Author Topic: Jamie's STI Rebuild  (Read 1844 times)
February 09, 2017, 01:23 PM #0
jamie_hearts_subarus Offline
  • Real Name: Jamie Banman
  • Vehicle: 2004 WRX STI
  • jamie_hearts_subarus has no influence.
So, Looks like she has come down with a case of the broken. lol
At the end of this past summer we were noticing a lack of power and a substantial use of oil. Rodney the lovely mechanic he is, had a theory of the head gasket leaking...
well... he was right. So, with the help of Dylan Hesom, we pulled the motor, (which was surprisingly easy apparently), tore her down, and found more problems...
Not only is the head gasket leaking, but so is the power steering pump, the turbo wastegate is cracked (unfortunately not a small one either), one of the past owners ran her filter less for an unknown amount of time and the fins in the turbo are completely dull and chewed up. And we pulled the clutch to see what condition it was in, and good timing, it was almost done too.
Then, on top of that, the case bolts would not loosen for the life of us! (yes, we tried an impact, & 3 different length breaker bars, ended up snapping a reducer lol, with the 3rd breaker bar they finally broke loose with me holding the entire side of the engine stand down with all my weight and Rodney pressing the bar with all his weight lol.)
Will post updates as they come
    Jamie's STI Rebuild
    « on: February 09, 2017, 01:23 PM »
    February 09, 2017, 01:31 PM #1
    So, we have her completely stripped down, found out which head gasket was doing the leaking and there was oil in the same piston so we're assuming a ringland is shot in that one too.
    One of the timing belt idlers sound done aswell, so we're just gonna do a whole new timing belt kit on her & just start fresh, one of the pistons had wear in the channel so it sounds like we're going to send the block over to Justin & a buddy of his @ Nemisis Tuning to take car of the machining and upsize the pistons for us!
    :zpin:
      February 09, 2017, 02:28 PM #2
      Looks like you've got your work cut out for you! Are you planning on getting a bigger turbo while you're at it?
        February 09, 2017, 02:56 PM #3
        haha yeah she's gonna take a bit to do it all, most likely but not entirely sure honestly lol
          February 09, 2017, 03:06 PM #4
          That's unfortunate but now you can build it better! What are your build plans?
            February 09, 2017, 05:53 PM #5
            Nirusan Offline
            • Reputation Power: 217
            Ooof! Better to catch all the issues now though then later down the road! I have the same question as Igor, any idea on the build plans?
            I look forward to seeing future updates :)
              February 10, 2017, 01:25 PM #6
              Please report back with how much this build is going to cost you. Best of luck.
                February 10, 2017, 01:30 PM #7
                Not entirely sure yet what the whole plan is upgrading wise, ill keep you all posted :)
                Supposed to cost Between 3 - 5 thou, depending on what we all want to upgrade, Plus i get some items discounted through work so that helps :P
                  February 15, 2017, 10:47 PM #8
                  Continuing to strip her down, time to pull the pistons and split the block! Sending her off to Nemisis soon! :)
                    March 03, 2017, 11:02 AM #9
                    So! We brought her to Justin @ Nemisis this past weekend& Parts are starting to come in! :) :zpin:
                      March 03, 2017, 11:48 AM #10
                      Oh boy how exciting! Any idea what the estimated completion date is?
                        March 03, 2017, 11:55 AM #11
                        Unfortunately no exact date at the moment, hoping to be done by May tho
                          March 03, 2017, 12:40 PM #12
                          Awesome, Im excited to see some updates on this for sure.
                            March 11, 2017, 08:22 PM #13
                            Stone Offline
                            • Real Name: Dean
                            • Vehicle: 2004 Subaru WRX
                            • Stone has no influence.
                            How many kms were on it when it went? And how long has it been modified for?
                              March 13, 2017, 04:22 PM #14
                              Under 200,000km, it didnt actually blow, we just saw the warnings & decided to act now before it did lol
                              Its been modified for a few years alread. Dont know exact dates of things that were done by previous owners
                              Last Edit: March 14, 2017, 10:30 AM by jamie_hearts_subarus
                                March 14, 2017, 12:36 PM #15
                                My last gaskets came in! :D
                                  April 11, 2017, 04:30 PM #16
                                  So the motor should be done in the next week or so :) Pretty pumped to get her all back together, and here's my new clutch! :)
                                    April 18, 2017, 10:26 AM #17
                                    So, a bit of delay waiting on a few more parts, but hoping she'll be ready to go for Beginning of May :)
                                      April 18, 2017, 10:54 AM #18
                                      How does the block look? No scoring in the cylinders? Are you sticking with oem sized pistons?
                                        April 18, 2017, 11:03 AM #19
                                        It was in rough shape, it's a good thing we ripped her apart when we did,  there was scoring in the cylinders, a valve was bent, and yes the pistons are being upsized
                                          May 30, 2017, 03:44 PM #20
                                          We pick up the motor this week!!!
                                            May 31, 2017, 11:56 PM #21
                                            TeamSX4 Offline
                                            • Real Name: Matt Wall
                                            • TeamSX4 has no influence.
                                            Right on! Can't wait to see her out on the street again
                                              June 23, 2017, 12:17 PM #22
                                              SO! the motor went in smoothly! everything runs beautifly (except a small vacuum leak), and the break in time is almost over! but it's soo nice to have her out again :) :banana:
                                                June 23, 2017, 02:05 PM #23
                                                That's great news. I take it Justin is going to tune it for more power after?
                                                  June 23, 2017, 02:25 PM #24
                                                  He did tune it for me, yeah
                                                    Jamie's STI Rebuild
                                                    « Reply #24 on: June 23, 2017, 02:25 PM »
