Author Topic: FROSTI, Colins 01 fSTI  (Read 7221 times)
January 26, 2017, 11:33 AM #25
Here is a pic of the rear speakers.
20161225_164102 by Colin McAndrew, on Flickr
    Frosti? Colins 01 fSTI
    « Reply #25 on: January 26, 2017, 11:33 AM »
    January 26, 2017, 12:13 PM #26
    So to start my audio installation I spent a lot of time just looking at other installs I'd seen around and was having a lot of trouble finding something that was exactly the same as what I had in mind. So after many hours of research, I had compiled a bunch of photos of systems I liked the visual aspects of, and decided to take what I liked about each and make it in my own way.
    I wanted fairly flush mounted amps, slightly inset for their protection but still visible. And a single subwoofer also mounted semi flush, the surround will have to sit 1/8" above the floor level, but it looks pretty good that way.
    My plan was to make a flush trim ring that sits over the mounting flange of the subwoofer, covering the screws, so all you see is the surround and cone of the subwoofer. Then I would also make a secondary cover that is 3/4" taller that will act as a cap for the subwoofer in case I want to put goods in the back of the vehicle, for road trips for example. This will still allow the subwoofer to play at lower levels with out the risk of damage to the driver. The two rings will be fairly easy to interchange.
    I started by gutting my rear hatch area, figure out what kind of depth I had to work with and how large on an enclosure I could build while trying to keep it at the same original floor height.
    20161222_184019 by Colin McAndrew, on Flickr
    20161222_184027 by Colin McAndrew, on Flickr
    20161222_185343 by Colin McAndrew, on Flickr
    The car still had the old TV antennas from the original JDM head unit, so I removed all that stuff while cleaning out the trunk area. It looked like I had a pretty solid work space to use, depth to the original floor from the bottom of the spare tire well was around 9.25" would would leave me with plenty of mounting depth for my subwoofer and enough height to make a box with a volume perfect for my subwoofer.
    20161222_191351 by Colin McAndrew, on Flickr
      January 26, 2017, 12:21 PM #27
      Next step was determining how I would lay out my components. It was pretty obvious that the sub would have to go in the spare tire well, since its the only place with enough dept, and its very close to the center of the trunk.
      I wanted the amps to go above the subwoofer, near the rear seat, had to find a suitable mounting height so I testing some idea with scraps around my garage.
      20161222_193502 by Colin McAndrew, on Flickr
      20161222_194220 by Colin McAndrew, on Flickr
      20161222_194225 by Colin McAndrew, on Flickr
      I was liking the look of this layout, and it worked pretty well with the way the trunk floor is contoured, in the end they are sitting quite a bit further back though, since I decided to re-use the OEM side compartments, firstly because it makes install way more simple, they have bad ass compartments, and they set a nice level floor height for my final goal.
        January 26, 2017, 12:44 PM #28
        Next I had to determine a box shape that fit the floor, and would allow the sub to mount centered in the trunk. I played around with some cardboard till i had something I was satisfied with.
        Then I transferred the design to wood.
        20161226_211000 by Colin McAndrew, on Flickr
        20161229_193109 by Colin McAndrew, on Flickr
        20161229_194837 by Colin McAndrew, on Flickr
        20161229_201108 by Colin McAndrew, on Flickr
        20161229_203935 by Colin McAndrew, on Flickr
        20161229_212656 by Colin McAndrew, on Flickr
        20161229_212714 by Colin McAndrew, on Flickr
        This was the completed shape of the enclosure itself, the bulge on the left allows the subwoofer to be centered since the well itself is actually offset, and shaped quite oddly below.
          January 26, 2017, 12:51 PM #29
          Glued and stapled the box together, I always apply a second and if required third strip of glue onto the seems of the enclosure to ensure its air tight and strong.
          20161230_191705 by Colin McAndrew, on Flickr
          20161230_191916 by Colin McAndrew, on Flickr
          20161230_192454 by Colin McAndrew, on Flickr
          Once I put the sides back into the trunk I could really see it starting to come together, but I was still just getting started, I thought building the box would be the hard part, but it only took me a couple hours in the evening. Next was making it all fit the way I wanted.
          20161230_204908 by Colin McAndrew, on Flickr
          20170101_121456 by Colin McAndrew, on Flickr
          I actually ended up having to cut 1 1/4" off the top of the box because the volume was going to be too big (first time thats happened). Then I made the top of the box, and made it to fit perfectly in the original opening where the spare tire went, butting up tightly against the foam inserts. Fitment after taking the top off the box was almost exactly where it needed to be, with another layer of 3/4" on top, it came to just about flush with the original floor.
          20170101_122434 by Colin McAndrew, on Flickr
            January 26, 2017, 01:05 PM #30
            Next I made the cutout for the sub itself, how exciting  :banana:
            20170101_190157 by Colin McAndrew, on Flickr
            20170101_215345 by Colin McAndrew, on Flickr
            To make sure the lower enclosure and top cover wouldn't shift, I put 4 screws through the top, boy was that tricky to line up straight, but I screwed it up perfectly - that punny, you should laugh (insert fake laugh here).
            You may also notice the bracing inside the box, this was actually to reduce the volume even more, as my engineer father pointed out to me, it was still a bit big and one of my calculations was off... But its now the exact spec the subwoofer manufacturer calls for.
            So now the enclosure itself was basically finished, next I had to figure out the amp rack. Keeping in mind that my front speakers will be bi-amped, I will need separate speaker and tweeter wires run from the amp to the doors, so why not just put the crossovers in the back and show them off too.
            20170102_205038 by Colin McAndrew, on Flickr
            20170102_212548 by Colin McAndrew, on Flickr
            20170102_212258 by Colin McAndrew, on Flickr
            20170102_212302 by Colin McAndrew, on Flickr
            This is basically the layout I went with in the end, spacing is now a bit different but the layout is the same. I had quite a hard time deciding how to lay it all out though since the amps are different sizes, same height and length, but different widths. And I now also had to put the two crossovers in the mix, which had nothing in common with the amps except they were rectangles, I decided to just center them between the two amps.
            Last Edit: January 26, 2017, 01:08 PM by Ctown8
              January 26, 2017, 01:24 PM #31
              Took a break from the trunk and decided to play around with the bass knob that came with the subwoofer amplifier.
              I started by disassembling it and removing the required components, then found a suitable place to mount it where its accessible, and really really ridiculously good looking.
              20170102_214410 by Colin McAndrew, on Flickr
              20170102_214446 by Colin McAndrew, on Flickr
              20170102_214910 by Colin McAndrew, on Flickr
              20170102_221141 by Colin McAndrew, on Flickr
              20170102_222308 by Colin McAndrew, on Flickr
              20170102_224544 by Colin McAndrew, on Flickr
              20170102_225739 by Colin McAndrew, on Flickr
              Last Edit: January 26, 2017, 01:26 PM by Ctown8
                January 26, 2017, 01:40 PM #32
                I was now ready to glue the top of the enclosure down, it was only screwed in place up to this point, but I also had to add an mdf ring to give my screws/bolts more depth to bite, and slightly increase the strength of the top cover.
                20170118_182906 by Colin McAndrew, on Flickr
                20170118_184305 by Colin McAndrew, on Flickr
                So now I was back to working on the amp rack. I had to make  base that sat level in the trunk and was sturdy enough to hold the amps without moving around, and also at the right height.
                20170103_200507 by Colin McAndrew, on Flickr
                I used a combination of a few pieces of 5/8" mdf and some pedestals to give support in the tricky parts.
                  January 26, 2017, 02:00 PM #33
                  With the base made I was ready to start mounting the amps to it, and aligning them with a cover I was also in the process of building. I cut each item out one by one to ensure each fit perfectly. The crossovers I actually made the cut outs, then centered them in the openings and screwed them in place.
                  20170123_195524 by Colin McAndrew, on Flickr
                  20170123_195506 by Colin McAndrew, on Flickr
                  20170123_215330 by Colin McAndrew, on Flickr
                  20170123_215401 by Colin McAndrew, on Flickr
                  20170123_222503 by Colin McAndrew, on Flickr
                    January 26, 2017, 02:05 PM #34
                    The annoying moment when your blade breaks 1/8" before the end of your cut, AFTER you already finished the turned part of the cut...  :unamused:
                    20170123_224142 by Colin McAndrew, on Flickr
                    Thankfully I have many extra blades and finished the cut. Amps all laid out, I'm pretty happy with how it sits.
                    20170123_230229 by Colin McAndrew, on Flickr
                    20170123_230220 by Colin McAndrew, on Flickr
                    20170123_230238 by Colin McAndrew, on Flickr
                      January 26, 2017, 02:09 PM #35
                      Damn this looks really good.
                        January 26, 2017, 02:56 PM #36
                        Thank you sir!
                        Started last night by making the top most panel that caps the subwoofer, some minor trimming was required, but it fits like a glove that fits.
                        20170124_220908 by Colin McAndrew, on Flickr
                        20170124_221952 by Colin McAndrew, on Flickr
                        20170124_222734 by Colin McAndrew, on Flickr
                        20170124_223713 by Colin McAndrew, on Flickr
                        The cover fits perfectly and sits at the height I want. Now the tricky part, cutting out a hole in the floor blindly that has to line up with the hole below... I started by measuring with a square to get lines of where the hole ends on the top, sides and bottom. This will get me within 1/4", if done perfect it should get me on point, but I aint perfect, I know that. So I used a circle jig I made for my router and made 4 holes around the circle and then checked in the car to see if it lined up. I was off by 1/4" down, and 1/16" to the left. So I re-aligned my jig and repeated making 4 more holes. This time it was perfect.
                        20170124_225715 by Colin McAndrew, on Flickr
                        20170124_230541 by Colin McAndrew, on Flickr
                        20170124_230944 by Colin McAndrew, on Flickr
                        received_1607102325970009 by Colin McAndrew, on Flickr
                        I then made some more measurements and cut out the circle.
                        Last Edit: January 26, 2017, 03:03 PM by Ctown8
                          January 26, 2017, 03:08 PM #37
                          I made the circle about 1.5" larger than the surround on the subwoofer, because of the cover I was planning on making next.
                          20170125_210611 by Colin McAndrew, on Flickr
                          20170125_210726 by Colin McAndrew, on Flickr
                          20170125_213123 by Colin McAndrew, on Flickr
                          I made the ring by cutting one circle to 1/4" smaller than the outer edge; to make room for fabric, then cut a smaller circle in that disc to the size of the surround on the subwoofer.
                          20170125_215548 by Colin McAndrew, on Flickr
                          20170125_223351 by Colin McAndrew, on Flickr
                          20170125_225156 by Colin McAndrew, on Flickr
                          Trimming the inside of the ring to make room for the mounting surface of the subwoofer proved very difficult, since I didn't, and still don't, have a trim bit large enough to take off 3/4" of material, mine can only do about 3/8". So I improvised, made a jig, nearly cut my hand off, made a new jig, and it worked perfectly! Which left me with the perfect fitting ring seen above.
                            January 26, 2017, 03:11 PM #38
                            It wasn't easy to get it right, but with careful measure (measure twice cut three times because you can always remove material and fingers, but its much harder to put them back on..)
                            it all lined up how I wanted. And I made a huge mess :lol:
                            20170125_225400 by Colin McAndrew, on Flickr
                            received_1607213425958899 by Colin McAndrew, on Flickr
                            received_1607212939292281 by Colin McAndrew, on Flickr
                            Next will be perfecting fitment, wiring, and carpeting everything, I also still have to make a second ring that will also cover the subwoofer. That is the plan for this weekend though. Updates incoming soon.
                              January 26, 2017, 03:21 PM #39
                              • Reputation Power: 93
                              daaaaang thats epic.
                                January 27, 2017, 10:06 PM #40
                                Holy ****. Want2build My system. That is gorgeous. Great work!
                                  January 28, 2017, 09:28 AM #41
                                  Thanks guys, and I can help both of you with your systems :)
                                    January 28, 2017, 03:49 PM #42
                                    Lets see what I get!
                                    2017-01-28_03-45-36 by Colin McAndrew, on Flickr
                                      January 29, 2017, 10:46 AM #43
                                      Awesome work on the enclosure!
                                        January 31, 2017, 09:31 AM #44
                                        Picked up some new wheels last night, was gonna get a new o2 sensor finally, but part source sold it before I got there...
                                        Heres the wheels though: Rays Gram Lights 57c6 in 18x8.5 et35 with Hankook Ventus v12 EVO
                                        FB_IMG_1485813942775 by Colin McAndrew, on Flickr
                                        FB_IMG_1485813938153 by Colin McAndrew, on Flickr
                                        2017-01-30_04-08-12 by Colin McAndrew, on Flickr
                                          January 31, 2017, 10:18 AM #45
                                          Started on some of the finishing touches for the amp rack, the farthest back panel will join the seats and the amp cover, and also hide all the wiring.
                                          20170130_202916 by Colin McAndrew, on Flickr
                                          20170130_202926 by Colin McAndrew, on Flickr
                                          The angle of the panel is the exact same angle as the maximum recline on the rear seats, this way there is no gap when the seats are folded down.
                                          I also rounded the opening where the amps and crossovers will be visible, and raised the panel abour 1/8" above the faces of the amps to keep them safe.
                                          20170130_205819 by Colin McAndrew, on Flickr
                                          20170130_205822 by Colin McAndrew, on Flickr
                                          20170130_211019 by Colin McAndrew, on Flickr
                                          20170130_212152 by Colin McAndrew, on Flickr
                                          I also made the second cover ring, this time I angled the edge at a 45 instead of rounded, I think it looks sharp. Hopefully be able to start carpeting and wrapping tonight.
                                          20170130_224441 by Colin McAndrew, on Flickr
                                            January 31, 2017, 10:54 AM #46
                                            February 01, 2017, 10:35 AM #47
                                            Spent most of last night sanding and trimming panels to ensure proper fitment after applying fabrics, all pieces now fit perfectly, and I have wrapped the main cover panel with black carpet, the other two side panels, amp rack, and the trim ring around the sub will all be black suede.
                                            Due to the height gap between the amp rack and enclosure baffle, I put a 45 on the edge of the amp rack to make the transition smooth.
                                            20170131_204139 by Colin McAndrew, on Flickr
                                            20170131_212211 by Colin McAndrew, on Flickr
                                            20170131_213700 by Colin McAndrew, on Flickr
                                              February 01, 2017, 11:00 AM #48
                                              Shier Offline
                                              • Real Name: Greg
                                              • Reputation Power: 56
                                              damn man, looks great
                                                February 02, 2017, 10:11 AM #49
                                                Did some more work on the wiring last night, still waiting to receive a roll of pure copper 4awg before I can power up the speaker amp, but I made my speaker wire connections at least. Running bi-amped so two pairs of speaker wires per crossover. theres Currently 40ft of speaker wire under the rear seat waiting to be ran into the doors and dash.
                                                20170201_194401 by Colin McAndrew, on Flickr
                                                20170201_195258 by Colin McAndrew, on Flickr
                                                20170201_202839 by Colin McAndrew, on Flickr
                                                Got bored since I cant hook up the speakers anyway, so I did a bit more wrapping with suede, did the ring around the sub, ran out of glue and couldn't do the amp cover unfortunately.
                                                20170201_212322 by Colin McAndrew, on Flickr
                                                20170201_214218 by Colin McAndrew, on Flickr
                                                20170201_215149 by Colin McAndrew, on Flickr
                                                20170201_215207 by Colin McAndrew, on Flickr
                                                I think it looks pretty slick in all black with the yellow sub popping out in the center. I might have to add some leds under the amp cover just to give it a bit of a glow. Problem is the amp power light is blue, and pretty bright, so I would either have to cover it, or mask it. Since blue wouldn't go with my current color scheme. White or pink are about the only colors I'd want to do, maybe a yellow/gold to go with the other accents around the car, and the Kevlar covers I'll be getting made from Mike @ 204carbon.
                                                Speaking of Kevlar, maybe I could do an overlay, or dip the sub ring in Kevlar, but that might be too much Kevlar in one place.
                                                  « Reply #49 on: February 02, 2017, 10:11 AM »
