Author Topic: FS: Fidanza 2JZ-GE Lightweight Flywheel + Centerforce DF clutch $300.00  (Read 354 times)
October 01, 2016, 09:54 PM #0
Rx7rotary Offline
  • Vehicle: '85 RX-7 GSL-SE, '03 IS300
  • Rx7rotary has no influence.
Up for sale is a Fidanza aluminum flywheel and Centerforce dual friction clutch for 2JZ-GE. In good shape, seems like a decent amount of clutchplate left.
Im assuming this is Fidanza model #130301, which is a direct replacement for the dual mass flywheel in a stock IS300.
I believe it should fit any 2JZ-GE car as long as you use the IS300 slave cylinder pushrod (this is an assumption, as my IS300 has a Supra flywheel and clutch using a longer slave cylinder pushrod)
$300 Firm.
Thanks,
Alex
Shiftin gears, eatin cheeseburgers
    October 11, 2016, 12:12 PM #1
    Rx7rotary Offline
    Bump
      October 17, 2016, 09:12 PM #2
      Rx7rotary Offline
      Sold, please close
