpowering to anyone sitting in the rear seats, even at a moderate volume, so I got myself a bass knob. After I finished that, I may have started talking to @Ctown8 too much, because suddenly I decided I NEEDED sound deadening.
                Started with the hatch, then the front doors and the rears doors. It's amazing the difference it makes. I noticed the biggest difference when I drove in on the perimeter going to RRC and back every day. I cant hear cars passing by any more, and my exhaust isn't as invasive as it was. You also notice it when opening and closing the doors, the foz doesn't sound like a tin can anymore. On top of all that, my stereo sounds noticeably better/cleaner. Also under Colins advice, I put in foam speaker cups to get a bit more bass out of my front speakers.
                And finally, yesterday I picked up an amp for my speakers and installed it today. Took quite a while to get all the wires run and soldered, but it all went smoothly and I still managed not to break any clips!! I also finally took the time to solder my head unit connections together and take the marrettes off from when I first installed it almost a year ago lol.
                https://www.flickr.com/photos/124745423@N04/albums/72157678511611813
                As far as I'm concerned my stereo is complete now, until I'm talked into upgrading everything. Next on the list is a new front bumper and lip, as well as side skirts (I had a rough winter). If anyone knows of someone or somewhere I could get a decent set, if you could let me know, that'd be awesome.  I'm having a hard time finding a set anywhere.
                  March 28, 2017, 10:15 AM #58
                    Carson's '99 stb
                    « Reply #58 on: March 28, 2017, 10:15 AM »
