Author Topic: The Foz - The Do All Daily  (Read 12056 times)
June 03, 2017, 08:35 PM #150
Took the foz to JP Subaru this week for the CVT fluid change. I tried to bargain off my future first born. $450 for the service and oil. OUCH! But, it was quick service, they didnt do anything more or less and didnt hammer on it during the road test. Considering I'm set for another 100,000kms, $450 isnt that bad.
We worked on Matts Forester. TLDR. Its fixed!
He was full on ready for a MT swap, I told him to hold his horses, lets pull the pan and see if something is wrong internally. That lead to him sourcing a tranny from Subaru Gerry, I did a bunch of cross referencing on the USDM vs JDM, Phase 1 vs Phase 2, Studying what solenoids can be swapped and or boughten. Turns out its like $300 or so for a solenoid. Gerry hooked us up at $400 for a USDM 4EAT. The plan was to swap it in if needed.
After work on Monday we dropped the Automatic Trans Oil Pan. This was my first time in a trans, so it was touch and go for me, but I do know subarus.. Luckily Matt has been in a VW for sometime and has had lots of trans experience... but not autos. We dropped the pan, fluid went everywhere. The previous owner had been in it and Red RTV'd the **** out of the pan gasket. Goop everywhere. The oil was brown and burnt, but there was very little trans wear. After cleaning ourselves and the area up, we got to take a peak at the Solenoid Valve body/block. Where he hit a rock and bent the pan during the offroading venture, was the Clutch solenoid. Sheard the connector off and there was no way to repair it. So we grabbed fluids, filters, food, did an oil change on his forester and dinked around until Gerry got home and then we used my grocery getter to pick up the new-to-us transmission. The one we grabbed was the same tranny, but was a minor revision. He had a S1AA, and we got a C2AA. We got back to the shop around midnight, stripped the new tranny, pulled the new 2-4 Clutch Shift Solenoid, tested it and installed. What we didnt realize was that RTV takes 24 hours before its cured... damn. I layed a nice thin gasket out of Black RTV, and we reinstalled everything.
The next day we filled the transmission up with Castrol Transmax, took it for a rip around the block. The transmission is shifting again, smoother than when he got the car.
He now has a parts transmission and might even be willing to sell parts if anyone needs for a Phase 2 4EAT.
Back to The Foz, I have started the audio portion of the build. Subwoofer box is built and curing as I type. More to come on this as I tackle it slowly
    « Reply #150 on: June 03, 2017, 08:35 PM »
    June 05, 2017, 12:33 PM #151
    WOO!
      July 07, 2017, 09:26 PM #152
      Nothing more than a small tuning and maintenance update for The Foz this time.
      I changed the Differential fluids today with Castrol 75-90 Full Synthetic, first time doing this so I am not sure on how to "read" the oil and residues. Interestingly, both front and rear diffs were low. I am unsure how much oil gets eaten or escapes through the breather, but I'd wager they were at 75% of full. Boy, were they black and throughly used; The front looked like it may have had some water dilution too. It almost looked like it was grease in spots on the magnets...
      Engine Oil was changed at 7,000 instead of 10 and it was real bad. I suspect it was from all the hard driving since I started the tuning with Torqued. A new fill of Pennzoil Ultra Platinum and I should be good for the rest of the summer. Oh, also did another seafoam to the fuel to help clean the injectors and keep it running smooth. $12 piece of mind,
      We are on to Revision 17 of the map. The CVT and the FA20DIT is apparantly a **** combo, the trans lugs the motor and the DI is extremely tempermental with knocking. Whenever I use Manual or SIDrive - Sport Modes, there is next to nothing and it performs like the WRX would. The CVT is always keeping fuel economy in mind instead of running a safe RPM. Luckily the motor is extremely adaptable and versatile with the timing, AVCS, and knock strategies. The Grimmspeed 3 Port EBCS is extremely consistant with its controlling and hasn't spiked more than .5 PSI. The stock controller had as much as 5 PSI for spikes - Target is 18 PSI, Achieved was 23 PSI. Overall the tune is about the same performance as the COBB OTS Stage 1, however its extremely safe on the tranny and the motor. Considering that I have added a few hundred pounds of weight, bigger tires, heavier wheels, reduced the aerodynamics and witht he tune she is a bit quicker than stock, Id say its a win-win. She isnt fast, but shes quick... enough. Torqued adjusts some stuff and the Feedback Knock goes wild, antoher and the Fine Knock goes crazy. Its like a magical balancing act that is fighting him with every revision.
      Most likely nothing more for a while, until the audio gets finished and I head out west for a weekend later in August/Sept
        July 08, 2017, 04:10 AM #153
        Wow that's a lot of revisions. You should post up some logs. I'm interested to see what's going on.
          July 08, 2017, 08:33 AM #154
          Nirusan Offline
          • Reputation Power: 217
          http://datazap.me/
            November 09, 2017, 10:00 PM #155
            WOW, I havent been here in a while!
            TTI has missed so much, Ill try to write it all down!...
            She is on Winters now.... Thats really about all :P
            I chose to change tuners to Bren Tuning. I probably should have gone to them first, but decided to cheap out. Oh well. We are two revisions in, and they immediatly tell me that something is wrong with the intake system. I need to check it out before we continue. (side note: same setup and build as the Torqued tune)
            This evening I tore apart the intake system, From MAF to Turbo, disassembling the BPV and Charge pipe. Removing the intercooler and all.  I have never done a tear down of the intake system before on this car so it was cool to pull it apart.
            I partially followed the "Danoz Clamp Fix" (http://www.subaruforester.org/vbulletin/f207/danoz-fix-fa20dit-turbo-clamps-318129/#/), I replaced every clamp instead of tightening some and replacing others. Almost every hose clamp was only finger tight and many of the flanges were mis-shapen from the OEM clamps. Each one was cleaned and reassembled.
            @Igor @Nirusan
            https://datazap.me/u/cspence47/wot?log=0&data=3-9
            https://datazap.me/u/cspence47/wot?log=1&data=3-9
            Here are two WOT logs, One before the intake system service and one after. Both on Bren Tune Rev 2.
            Here is a crusing log, BrenTuning, Rev 2 - https://datazap.me/u/cspence47/cruise-after-wot?log=0&data=8-24
            Here is one from the last Rev on the TP Tune - https://datazap.me/u/cspence47/tp-wot?log=0&data=7-21
            To me the tapering boost was not a factor of the tune but of a boost leak that Ive had for a while. It should taper but not by 7 psi, at least to my assumptions.
            So from here I'll keep playing and tuning with Bren and see how things go!
            Last Edit: November 09, 2017, 10:03 PM by Colby
              November 10, 2017, 12:02 PM #156
              Boost taper will depend on what your initial boost is and how much pressure your turbo could build. For example, my peak boost hits 21.5 at around 3400 rpms but tapers down to 13-14 by 5500 rpms. The turbo is just too small to keep up that pressure.
              Your cruise logs still show a lot of random feedback knock. Are you feeling the car pull timing like it did during during our drive to the rally? DAM is all over the place as well but I believe you mentioned that was because of the direct injection.
                November 10, 2017, 11:32 PM #157
                I chatted some more with BrenTuning today. It turns out that the FA20DIT setups when properly running will compensate the amount of boost based on the ambient temperature. I have no idea how the Duty Cycle works, but it was at 71% and that somehow equals over 22 PSI. However in low temps such as -17, when I took that log, the ecu drops the boost because of the denser air. The turbo running at 13 PSI at -15C is equal to it running at 20PSI at +15C... If I understand it right and all things are roughly equal.
                With that being said BT wont tune the car until we are above +3C... soooo I may be waiting till spring to tune. We shall see how things unfold.
                Regarding the maintenance, It has solved the fueling issues that I was having with it and is running much more consistent.
                Its still pulling timing, but only on tip in/out throttle. Its no longer doing it when cruising!
                  November 11, 2017, 01:56 PM #158
                  yeah that's pretty standard. During the summer I've seen 22psi but during the winter I don't think my car has hit over 18psi. Colder air is more dense and requires less of it to reach the required number.
                  probably for the best too. I think you would want to log is warmer temps as hotter conditions might be more prone to knocking.
                    November 11, 2017, 10:26 PM #159
                    Ran another day on the BT Rev 2, still quite a bit of feedback and FKL... being that it was tuned with a leak and only rev 2, there is still lots left on the tables to clean up. However I consistently hit 18PSI today with Intake temps of 38F.
                    I swapped back to the last rev of the TP tune. It ran extremely well now that BT was able to diagnose the issue over the logs. Ill be running TP for the next little bit until BT gives me a cleaner rev or until the temps warm up enough to log and revise in the spring.
                      November 12, 2017, 01:23 PM #160
                      Gonna be +3 on tuesday!
                        November 13, 2017, 03:11 PM #161
                        Hit 20.50PSI today! BT Rev 2 is still super rough though. Hope to get a few revs in efore the cold comes back
                          November 23, 2017, 08:30 PM #162
                          I am on Rev 3 currently. The LSPI knock is still happening. WOT pulls are 100% clean, no issues or any chance of harm.
                          The LSPI happens mostly because the CVT "lugs" the motor. It aims to keep the RPM's between 1300 and 2000 at any given time, depending on the speed. I did a bunch more reading and it turns out that Pennzoil is heavy on the calcium, a detergent, as their line of products is supposed to keep things clean and sludge free. Rumor has it that Calcium is a major contributor to LSPI. Motul has released a new oil that is designed specifically for DI engines. BrenTuning has seen proven results with it, so I am going to give it a shot. It is supposed to also improve MPG and keep the engine just as clean as any other oil... Only time will tell I guess. I'd rather do a cleaning additive every second or third change than have it run like poo.
                          I have also done a EGR "Delete". By simply removing the solenoid's connector it locks the EGR valve shut. By doing this is has almost cut the LSPI Knock in half for the most part.
                            November 24, 2017, 10:02 PM #163
                            Next minor update in an attempt to help stop the LSPI.
                            I spent a fair amount studying oil reports and forums. We all know everyone is an expert on the internet :P
                            I did a half assed oil change today. I swapped out the Pennzoil Ultra Platinum for the Quaker State Advanced Durability 5w-30, Its a Dexos 1 Gen 2 spec'd oil. The new spec, Gen 2, is designed specifically for LSPI/ DI engines. With low calcium and more of a Magnesium/Moly base as a detergent/friction modifier, they have around 1000PPM (or even lower in some cases) vs 2500PPM for most oils.
                            The LSPI is still there, considering its only been one drive, I doubt Ill see to much difference. I didnt swap the filter either, so there will still be some higher calcium in the system. But, the biggest change is how the motor is reacting. LSPI is still around, but it seems to be much less aggressive, and the ECU is attempting to advance the timing more.
                            I'l report more once I get into the new Motul oil.
                            On a non-tuning issue note. My block heater tripped the GCFI at home for the last few times. I decided to get pricing on replacing it, thinking it had gone bad in the block. The FA block has it behind the exhaust manifold. You have to remove a subframe, drop the exhaust manifold, disconnect the turbo charger and intake, drain the turbo charger oil feed, and drain the coolant system. Its reportedly only 2.5 hours at the dealer which is around $350 at shop rate plus the $250 for a new block heater. Some people have been charged as much as $1200 for it to be installed...
                            Long story short, the cord was shorted out internally and was sending 120 volts to the chassis. It was a 45 minute job to unbutton everything, diagnose, cut out bad section, splice in new, and reassemble. She is as good as new now.
                              November 26, 2017, 01:55 AM #164
                              You could try doing an oil analysis to see how much calcium is actually in the system. Not sure how much that would actually tell you anything
                                December 03, 2017, 01:26 PM #165
                                Yet another LSPI update. Turns out I grabbed the wrong Quaker State oil.... it was the old formula, however it still behaves better than the calcium filled PUP(Pennzoil Ultra Platinum) Dexos 1.
                                So I ordered the Motul... turns out that the company fullfilling the order dinked around. It isn’t what I ordered at all, so that week wait was for nothing.
                                I did some VOA research on BITOG regarding Dexos 1 Gen 2 oils.
                                Turns out that the Pennzoil Platinum and Quaker State Ultimate Durability 5w30’s have G2 license’s since they reformulated to be compliant.
                                I chose to do the PP D1G2, it’s almost the same as the QSUD D1G2, it has lower Ca. The QSUD arguably is a better Oil with better antiwear and lube packets.
                                Anywho, I loaded this new oil up. For the last 200kms it has been volatile as ****. Its almost as if the ECU is torn between pulling timing and advancing it. It has been leveling out with the more miles I put on it, I guess as the oils balance, the calcium’s gets pulled from the cylinders and such. I had the first highway drive today with NO FKL or DAM drop, ever! I am pretty pumped. I have yet to test the city portion as I have been ripping around in Sport and Manual to keep the motor out of the Low Speed area.
                                Sooo, Woohoo! The car is boosting to 21PSI! It’s tuned for 19, so we have to get that down. But loads, AFR, LSPI are all becoming acceptable!
                                On another note, we did some hose clamp mods on Matt’s WRX/Tomika. They worked well and solved a small leak! I wish my Foz snapped and popped like yours does dude.
                                  December 03, 2017, 03:56 PM #166
                                  @Colby
                                  have you seen this? https://www.amsoil.com/lander/lspi-update/
                                  "Proving it can protect turbocharged direct-injected engines, AMSOIL achieved 100 percent protection against LSPI in the engine test required by the GM dexos1® Gen 2 specification."
                                    December 03, 2017, 09:05 PM #167
                                    alohaimmatt Offline
                                    • Real Name: Matt
                                    • Vehicle: 2017 DGM WRX
                                    • alohaimmatt has no influence.
                                    Straight piped Foz incoming? :)
                                    Thanks again for the help!
                                    Like I mention, hit up Amazon support tomorrow morning. They'll definitely try to make the issue right, at the very least you should be able to return them all without any hassle!
                                      December 03, 2017, 10:54 PM #168
                                      @Colby
                                      That is cool. Perhaps that what Ill use for the next interval
                                        December 18, 2017, 09:00 PM #169
                                        UPDOOT! No Pics though :(
                                        I stopped by @BRAUDIO the other week and FINALLY picked up the other half of the audio build for the Forester from @Ctown8 . We have a AVH-2300NEX 7" Deck, Focal 2Way... somethings... I dont remember... and a ton of harnesses to bypass/integrate everything that we could.
                                        Simply saying that Colin "helped" with the wiring/install and build is so much of an understatement. I couldnt have done it as easily/clean or timely without his help and expertise... quite possibly not at all. So big shoutout to him and BRAudio.
                                        I was driving along this past week and out of nowhere the audio got fuzzy, cut out and died. It then came back at full volume out of one speaker and was blaring random electrical noise. It turns out that the pin connector for the Sound Processor under my seat had gotten wet and was shorting out. I yanked the connectors and left it alone for a few days.
                                        Saturday, with the help of Colin we tore into the audio build. Yanking the OEM deck, Pulling the drivers seat and sound processor. Removing the front tweeters and 6x9's, the rear tweeters and 5 1/4's. Colin and Chrissy worked through the wiring to bypass and jumper the multiple OEM harnesses and create a singular working harness.
                                        The two of them got the Deck in without any issues, steering controls all functioning and an extra USB port ran.
                                        We made MDF brackets for the front 6.5" Focals and ABS brackets for the tweeters. Everything fit fairly flawlessly. I have to say that it was the cleanest install I have ever done for a setup. You wouldnt know that anything has been changed until you hear the speakers.
                                        I was able to use my old Infinity Kappa's that were 6.5" with a massive tweeter for the rear doors. That was a huge plus in my books to resuse that old gear from the "Van Days". We had a few troubled moments along the way making them work, but in the end, they function perfectly.
                                        The OEM system used the front 6x9's as subs to play lows, the rear 5 1/4's were filling in for the mids and the Tweeters hit the highs, although they were never "bright" enough to stand out IMO. Now with how its set up, the 6.5's all around hit the mids beautifully, the tweeters are bright and noticeable with the right music. It is a more fulfilled sound than before, much clearer with greater fidelity. The only issue is that I dont have the sub in yet! As of now I am missing my lows, but that will change over the holiday break I imagine!
                                        OH! I also installed a Fumoto Valve last OCI. It should make the next change 100% toolless and a breeze.
                                          December 18, 2017, 09:14 PM #170
                                          • Reputation Power: 93
                                          Just can't go wrong with @BRAUDIO Sounds like a good setup, go get some pics right meow.
                                            December 19, 2017, 07:06 AM #171
                                            alohaimmatt Offline
                                            • Real Name: Matt
                                            Let me know how you like the AVH-2300NEX, that's what I was looking into for replacing this god awful headunit that Subaru makes.
                                              December 19, 2017, 11:21 PM #172
                                              So far, with limited usability (I havnt connected the Parking Brake wire so it is currently always in "drive" mode), its better than any headunit I have ever used. Once I have the full capability of it, I imagine it will be even better.
                                              Id give it a solid 9/10, only for the fact that you cant do an "easy" bypass.
                                              It has some cool tuning capabilities that I dont know how to use properly... but Colin thinks they are cool, so I will believe him :P
                                              If you wanted to check it out, give me a shout!
                                                December 20, 2017, 06:54 AM #173
                                                alohaimmatt Offline
                                                • Real Name: Matt
                                                Definitely! I really just want Apple CarPlay if anything.
                                                Also shoot me a text about the Christmas Drive!
                                                  December 21, 2017, 03:46 PM #174
                                                  The AVH-2300NEX, MVH-2300NEX, and AVH-1300NEX are all awesome and a huge step up in features/price to Pioneers line up. I would definitely recommend all of them, I put the MVH-2300NEX in the GF mustang for her birthday and got to play with it quite a bit and the functionality with the phone and how responsive it is blew me away, makes me wish I waited to get one instead of the AVH-4800BS I currently have.
                                                    « Reply #174 on: December 21, 2017, 03:46 PM »
