Author Topic: Removing surface rust from rock chips  (Read 3893 times)
June 11, 2016, 05:30 PM #0
As the title states I'm looking for a (hopefully cheap) method of removing some surface rust from my hood that was causes my stone chips. I'd rather not have to get my hood refinished.
It's not terrible, but I'm worried that I don't do anything about it that it will get worse.
There's also a sizeable stone chip that caused my paint to flake a bit due to washing my car. :(
    « on: June 11, 2016, 05:30 PM »
    June 11, 2016, 10:48 PM #1
    Surprisingly sonax fallout cleaner cleans out rust. Use that and then touch up paint once the rust is gone. $30 for a bottle at speedfactor.
      June 12, 2016, 01:44 AM #2
      I actually meant to ask about that stuff as I've seen it on Instagram. I'll pick some up this week if I have a chance.
      Would Ronax or Honda be better for touch up paint?
        June 12, 2016, 09:54 AM #3
        • Reputation Power: 110
        I'll admit that I haven't used Sonax Fallout Remover but I am extremely skeptical that it can remove rust. I do definitely believe that it will dislodge loose iron particles and that "orange dust", but oxidation needs to be chemically stopped or mechanically removed from the metal. That said, if it's just a little bit of "turning orange", you could clean it with that fallout remover, paint over it with a dab of touch-up, put a dab of clear over top, then wetsand it flat. Should last a pretty decent while before the rust causes the paint to bubble. By the time that happens, it will have eaten into the metal more, so sanding it off will likely reveal deeper etching that will need filling and a broader affected area.
        Rondex touch-up paint is pretty good with the colour matching most times, but it's quite expensive at over $20/can and the coverage is terrible. The Rondex rattle can clear is hands is super finicky. If it's too hot, it won't set right. If it's too humid, it won't set right. The nozzle sucks absolute ass and is pretty likely to either dry spray into your wet coat, or lob a loogie of clear onto the surface that you'll then have to sand out. I've gotten a very nice mirror finish with it, but it absolutely needed wetsanding and buffing to do it. Once that's done though, it's decently tough and looks good.
        Depending on the expanse of the affected area, you could attempt a blend with rattle cans, but believe me, it's easy to screw up. I know I screwed mine up, and it was simpler than a hood.  I have a lot of wetsanding and buffing to do. I had some flaking paint on the lip of my wheel arch, so I sanded it down to bare metal and feathered out the area as little as possible, then scuffed a large area around it with a gray pad and sanding paste. (this is actually my mistake- I should have scuffed the entire fender or at least a larger area and recleared the whole thing) Then I primed, then blended out the repair with Rondex colour matched base, and cleared over the entire scuffed area. Getting Rondex clearcoat overspray on unscuffed areas was my downfall. I'm now stuck having to feather it out while trying not to burn through the factory clearcoat. Definitely don't do what I did.
        Last Edit: June 12, 2016, 10:01 AM by firelizard
          June 12, 2016, 06:35 PM #4
          Lou Offline
          • Real Name: Louis
          • Vehicle: 2017 Toyota 86
          • Reputation Power: 35
          • Lou is working their way up.Lou is working their way up.Lou is working their way up.
          I found that fiberglass pen thing I was mentioning last fnl. No idea if it's the proper way to go about removing rust resulting from some chips but I found it worked ok for me when I used it on my TSX. Your welcome to borrow it if you want to.
            June 12, 2016, 07:47 PM #5
            Toilet bowl cleaner. Soak a Q-Tip in it and dab the chip and wait. Use water after to neutralize the cleaner. Dry well.
            For touch up paint I'd go to a body shop. They can usually give you a little of the left overs. A Honda shop will most likely have a bunch of extra. When I did mine I just mixed some left over clear with my black base and it turned out well and lasted a long time. A cardboard match stick with the head pulled off works best for a brush.
            Last Edit: June 12, 2016, 07:58 PM by cluelessk
              June 12, 2016, 07:50 PM #6
              Another more detailed method.
                June 13, 2016, 11:08 PM #7
                Thanks for the feedback guys! I'm going to try Sonax Fallout Cleaner first since the rust spots are just surface and very minor. If this method doesn't work I'll try something more through!
                I'll probably try and tackle this Saturday. I'll try and remember to post pictures.
                  June 17, 2016, 02:57 PM #8
                  Boyli Offline
                  • Real Name: Paul
                  • Vehicle: 2007 Impreza, 1994 Camry
                  • Reputation Power: 23
                  • Boyli barely matters.Boyli barely matters.
                  Apply a bit of rust inhibitor acid in the spots with a Q-tip then apply some touchup paint in there then clear nail polish over top to seal it. Contrary to above the touchup paint at Rondex is $15, I work there.
                    June 17, 2016, 04:51 PM #9
                    I was referring to spray cans. I would use them more often if they were only $15. Of the two (base and clear) one is a bit more expensive. I think it was the base. Either way. 20ish.
                      June 24, 2016, 11:56 PM #10
                      In for TTI Deals, which Rondex? any Satin White Pearl for a '14 Forester?
                        June 25, 2016, 08:13 AM #11
                        Boyli Offline
                        • Real Name: Paul
                        There's only one in the city, 177 Isabel :)  Yeah I can mix up any colour but I'd need the paint code. Should be in the passenger side door jamb. Pearl whites aren't easy though because they're what's called a tri-coat. You need to apply a base of solid white, then a translucent pearl coat, then a clear coat.
                          July 14, 2016, 11:15 PM #12
                          Unfortunately the foz has a few more chips than id like to admit. Does rondex sell a primer for the deeper chips to the Metal/Plastic?
                          37J is the paint code for Satin White Pearl. I have one spot on the roof that has some rust built up, took a nasty rock, any advice for clearing that up apart from the fibreglass pen, sonax and rust inhibitor acid? Ive also never done anything like this but would like to get better at it...Any advice is welcome. Ive read that this colour should contain The Base Color, The Semi/Gloss Coat, and The Clear Coat. and just practice a handful before attempting with a tricoat.
                          Also should do the Legacy, perhaps a good project to learn how to touch up??
                          @Vince Sonax review?
                            July 15, 2016, 10:52 AM #13
                            Boyli Offline
                            • Real Name: Paul
                            We have some filler primers but only in spray cans and it's not going to fill a larger chip, your best bet would be clean it out with rust inhibitor, a bit of spot putty or fiberglass, a bit of primer, then the base, the pearl, then clear.
                              July 15, 2016, 11:21 PM #14
                              @Vince how did the Sonax work out?
                                July 15, 2016, 11:53 PM #15
                                I've yet to actually buy the sonax haha I've been too busy and keep forgetting. @dan @Colby
                                  July 16, 2016, 12:47 PM #16
                                  Let us know.how.it works out.  I'm also going g to pick up the same stuff and try to seal my hood after.  Stone chips suck
                                    July 16, 2016, 02:25 PM #17
                                    @Igor has also used it IIRC. From what I've heard it works pretty good
                                      July 17, 2016, 05:33 PM #18
                                      The sonax works great. I had a few chips that started rusting. One poot of the sonax and it pulled it completely off to expose clean metal underneath. Wash off with water and fill in with paint.
                                        July 17, 2016, 07:08 PM #19
                                        • Reputation Power: 72
                                        CLR on Q-Tip
                                          July 19, 2016, 07:35 PM #20
                                          Good news guys! I found another method to get the rock chips and rust spots fixed! It was pretty easy too!!
                                            July 20, 2016, 10:49 PM #21
                                            Uhhh sweet?
                                            That's a bit of a bummer, but on the bright side you can do a clear bra after it's fixed or replaced. :) Silver lining?
                                              July 22, 2016, 06:03 PM #22
                                              Originally posted by firelizard
                                              Uhhh sweet?
                                              This isnt the cheapest method but itsnt the most expensive one either... my condolances vince, good to see you are ok though!
                                                « Reply #22 on: July 22, 2016, 06:03 PM »
