Author Topic: The photogs car  (Read 2218 times)
November 04, 2016, 12:47 AM #0
Ahi Offline
  • Real Name: John Ahi
  • Vehicle: 99 civic sir
  • Reputation Power: 20
  • Ahi barely matters.Ahi barely matters.
*I just wanna start of by saying this is gonna be a big learning experience for me. I'm finally gonna step away from behind the lens and learn me some stuff about cars so bear with me on this*
So i finally ditched my pos sunfire and picked up a 99 sir.  :banana:
0011 by John Ahi, on Flickr
- Its a b16 head/b20 block swap (frankenstein swap?)
- Lowered on eibach springs but it rubs like crazy at the front so i have a set of tein coils to put in to raise it up a bit.
- Aem intake and fuel rail
- Full Megan catback exhaust with 4-1 headers
- Basette steelies
Has some minor rust on the rear quarters and passenger door, and burns a bit of oil.
I really have no idea what i want to do with this car right now but im sure it'll change and i'll be sure to keep this updated!
so far on my todo list is:
- put coils in and raise the car a bit (put the fronts in and raised it)
- get it saftied
0006 by John Ahi, on Flickr
Last Edit: December 13, 2016, 04:09 PM by Ahi
    The photogs car
    « on: November 04, 2016, 12:47 AM »
    November 04, 2016, 08:36 AM #1
    Congrats on ur first not sunfire car!
    Do you know what ECU it's running, or if it's tuned?
      November 04, 2016, 09:00 AM #2
      Nirusan Offline
      • Reputation Power: 217
      Congrats on the purchase!
        November 04, 2016, 11:23 AM #3
        In5updoots
          November 04, 2016, 01:13 PM #4
          Ahi Offline
          It's a chipped ecu, has 2 step and launch control.
            November 05, 2016, 02:57 AM #5
            Ahi Offline
            Little update:
            -Fixed my window so now it's all the way up, but i think the motors are dicked so im just not gonna touch my windows all winter (rip drive thus)
            -Changed the wheel setup a bit also. took the basette steelies off and put the wheel i had on the rear at the front and put my winters on my rear so i don't need to worry about the coilovers now. (will put winters on the front soon)
            -Found out i need a new alternator belt, driver side lower ball join and a battery tie down so gonna go pick those up tomorrow.
              November 06, 2016, 02:11 AM #6
              Ahi Offline
              - Changed the alternator belt
              - realized that the ball joint was just loose so put it back into place and added the pin so it should be good now  (this also lifted the front end so now the car sits more even)
              - cleaned up the corrosion on the battery and added the tie down
              - also had a burnt out tail light so changed the bulb
              on my way home tonight tho i took another look at my balljoint and it looked a little dicked
              This is before i fixed it
              14963711_1294838663899723_1159075673_o by John Ahi, on Flickr
              and this was when i just checked it out. Can anyone help me out if it should be replaced or if it's all good. Idk if the metal above it should be there.
              14971642_1294838620566394_516218557_o by John Ahi, on Flickr
                November 06, 2016, 08:10 AM #7
                It's good preventative maintenance to change your ball joints anyways cause you definitely don't want those going on you.
                  November 06, 2016, 10:32 AM #8
                  Imprzme Offline
                  • Vehicle: '16 Legacy 3.6R
                  • Imprzme barely matters.Imprzme barely matters.
                  That looks to me like whoever last did the balljoint never tightened it correctly. Hopefully it hasn't damaged/enlarged the hole in the control arm from the extra movement. I'd try tightening it first :)
                  Save your breath - you'll need it to inflate your girlfriend
                    November 06, 2016, 10:59 AM #9
                    Ahi Offline
                    yea it was really loose and there was no cotter pin, so ended up tightening it and then added a pin.
                      November 06, 2016, 01:35 PM #10
                      Imprzme Offline
                      Is the last pic after you tightened it?  If so it's not tight enough. That shiny part of the metal showing above the arm shouldn't be.
                        November 17, 2016, 04:51 PM #11
                        Ahi Offline
                        HUGE UPDATE:
                        i changed my shift boot from white to black
                          November 17, 2016, 04:57 PM #12
                          December 13, 2016, 03:38 PM #13
                          Ahi Offline
                          cars safetied finally ayyyyy
                            January 24, 2017, 08:30 PM #14
                            Ahi Offline
                            Been a not so fun start to the year. The civ decided to get a nice lil rod knock so gonna end up swapping my whole engine out. Luckily i found a nice B16/B20 again for a decent price thats pretty mint and will be a nice upgrade
                            16326309_1385617544821834_1819906505_o by John Ahi, on Flickr
                            Has arp headstuds and is generally really clean.
                            Been told it dyno'd at 187whp but can't always take a word so gonna maybe do one myself and see what im working with.
                            Future plans may be to turbo it but main priority is to get my car back running so i can have my bbg back
                            oh yea i also added some yonaka recaro rep seats because why not
                              January 24, 2017, 10:41 PM #15
                              fc3sxe Offline
                              • Vehicle: 1986 Mazda RX-7
                              • fc3sxe has no influence.
                              Aieee lookin forward to how this turns out, more fire photgraphy plz
                                February 06, 2017, 12:56 AM #16
                                Ahi Offline
                                Over the weekend me and a few friends manage to drop the engine and completely cleaned my bay and transmission that was just caked with oil. hopefully by next week i'll have the new engine in and the car running, have a few minor parts to pick up, main thing is i need a new fuel regulator for my fuel rail. i'll post more pics later. My old head is still mint, and the block is actually really clean so i'm just thinking my old setup will just need new rods and stuff.
                                Untitled by John Ahi, on Flickr
                                Last Edit: March 03, 2017, 12:42 PM by Ahi
                                  February 22, 2017, 12:07 PM #17
                                  Ahi Offline
                                  alright im pretty lazy when it comes to adding photos but after getting the motor in and then trouble shooting for a week on and off trying to get the car to start and buying new spark plugs and ignition wires, we replaced my dizzy with my backup dizzy i had and she runs mint. turns out the tooth on my other dizzy just broke off. so now i have a running car again :)))))))))))))))))))))))))
                                  Here's how the bay looks now
                                    February 22, 2017, 12:54 PM #18
                                    right on thumbs up for learning
                                      March 02, 2017, 06:31 PM #19
                                      Ahi Offline
                                      Trying to iron out some problems that happened with the swap, my car does not like to start in the cold, cranks alot and will idle at 500 then die, does that about 5 times  then it will hold a low idle until it warms up. and then another problem i ran into is sometimes when i press the gas it bogs out, sputters and backfires. i replaced my tps, map and iac valve, i think i narrowed it down to a bad 02 sensor or i might need a re tune. for the starting up in cold idk if i'll need to deal with it or maybe buy a new distributor (spark plugs and ignition wires are brand new). also put new coils in my rear so the car sits on tein coils all around, i put my white trunk back on and bought some 15x8 volk ce 28 reps.
                                      Last Edit: March 03, 2017, 12:40 PM by Ahi
                                        March 03, 2017, 12:43 PM #20
                                        Ahi Offline
                                        *updated with photos*
                                          April 14, 2017, 11:11 PM #21
                                          Ahi Offline
                                          (sometime mid april)
                                          Fixed my running lean issue by changing my ignition wires because my cylinder 1 wire was broken.
                                          I thought it was my distributor so i bought one off of ebay and installed it, then a day later broke down while on bishop so that was fun.
                                          Got a ticket for my car being too low so gonna be in the process of raising that.
                                          But some more issues with the car.
                                          Turns out when doing my rear coils the head of one of my bolts for the LCA broke and well long story short while driving on the perimeter my lca decided to fall off. No damage to the car, just a stressful afternoon, and the other day my short shifter broke. I guess my car had a cheap ebay one in it. so gonna fix those 2 things then the civic will be for sale
                                            April 15, 2017, 12:50 PM #22
                                            What you going to buy?
                                              April 27, 2017, 12:51 AM #23
                                              Ahi Offline
                                              I have my eyes on a 99 legacy wagon or a 99 4runner. Want something reliable to roadtrip and camp in.
                                                June 13, 2017, 06:42 PM #24
                                                Ahi Offline
                                                traded my civic for a 96 jeep cheroke so maybe ill make a thread on that in the future
                                                  The photogs car
                                                  « Reply #24 on: June 13, 2017, 06:42 PM »
