Author Topic: Low-Cost Winter Tires Worth it?  (Read 3397 times)
September 08, 2016, 02:01 AM #0
jon08 Offline
  • Real Name: Jon
  • Vehicle: 5th Gen WRX
  • Reputation Power: 29
  • jon08 barely matters.jon08 barely matters.
Hello,
Thinking of getting a set of GT Radial Champiro WinterPro HP before snow hits. I will be replacing Blizzaks, I'm just not sure if it's worth it.
Price difference is at $100 per tire.
thoughts?
Thanks!
Check this page and see if your vehicle is in one of the photos! - www.flickr.com/jonaduna
    « on: September 08, 2016, 02:01 AM »
    September 08, 2016, 05:40 AM #1
    Everyone's going to have different thoughts and opinions on this.
    Personally, I don't think snow tires are a requirement if you have a good set of all seasons more of just a luxury. With that being said, anything is better than nothing. A bottom of the barrel snow tire will still probably perform better than an all season because it's soft tire compound. Will they be just as good as blizzaks? Probably not, but maybe that's all you can afford and as I said, somethings obviously better than nothing.
      September 08, 2016, 06:59 AM #2
      What size of tire are you looking for? Have you checked pmctire.com for deals?
      A low end snow tire may act slightly better than a higher end all season tire in the snow.
      You also have the option to go through mpi's program and get a better set of tires and take a  longer period of time to pay em off if money is tight.
        September 08, 2016, 01:22 PM #3
        jon08 Offline
        • Real Name: Jon
        It's 245/40/r18, got a deal with Winnipeg Wheel Works... they will not charge me for Mounting and balancing (and hopefully installation) since I'm going to have my rims painted and buy tires at the same time.
        The only reason I asked is because... I can buy more car parts if I cheap out on winter tires. lol
        Thanks @Igor and @Madbuzz41 !
          September 08, 2016, 02:40 PM #4
          Well i'm sure any winter tire would be better than an all season but I wouldn't cheap out on something that is the only contact between the car and the road, especially in the winter.
            September 08, 2016, 03:43 PM #5
            • Reputation Power: 87
            Going to agree with this 100%
            I've also run GT radial tires in the past, not specifically winters, but summers, and I had no issues with the tires. i wouldn't say they are a bad brand from my experience.
              September 08, 2016, 06:29 PM #6
              MarvinM10 Offline
              • Real Name: Ed
              • Vehicle: 2010 Mazdaspeed3
              • Reputation Power: 27
              • MarvinM10 barely matters.MarvinM10 barely matters.
              http://toptierimports.com/index.php?topic=11591.0
              Any winter tire will perform better than an all-season.
              Laziness breeds efficiency
                September 08, 2016, 08:18 PM #7
                • Reputation Power: 20
                Cheap Winter tires are way better than any all season I've used. Think I had a set of Winter Claw? Tires. Ran about $135 a tire for 225/40/18.
                Only issue is on the third remount 2 sidewalls broke. Should of just got a designated Winter wheels.
                I would buy again.
                Last Edit: September 08, 2016, 08:20 PM by cluelessk
                  September 08, 2016, 08:30 PM #8
                  jon08 Offline
                  • Real Name: Jon
                  I can't open the link. Deleted?
                  Sent from my SM-N910W8 using Tapatalk
                    September 08, 2016, 09:16 PM #9
                    wpg123456 Offline
                    • Real Name: Marko
                    • Vehicle: 2011 Subaru Impreza
                    • wpg123456 has no influence.
                    Another option is getting the cheaper winter tires studded (around $30 a tire I think) I ran studs last year and yes, it is annoying on pavement as they wear out and can slide but when it's icy/snowy you stop on a dime and it's well worth it in my opinion.
                      September 08, 2016, 10:06 PM #10
                      I always get mine studded. Gotta go easy on dry pavement, but on the highway when it's straight ice, I wouldn't want anything else on my car.
                        September 08, 2016, 10:26 PM #11
                        wpg123456 Offline
                        • Real Name: Marko
                        Ya all my future sets will be studded for sure. People don't realize the difference until they stop on ice with studs and find out how big of a difference it makes.
                          September 09, 2016, 12:06 AM #12
                          The truth is, I used to cheap out on tires (I still don't spend a whole lot) but when you compare good tires to less good tires, even if you could safely get around, it's less fun. It's hard to see all that money go at once, but good tires are one of the best modifications you can do to improve your driving experience. That said, cost is not always an indicator of performance, and it's not necessary to get the absolute best tire available. There are definitely worse things you could do than run cheap winters, like run all season or summer tires.
                          Last Edit: September 10, 2016, 02:28 PM by firelizard
                            September 09, 2016, 06:54 AM #13
                            • Reputation Power: 199
                            This.
                            I have never purchased brand new winter tires. There should be a ton of options on Kijiji.
                            What tread depth are your Blizzak's? Why are you replacing them?
                              September 09, 2016, 07:09 AM #14
                              jon08 Offline
                              • Real Name: Jon
                              This.
                              It got stolen. :(
                                September 09, 2016, 08:36 AM #15
                                Definitely go on kijiji.
                                I bought a used set there. You mnay even find a set of used "good" winter tires for cheaper than the new "cheap" tires you're referring to
                                  September 09, 2016, 10:01 AM #16
                                  I've been burnt with tires from Kijiji. They might looks fine but as soon as they're mounted or under pressure cords could be letting go. Usually from improper storage.
                                  Luckily for me the seller returned my money.
                                    September 09, 2016, 10:16 AM #17
                                    Damn that is bad luck. What was the manufacturing date? My personal rule of thumb when buying tires is no more than 4 years.
                                      September 10, 2016, 01:05 PM #18
                                      Battle Design Offline
                                      • Battle Design has no influence.
                                      I picked up a set of near new winter tires on steel rims WITH the TPS in them for 300. Oem ford steel rims.
                                      Spring/summer is the best time to find deals on winter tires.
                                        September 10, 2016, 01:59 PM #19
                                        Damn that's a good deal cause those TPS are so expensive. I got a set of Goodyear snow tires mounted on steel rims that were only driven on for 4 weeks for $200
                                          September 10, 2016, 04:39 PM #20
                                          I've personally driven on the winterpro's
                                          weren't too bad, back when I had my 99 bmw 323i I had 4 of them on, went through winter with little to no issues, this was 3 winters ago but working at the tire shop here we sell a lot of low cost winter tires, many people agree that even a low cost winter out performs their top grade all season tires.
                                            September 10, 2016, 08:03 PM #21
                                            • Reputation Power: 66
                                            I used to work at one of the bigger Tire Distributors in the city(Supplied most tire shops) And Sold alot of those Champiros. Good winter tire and always heard good things about them
                                              September 11, 2016, 05:55 PM #22
                                              jon08 Offline
                                              • Real Name: Jon
                                              Thanks for all the input @Madbuzz41 @Igor @DonR @benz88 @themikewoo  @cluelessk @firelizard and to the others I can't tag for some reason! I need more help,
                                              Found this ad on Kijiji, rubber looks good... and it comes complete with rims. Just not sure how would it fit my car.
                                              Currently running the ff: wheel specs with no issue:
                                              Bolt pattern: 5x114.3
                                              Centerbore: 56.1mm
                                              Wheel size: 18 x 8.5"
                                              Offset: +55mm
                                              Tire: 245/40R18
                                              This ad's wheel spec:
                                              18x8
                                              +35 offset
                                              5x114.3 bolt pattern Monte Titano Rims,
                                              TPMS and wheel covers
                                              The major difference is the offset, not sure how +35mm offset would affect the fitment compare to my original +55mm.
                                              Please advise.
                                              Thanks!
                                                September 11, 2016, 08:12 PM #23
                                                Lou Offline
                                                • Real Name: Louis
                                                • Vehicle: 2017 Toyota 86
                                                • Reputation Power: 35
                                                • Lou is working their way up.Lou is working their way up.Lou is working their way up.
                                                @jon08 I like to use this website for tire and wheel fitting information: http://www.willtheyfit.com/index.php?width=245&aspect=40&diameter=18&wheelwidth=8.5&offset=55&width2=245&aspect2=40&wheel_size=18&wheel_width=8&offset2=35#isPage=1
                                                Based on the site, the setup you found on kijiji will sit almost 1.5 centimetres closer to your fender (stick out) than your current setup. I don't know for sure if this will work on your car or not but I would recommend checking out a Subaru forum like NASIOC as I find they usually have some sort of wheel fitment thread that will tell you what will work for your specific platform.
                                                Another thing you need to check is the center bore. It must be at least the same size as the factory wheels or bigger.
                                                  September 11, 2016, 09:27 PM #24
                                                  Centerbore: 56.1mm
                                                  Offset: +55mm
                                                  Tire: 245/40R18
                                                  18x8
                                                  +35 offset
                                                  Please advise.
                                                  Thanks!
                                                  14mm closer to the fender. That's about a pinky width, so well within acceptable for just about any stock vehicle. Keep in mind though that if you have a tire that bulges a bit past the wheel rim, you need to consider that in your fitment.
                                                  Last Edit: September 11, 2016, 09:30 PM by firelizard
                                                    « Reply #24 on: September 11, 2016, 09:27 PM »
