Author Topic: 95 impreza jdm vehicle speed sensor  (Read 228 times)
March 11, 2017, 05:23 PM #0
AXeHound Offline
  • Vehicle: 95 subaru impreza wrx sti type RA
  • AXeHound has no influence.
Im looking for some help clearing error code 33(vehicle speed sensor) but i cant seem to find the correct part online.
so my question is does any one know the part number or a local retailer that sells this part. im totally locked out at 4500 rpm :(.
 if any one has any info on this i would really appreciate it thanks.
    « on: March 11, 2017, 05:23 PM »
    March 12, 2017, 12:25 AM #1
    awd_ftw Offline
    • awd_ftw has no influence.
    Is your speedometer working or acting strange? Is it a cable, 2 wire, or 3 wire sensor? It's located on the right side of the transmission behind the dip stick.
    If its the 2 or 3 wire sensor I would check the ground.
    The usdm cable part that goes to the tranny is 737411752. I'm not %100 sure if it will work with the JDM. You could always remove it and compare. Could be the sensor behind the speedo (if not working correctly).
    Last Edit: March 12, 2017, 12:58 AM by awd_ftw
      March 12, 2017, 12:26 AM #2
      awd_ftw Offline
      dbl post  <:
        March 12, 2017, 09:18 AM #3
        AXeHound Offline
        thanks for the reply. the speedo seems to be working fine. i have not had the chance to get the car off the ground to locate the part in question to see of its mechanical or digital
          March 13, 2017, 09:08 AM #4
          Have you always had this code or did it just pop up?
            « Reply #4 on: March 13, 2017, 09:08 AM »
