Author Topic: Re-Pinning Electrical Sockets  (Read 950 times)
August 29, 2016, 09:58 AM #0
  • Reputation Power: 173
Is anyone here familiar with re-pinning factory electrical sockets? I received a set of headlights that has a 194 bulb socket to light up the housing, however, the seller decided to chop the wires right at the connector as seen below:
I really just need these wires extended, so I can connect them to the vehicle, so re-pinning seems like the best solution.
If anyone would be able to offer advice/assistance doing this, that would be awesome, as I'm not to familiar with electrical things.
    « on: August 29, 2016, 09:58 AM »
    August 29, 2016, 12:38 PM #1
    dangelkovski2 Offline
    • dangelkovski2 has no influence.
    I know there is a tool for this. Pretty sure you can just pick it up at princess auto for cheap use it than return it. Also contact Al and see if he would have a couple mins to swap it out for you.
      August 29, 2016, 12:44 PM #2
      The front of the connector likely has a plastic surround around the pin terminals. Pop that off. Then the two wire terminals will be more visible, likely a metal or plastic tab just needs to be relieved and the pin will slid right out the wire end.
      A straight pick will likely be the easiest tool to use. I have the terminal tools, but usually end up finding a pick easier and faster to use.
        August 29, 2016, 01:05 PM #3
        Awesome thanks.
        Once its removed, can a new wire just be crimped in its place? Or does the terminal need to be replaced?
          August 29, 2016, 03:48 PM #4
          If you're careful you can very likely un-crimp the old wire and crimp a new one on with a pair of needle nose pliers. A dab of solder wouldn't hurt things either.
            August 31, 2016, 12:38 PM #5
            this is the inside of the plug. Its got that little white pieces that slides in and out, but thats about it. Tried with a  flat head to pry within those terminals up and down, but can't manage to get the wires free on the other end.
            I also didn't want to use too much force as to break them
            @winter beater
              August 31, 2016, 04:39 PM #6
              • Reputation Power: 221
              @winter beater
              Those terminals usually have a little tab on the backside of them to hold them in the plastic piece. you'll need to get a pick or small flat head and try to pry it out of the plastic so you can pull it out.
                September 06, 2016, 03:16 PM #7
                That white plastic piece likely comes right out. Then with a straight pick you should be able to pop the tab to slide each individual pin out.
                  September 09, 2016, 04:20 PM #8
                  Earthworm Offline
                  • Vehicle: 1993 Subaru SVX
                  • Earthworm has no influence.
                  A little late but the tool you need to remove pins from connectors looks like this:
                  http://12v.org/urs/T55ECUConnectorWithBlackCoverRemoved.jpg
                    September 09, 2016, 06:19 PM #9
                    • cluelessk has no influence.
                    They're probably dirt cheap from a wrecker. Even new I don't think they're much
                      September 09, 2016, 06:56 PM #10
                      I couldn't find them at the wrecker.
                      None that I went to had Celicas ( to no surprise ). It's apparently s common Toyota plug however I was unable to find one. Ended up soldering on to this one and making it work
                        September 28, 2016, 07:16 PM #11
                        • Reputation Power: 42
                        I probably have a few of those.
                        I'll take a look next time I'm digging in the bin.
                        How long do you need the leads to be.
                          September 29, 2016, 08:30 AM #12
                          I actually managed to sort it out. But I appreciate the reply. I ended up Soldering on to the existing wire and it seemed to be sturdy enough. Its only for accent bulbs so not super important.
                          If you do have an extra set though, I wouldn't turn them down. Leads only have to be inch of 2 min, enough to splice on/extend the wire.
                            « Reply #12 on: September 29, 2016, 08:30 AM »
