Author Topic: 1993 Mazda Probe GT  (Read 362 times)
May 27, 2016, 07:57 AM #0
Madmonkey Offline
  • Real Name: Mike
  • Vehicle: 2007 yaris
  • Madmonkey has no influence.
Well now that i'm parting out my mx-3 i have a new project. After getting the mx-3 i was browsing the boards and got in touch with an old buddy from MPOC. to make a long storey short i picked up both his probes a 96 i'm just going to safety and throw on kijiji, a nice almost rust free 93 probe gt with my old fully built ZE/DE engine.
Things to do this year
things to do next year
items removed
Electrical:
Battery relocated to hatch, Moroso battery box & cable
Flaming River battery disconnect switch
Suspension:
Tokico Illumina adjustable struts, perches cut for coil-overs
Ground Control coil-overs
Front strut tower bar (not sure if I had a clearance problem with the ZE manifold)
Rear strut tower bar
Mazdaspeed lower control arm bushings (stiffer than stock)
front Mazdaspeed6 12.6" rotors and calipers
Engine & Drivetrain:
Clutchmasters Stage 3 clutch
Clutchmasters lightweight flywheel
OBD I ecu with ZE vris points, no egr, 7950 RPM rev-limiter
RC Engineering 65mm bored throttle body
Unorthodox Racing underdrive pulley
KLDE/ZE Knife edge crank, forged eagle rods & 8.1 Ross pistons, ported heads to ZE gasket size,
5-angle valve job, modifications for 2.7l stroker
Colt Cams Turbo grind
KL-ZE intake manifold
Oil pump has been shimmed to increase oil pressure
motor mounts with polyurethane Filled
Cosmo Fuel pressure regulator
Hotshot cold air intake
Walbro high pressure fuel pump
millenia S injectors
MS plug and play ecu
Exhaust
Greddy SP exhaust
Bosal ceramic coated headers
Catalytic converter delete pipe
intercooler and piping
hotshot headers modified to plum turbo
3" stainless steel exhaust piping
3" Magna flow muffler
Interior:
Mazdaspeed shift knob
B&M Pro-edge short shifter
New shifter bushings
Momo steering wheel
Exterior:
Wings West Thruster rear spoiler
fx designs kit
pictures and details will be posted soon
Last Edit: May 10, 2017, 02:29 AM by Madmonkey
    1993 Mazda Probe GT
    « on: May 27, 2016, 07:57 AM »
    May 13, 2017, 01:02 AM #1
    Madmonkey Offline
    • Real Name: Mike
    Visited the car the other day to steal some parts for my red probe, hopefully in a few months it will be saftied and on the road then I can finish what I started back in 2002 which was to build a 11second probe, but I think now I'll just be more then happy if I break into the 12s.
    Last Edit: May 13, 2017, 01:05 AM by Madmonkey
      1993 Mazda Probe GT
      « Reply #1 on: May 13, 2017, 01:02 AM »
