Author Topic: S14 silvia speedo not working  (Read 669 times)
October 18, 2016, 08:17 PM #0
Smosis Offline
  • Real Name: Ryan Grantham
  • Vehicle: 09 Lancer se
  • Smosis has no influence.
So i just got my silvia and the speedo works sometimes and not others, im new to the whole schassis world and would like some help figuring out whats wrong.
    « on: October 18, 2016, 08:17 PM »
    October 18, 2016, 10:05 PM #1
    Check for any loose connections and your speed sensor cable on the tranny
      October 19, 2016, 08:46 AM #2
      Smosis Offline
      Alright i was assuming it might be a bad ground or a wire as theres a bit of a ratsnest of wires at my feet from where the previous owner wired in something that i dont know what it does
        October 19, 2016, 09:15 AM #3
        As mentioned check the connection to the speed sensor first, then the connections on the back of the cluster and if those fail bring the cluster to my dad's shop in town (Mr Whizard) to see if he can find anything wrong with it.
          October 20, 2016, 10:24 AM #4
          Smosis Offline
          Alright thank you!
            October 20, 2016, 11:34 PM #5
            Can your dad calibrate speedos? Example, changing tire size will cause a percentage of change in relation to the speed shown, acutal 108km/h instead of 100km/h... or the speedo is magically out.
              November 01, 2016, 01:45 PM #6
              Doubt it
                « Reply #6 on: November 01, 2016, 01:45 PM »
