Author Topic: G35 Questions - Snapped E-brake, Rough Idle  (Read 909 times)
May 09, 2016, 10:40 PM #0
thomasmarzec Offline
  • Real Name: Thomas
  • Vehicle: '04 G35 Coupe 6MT
  • thomasmarzec has no influence.
Hello everyone, just had a couple of questions regarding a manual 2004 G35 coupe.
1) I took the car to my mechanic so he could tell me what the left it would need for safety. Turns out the e-brake is snapped, he said there's a link or cable for the left side of the car, and the right side. The left side cable is broken. Does anyone know what that cable/part is called? Is it the same as one from a 2004 G35 automatic (asking because they only have auto ones at the wrecker). He thought the e-brake needed to be tightened but like I mentioned, the left side link/cable is damaged somehow.
2) The car will sometimes stall, UNLESS I give it gas - The RPMs will drop but go back up. From what I've been reading these could be the problem:
- The intake (Nismo) seems to be from a 350z - fits comfortably and it tight but doesn't clamp on to anything (can provide pics)
- The throttle body might be dirty or needs to be replaced
- MAF (mass air flow sensor) - this could be dirty or need to be replaced as well
- Camshaft sensors - read that this could be it online
If anyone has any advice, or help with these questions I would greatly appreciate it.
Thank you.
Last Edit: May 09, 2016, 11:03 PM by thomasmarzec
    « on: May 09, 2016, 10:40 PM »
    May 09, 2016, 11:01 PM #1
    May 10, 2016, 01:03 PM #2
    I'd do the easy stuff first for the rough idle.
    Make sure the intake is tight and there are no leaks, clean the MAF and throttle body. These cars will idle poorly and stall if there is an air leak after the MAF. The two piece plenum on the VQ35DE can leak too sometimes, this would cause the same symptoms. Remove the top half, clean and install new gasket would be something else inexpensive to try.
    Camshaft sensor would likely throw a code if it were the issue.
      May 10, 2016, 03:24 PM #3
      • Real Name: Thomas
      @Winter Beater The intake looks fine, it's just the clamp I'm worried about. I also think you're right about the engine code regarding the camshaft sensor - there is no check engine light right now. I'm kind of scared to clean my MAF or throttle body, my neighbour did that in his '05 Accord Coupe, then had an even worse idle and ended up ordering a new throttle body. I guess I might find a good thread on cleaning the TB and MAF. Thank you.
        May 13, 2016, 09:40 PM #4
        Call partsource or piston ring or an infinity dealer and they will give you the part number. You can also call Canadian tire.
          May 15, 2016, 10:24 PM #5
          • Real Name: Thomas
          @CFMP RAblue Yeah you're right, but if it's one of three options - I wanna properly diagnose the problem before I buy any parts.
            May 15, 2016, 10:29 PM #6
            I know turning the throttle body manually can ruin it on some cars.
              May 19, 2016, 08:48 PM #7
              I might have a spare throttle body lying around if you need one, I'd have to look.... PM me if you end up needing one. I'm 99% sure I don't have a MAF.
                « Reply #7 on: May 19, 2016, 08:48 PM »
