Author Topic: Recommend good shop  (Read 672 times)
May 13, 2016, 11:15 AM #0
Biggie shorty Offline
  • Vehicle: 1996 Mitsubishi Lancer Evolution IV GSR
  • Biggie shorty has no influence.
Hey peeps. Having a idle issue still with my evo 4 :unamused:. Replaced the IACV and that hasn't seemed to fix the problem. Cleaned whole engine bay. Doesn't seem like there any vacum leaks. It will fire up no problem and maintain a regular idle. It's just when it starts to heat up and I begin to drive does it want to stall out when I clutch in and let my foot off the gas.  Just want to bring it into a shop now to find out problem and have it fixed. Can anyone recommend a decent shop to take it to in the city..have been to Mitsubishi and they are complete joke over there.
Last Edit: May 13, 2016, 11:16 AM by Biggie shorty
    Recommend good shop
    « on: May 13, 2016, 11:15 AM »
    May 13, 2016, 11:25 AM #1
    Give Speed Factor a call and see if they can help you out.
      May 13, 2016, 01:41 PM #2
      maybe after it's warmed up when the fan turns on it's drawing too much current because of too much resistance somewhere and voltage drops.
      causing rpms to drop too low during idle.
      maybe if you check at night or a dark place you can see the dash lights get dim during the rough idle.
        May 13, 2016, 09:34 PM #3
        Did you check your spark plug wires/coil packs to see if there are any cracks. They could be tight went cold then once the plastics heats up the cracks could open up and start grounding.
        No other drivability issues? WOT?
          May 14, 2016, 03:45 AM #4
          SavageTaco Offline
          • Vehicle: Evo9 GG MR
          • SavageTaco has no influence.
          Check your TPS sensor. I've posted about how to test it before. I've had similar problems and it ended up being the TPS. It can also be other things, but it doesn't hurt to check. If you're looking to take it to a shop, I'd recommend Jackson Auto Sport or Speed factor.
          Evo 9 aka "The Grinch" pump gas warrior
          Self tuned on an AEM V2
          2000 Aristo V300 - Daily
          "When in doubt run flat out"- C Mcrae
            Recommend good shop
            « Reply #4 on: May 14, 2016, 03:45 AM »
