Author Topic: Where to get intake ports walnut blasted?  (Read 985 times)
August 24, 2016, 07:09 PM #0
My car's got 150k kms and carbon build up is a common issue. Idle's been a little rough. I'm looking to tune it soon and would rather data log on an engine that can actually breathe.
Would prefer to have a shop that could do it with leaving the head installed and just removing the intake manifold.
I know it's also a common issue on BMW's so maybe a specialty shop?
    « on: August 24, 2016, 07:09 PM »
    August 24, 2016, 07:36 PM #1
    • Reputation Power: 72
    think most hot tank them.
      August 24, 2016, 07:54 PM #2
      That's only if you pull the head off. Walnut blasting you you can leave the head on just making sure the intake valves are closed. The results are great.
      Before and after.
      Last Edit: August 24, 2016, 07:59 PM by cluelessk
        August 25, 2016, 09:17 AM #3
        • Reputation Power: 45
        How do you get all the blasting media back out of the head with the head on the engine still?
          August 25, 2016, 12:15 PM #4
          Compressed air and a vacuum. The valves are closed so it really doesn't make it far.
            August 25, 2016, 12:52 PM #5
            I hear @themikewoo likes blasting his walnuts at intakes. Maybe he can help you out!
              August 25, 2016, 01:19 PM #6
              Quoted for the truth. I'm getting older so I can't last that long and need lube.
                August 25, 2016, 07:17 PM #7
                Nirusan Offline
                • Reputation Power: 217
                I got you covered @themikewoo
                https://www.amazon.ca/Passion-Natural-Water-Based-Lubricant-Gallon/dp/B005MR3IVO
                Last Edit: August 25, 2016, 07:21 PM by Nirusan
                  August 25, 2016, 07:20 PM #8
                  Found a guy locally that has a sand blaster and the media that he's willing to lend me.
                    September 04, 2016, 02:00 PM #9
                    MarvinM10 Offline
                    • Real Name: Ed
                    • Vehicle: 2010 Mazdaspeed3
                    • Reputation Power: 30
                    • MarvinM10 is working their way up.MarvinM10 is working their way up.MarvinM10 is working their way up.
                    Laziness breeds efficiency
                      « Reply #9 on: September 04, 2016, 02:00 PM »
