Author Topic: custom splitter  (Read 889 times)
November 23, 2016, 09:06 PM #0
mhubeny180sx Offline
  • Vehicle: 180sx
  • Reputation Power: 12
  • mhubeny180sx has no influence.
Been wanting to try my skills at making a custom splitter, but having a hard time finding where to buy a nice piece of styrofoam for the core of the splitter, that is hard, can be sanded, comes in 3/8 - 1/2 inch thick and in a big enough sheet to make what I want. Anyone have any experience with doing something like this, and where I could get some??
    custom splitter
    « on: November 23, 2016, 09:06 PM »
    November 24, 2016, 12:48 AM #1
    Not too sure if this would work.. but home depot sells "styrospan" (iirc that's it's name), it's a styrofoam insulation panel, I think it comes in 16" x 72" sheets. Not too sure of thickness
    Edit - just tried searching for it on their site..nothing came up. I'll look tomorrow when I'm not half asleep.
    Last Edit: November 24, 2016, 12:52 AM by Vince
      November 24, 2016, 07:26 AM #2
      Magner Offline
      • Vehicle: Neons
      3/8 plywood is what the majority of SCCA/NASA amateur racers use, cheap easy to work with, easy to replicate and stronger than most other options.
        November 24, 2016, 02:06 PM #3
        I'm not sure if Styrofoam will be stiff enough but you can go to home depot and find some extruded polystyrene  rigid insulation (pink/blue stuff). It's stiff enough and can be sanded/formed, however, you'll have to be careful with what materials you can use to seal it as some chemicals melt it.
          November 26, 2016, 12:11 AM #4
          heiyuu Offline
          • Vehicle: 06 Civic, 05 Frontier, 98 Integra, 93 180sx
          • Reputation Power: 35
          • heiyuu is working their way up.heiyuu is working their way up.heiyuu is working their way up.
          I recommend the carbon fiber
            December 20, 2016, 03:45 PM #5
            johnstonlucas5 Offline
            • johnstonlucas5 has no influence.
            U can use foam to make the shape the use fiberglass to make the product
            Sent from my One using Tapatalk
              December 20, 2016, 09:53 PM #6
              Plywood. Cheap and fairly light.
              Race cars use it.
                December 21, 2016, 08:27 AM #7
                That doesn't look like a "race car"
                  December 21, 2016, 08:13 PM #8
                  It's a track car. Even had tubular control and spherical rod ends.
                  Pretty common track car parts.
                    December 21, 2016, 09:04 PM #9
                    Magner Offline
                    • Vehicle: Neons
                    Well I can guarantee it's not meant to take home some car show awards, it's a function vs form type of thing.  :-\
                    Last Edit: December 22, 2016, 09:29 PM by Magner
                      December 22, 2016, 10:05 AM #10
                      • Vehicle: 180sx
                      Race cars use it.
                      mm nthx lol, dont want my car to look like I ran over pile of wood.
                        December 22, 2016, 02:30 PM #11
                        • Reputation Power: 110
                        Resin it and paint it black.
                          custom splitter
                          « Reply #11 on: December 22, 2016, 02:30 PM »
