Author Topic: FS: All sold!  (Read 348 times)
October 26, 2016, 11:14 AM #0
4U2Envy Offline
  • Vehicle: 2007 Subaru Legacy Spec.B
  • 4U2Envy has no influence.
Hey TTI. The girlfriend has ordered me to clean out the garage so I've got a few things to sell. When these parts were taken off the car back in august, the mileage was 125,000KMS. I only have pics from when I did the install, I'll grab more pics when I get home.
VF46 turbo SOLD- I ended up swapping turbos this summer because I was craving more power. This unit was building boost just fine, no fin damage and car was meticulously maintained(OC every 4,000 kms/Rotella T6). I needed to harvest the coolant and oil return line for the new turbo so those would not be included.
*The bolt that holds the coolant line just underneath the wastegate snapped off(as pictured) when I tried to remove it. It's not an issues as the banjo bolt that connects it to the turbo holds it firm in place*
*Broken bolt has been removed*
Video showing no shaft play -
Video showing blades spinning -
OEM LGT/STI 565cc injectors SOLD- Not too much to say about these injectors, bigger turbo needs bigger injectors so these had to be swapped out. I ran Seafoam through the tank every 3 months to keep these clean, no issues with them.
Last Edit: November 14, 2016, 03:34 PM by 4U2Envy
"If everything seems under control, you're just not going fast enough"
324WHP/313WTQ EvoIII 16G on 94Oct - Bren Tuning
    FS: All sold!
    « on: October 26, 2016, 11:14 AM »
    October 27, 2016, 08:08 AM #1
    4U2Envy Offline
      November 03, 2016, 08:36 AM #2
      4U2Envy Offline
      Was able to remove the broken bolt without damaging the threads.
        FS: Used VF46 tubro and OEM inectors
        « Reply #2 on: November 03, 2016, 08:36 AM »
