Author Topic: 275/35/18s for street and track  (Read 1406 times)
April 08, 2016, 12:42 AM #0
SkevoX Offline
  • Vehicle: Evo x/ Frs
  • SkevoX has no influence.
Since it's spring now and I never got around to researching tires all winter I'm looking for some help. I'm looking for 2 sets of 275s for my evo. One will be used for everyday/highway well the other set will be my streetishable track tires (as long as there DOT I'm open to them) trying to keep the track tires under $400 per tire. Car is not a daily
Pic because yay new wheels  :banana:
    « on: April 08, 2016, 12:42 AM »
    April 08, 2016, 09:54 AM #1
    • Reputation Power: 173
    How much track time do you plan on doing? Autocross or time attack?
    Michelin Pilot Super Sports are a great track/DD tire, they're all rated #1 in the "Max Performance Summer" category on Tirerack.com. Unless you want something more aggressive and track focused.
    Check out these two links, credit to Magner for posting them in another forum.
    http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=MP
    http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=UHP
    Last Edit: April 08, 2016, 10:31 AM by Vince
      April 08, 2016, 10:06 AM #2
      Check out these two links, credit to Magnet for posting them in another forum.
      And they last forever.
        April 08, 2016, 01:12 PM #3
        • Reputation Power: 194
        First off what kind of track do you have available in SK? Autocross? Oval?
        If you are just *interested* in track and not an avid racer then I wouldn't even think about buying track tires. If you want to attempt track the tires @Vince suggested will be great for daily and not bad for as novice track tire.
        If you get hooked at the track then next season you'll have a better idea with your own research and speaking with your fellow racers.
          April 08, 2016, 03:38 PM #4
          ATP Offline
          • Real Name: Adam
          • ATP has no influence.
          I am running MPSS in exactly that size, 275/35/18. Although only on the rear.
          I found the best deal at costco, yes costco.
            April 08, 2016, 04:00 PM #5
            • Reputation Power: 246
            275/35/18 PSS from PMCTire are CA$1,401.55 shipped including tax.
              April 08, 2016, 06:34 PM #6
              SkevoX Offline
              I'll put like 5000km on the car a year. Was thinking about nt-05s and a set of cheaper tires for when it's not on the track. But they gotta be decent enough to make 500whp respectable on the street. Will be tracking at castrol in Edmonton. Will also be doing some events in sask. So mix of time attack and auto cross
              Last Edit: April 08, 2016, 06:39 PM by SkevoX
                April 09, 2016, 02:06 PM #7
                SkevoX Offline
                So I've bin reading up on the tires you guys have recommended and depending on what I can find for prices I will probably be picking up mpss for everyday tires. But still feel I want somthing more aggresive for the track. My only concern is finding the happy middle for a tire that will preform good at low heat for auto cross but not overheat for bigger tracks.
                  April 09, 2016, 04:16 PM #8
                  Imprzme Offline
                  • Vehicle: '16 Legacy 3.6R
                  • Reputation Power: 20
                  • Imprzme barely matters.Imprzme barely matters.
                  I don't think you'll ever find that - it's either one or the other. No matter what you buy it'll be a tradeoff if you want both.
                  Save your breath - you'll need it to inflate your girlfriend
                    April 09, 2016, 04:40 PM #9
                    SkevoX Offline
                    I'm thinking I'll use the mpss for autocross and possible get somthing very track orientated for the other set. Possible just make the leap to a nt-01 or somthing of that variety
                      April 09, 2016, 04:45 PM #10
                      Nhil Offline
                      • Real Name: Josh
                      • Vehicle: 2000 Honda S2000
                      • Reputation Power: 91
                      • Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!
                      Following this, I would try and decide which one you would be doing more and find something that suits that better. Something like a Bridgestone re71r will be great for autocross since they're quite sticky, however they wear quickly when hot from what I've read. Something like a Hankook rs-3 will be great when hot and will wear well on track, but be difficult to heat up and maintain for an autox event.
                      Both tires will work in both situations but try and find one that suits what you'll be doing more often.
                      [Mar 02 10:56:01] TwoFourDee:..ever
                      [Mar 02 10:55:59] TwoFourDee:nobody quote me on that
                      [Mar 02 10:55:56] TwoFourDee:I actually like those rotas
                        April 09, 2016, 06:37 PM #11
                        SkevoX Offline
                        I couldn't decide on the ideal tire for me that's why I got a secound set of wheels so I can easily switch back and forth depending on what I was doing
                          April 09, 2016, 06:53 PM #12
                          Nhil Offline
                          • Real Name: Josh
                          Sounds like you might need a third set!
                            April 09, 2016, 07:44 PM #13
                            SkevoX Offline
                            Way to plant the seed
                              April 10, 2016, 04:13 AM #14
                              I used to own a set of Kuhmo Escta V10 slicks I used for autocross. They were simply amazing and turned my civic into a go kart. Definitely have to change the wheels at the event.
                                April 10, 2016, 10:04 AM #15
                                • cluelessk has no influence.
                                What about the Nankang NS 2R? It's  DOT R compound that's pretty affordable and seems to have good reviews.
                                 They come in 180 and 120 treadware.
                                  April 12, 2016, 01:48 AM #16
                                  SkevoX Offline
                                  I can't find anything on these
                                    April 12, 2016, 01:52 AM #17
                                    SkevoX Offline
                                    Have you ran any other slicks to compare these too? Car will be trailered to tracks so wear isn't a issue. From what I've researched lots like to stick to the Hoosier slicks or hankook
                                      April 12, 2016, 07:14 AM #18
                                      No I have not. I decided to jump back to street tires because with racing slicks it puts you into one of the most penalized groups if you were wanting to be competitive.
                                      But mainly slicks hide your mistakes and save you bacon when you should of spun out or not made the turn. I wasn't progressing as a driver.
                                        April 12, 2016, 11:11 AM #19
                                        You still aren't!
                                          April 12, 2016, 11:35 AM #20
                                          • Vehicle: 2013 Nissan Leaf SL
                                          Originally posted by Riley
                                          You still aren't!
                                          He needs to drive as a driver to progress as a driver
                                          New business opening soon...
                                            « Reply #20 on: April 12, 2016, 11:35 AM »
