Author Topic: Toyota Supra  (Read 3154 times)
May 18, 2017, 04:36 PM #25
Supra2jz94 Offline
  • Vehicle: Toyota supra 2jz
  • Supra2jz94 has no influence.
Gaskets and studs, went for a modified waterneck, and my precision wastegate with Tial style bov.
Last Edit: May 19, 2017, 01:18 PM by Supra2jz94
    Toyota Supra
    « Reply #25 on: May 18, 2017, 04:36 PM »
    May 19, 2017, 01:25 PM #26
    Supra2jz94 Offline
    Now the single turbo kit has arrived im sure i have all i need to switch over.
    Front mount intercooler
    Exhaust modded and decatted
    New wideband
    Greddy boost controller
    Turbo timer
    Turbo blanket
    New turbo
    New manifold
    New k@N intake filter
    New wastegate and bov
    All gaskets
    All silicone connectors and clamps
    New oil lines
    Modified waterneck
    Phr intercooler pipes.
    Before with twins in.
    Last Edit: June 20, 2017, 09:06 AM by Supra2jz94
      June 15, 2017, 08:21 PM #27
      Supra2jz94 Offline
      Twins are out!
        June 15, 2017, 08:23 PM #28
        Supra2jz94 Offline
        Single is on and running.
          June 15, 2017, 08:26 PM #29
          Supra2jz94 Offline
          Almost there.
            June 15, 2017, 08:27 PM #30
            Soupy Offline
            • Real Name: Quinn
            • Vehicle: 1989 Toyota Supra Turbo
            • Soupy has no influence.
            Looks so nice :o. Gotta love the 2jz's
              June 15, 2017, 11:24 PM #31
              Supra2jz94 Offline
              Waited for this stubby downpipe from suprastore that they recomended, for my jdm Supra that didnt fit.
              Few things left to do to the supra till it can run on the street.
              - 90 degree elbow to charge pipe
              - charge pipe
              - 3 inch to 4 inch adaptor for intake filter
              - Custom 3inch downpipe to exhaust
              - Bov attached to pipe
              - wideband and boost controller to be hooked up
              - 3 dyno pulls for safe boost level on stock ecu
              Last Edit: June 20, 2017, 09:22 AM by Supra2jz94
                June 27, 2017, 08:43 PM #32
                Supra2jz94 Offline
                Update:
                3 inch to 4 inch adaptor came in, so intake and filter are on, clamps arent on in this picture, done though.
                90 degree hose came in charge pipes on.
                Waiting on Hks bov adaptor, picture shows mock up of where the bov will sit, i think it looks pretty good on top of the charge pipe like that, so itll probably go there.
                Downpipe and a screamer pipe are being made, and so to is 3 inch piping from after midpipe to tip of exhaust.
                Last Edit: June 29, 2017, 12:53 AM by Supra2jz94
                  June 27, 2017, 08:45 PM #33
                  Supra2jz94 Offline
                  Shot of the rear trd exhaust.
                    June 27, 2017, 08:47 PM #34
                    Supra2jz94 Offline
                    Trd exhaust which isnt going to cut it. The car is getting a custom 3 inch downpipe and a screamer pipe. The mid pipe is already 3 inches so thats staying. From the mid pipe back to the muffler its all only 2.5 inches the car has been bottomed out creating dents and a flat spot on the exhaust.
                    So all of that is being chopped and new 3 inch piping is going on instead.
                    My main plan for the car is to have a minimal lag street supra, lag sucks huge balls. On pump id like 550 hp and call it a day.
                    Also ordered a custom plate,  JDMV160 hopeing to get it.
                    V160 is the 6 speed getrag tranny in supras, for those that dont know.
                    In the last picture you can see the flat spot on the exhaust before the muffler, from some clown bottoming it out, probably why the spats are cracked and rear struts are worn.
                    Last Edit: June 29, 2017, 08:57 AM by Supra2jz94
                      July 25, 2017, 05:41 PM #35
                      Supra2jz94 Offline
                      Hks bov adaptor came in, Bov is now welded to the charge pipe. Greedy profec boost controller is wired up, Aem wideband is installed and working.
                      Exhaust is now done, custom downpipe a screamer pipe which points out just behind the drivers wheel. Rest of the exhaust is completely changed and is in 3 sections all v band for easy access and is all 3 inch piping race style with a turn down tip.
                      The first road test is a success at 8 psi afrs read 12.2 to 12.3. The car will be put onto a dyno very shortly to see how much the boost can be turned up safely.
                      The turbo spools up very fast, a 61mm with a .81 is a perfect fast spooling street turbo.
                      With the screamer pipe added you can hear turbo spool right away, and the rest of the exhaust now changed sounds very nice.
                      Many people have said that you need to tune your supra as soon as you switch to single. But this is solid proof that you can go single and be running safe afrs.
                      The 2jz compensates very well.
                      Car still has stock ecu stock pump stock injectors stock clutch stock suspension stock motor stock tranny.
                      Next we will see how much boost it can safely be turned up to.
                      Last Edit: July 27, 2017, 02:27 AM by Supra2jz94
                        July 27, 2017, 01:47 PM #36
                        Supra2jz94 Offline
                        Car has been dynoed.
                        Boosting 14psi limited by stock limiter.
                        Numbers 420 HP through the crank.
                        With 18 percent drivetrain loss.
                        She puts down 372 rwhp and 388tq to the wheels.
                        Afrs sitting around 11.2
                        Turbo starts hitting hard at 3000 rpm.
                        Very happy with the non laggy turbo and numbers for stock ecu and untuned
                        Last Edit: July 29, 2017, 02:49 PM by Supra2jz94
                          August 01, 2017, 05:41 PM #37
                          Supra2jz94 Offline
                          The new 3 inch exhaust system. Race style exhaust with a turn down tip.
                          Last Edit: August 01, 2017, 06:07 PM by Supra2jz94
                            August 01, 2017, 05:46 PM #38
                            Supra2jz94 Offline
                            Mid pipe, screamer pipe, downpipe.
                              August 01, 2017, 09:57 PM #39
                              Supra2jz94 Offline
                              Shots of charge pipe and hks flange and Bov.
                                August 01, 2017, 10:00 PM #40
                                Supra2jz94 Offline
                                Beautiful downpipe, even has a stamp on it.
                                  August 01, 2017, 10:03 PM #41
                                  Supra2jz94 Offline
                                  New manifold, turbo blanket, final look.
                                    August 01, 2017, 10:06 PM #42
                                    Supra2jz94 Offline
                                    All gauges now working, turbo timer, boost control set to max 15.5 has a 13 psi spring in wastegate, wideband is in and reading safe afrs.
                                      August 02, 2017, 08:34 AM #43
                                      • Reputation Power: 206
                                      No cat, resonator or muffler? ???
                                      How's that sound?
                                        August 02, 2017, 12:12 PM #44
                                        Supra2jz94 Offline
                                        It sounds phenomenal, nothing like a 2jz with a screamer pipe at full boost  :10:.
                                        Last Edit: August 02, 2017, 03:30 PM by Supra2jz94
                                          August 14, 2017, 02:47 PM #45
                                          Supra2jz94 Offline
                                          Took the exhaust in for some adjustments, and got a few shots from underneath the car.
                                            August 14, 2017, 02:50 PM #46
                                            Supra2jz94 Offline
                                            Exhaust. V band, 3 inch.
                                              August 25, 2017, 03:13 PM #47
                                              Supra2jz94 Offline
                                              Walbro 450LPH fuel pump, E85 coimpatible.
                                              Replacing the stock 190LPH fuel pump.
                                              Last Edit: August 29, 2017, 07:37 PM by Supra2jz94
                                                September 09, 2017, 01:24 PM #48
                                                Supra2jz94 Offline
                                                Before shift boot. And after.
                                                  September 22, 2017, 03:42 PM #49
                                                  Supra2jz94 Offline
                                                  Added a leather e brake boot with blue stitching, and my custom license plate.
                                                    Toyota Supra
                                                    « Reply #49 on: September 22, 2017, 03:42 PM »
