Author Topic: 2001 Subaru Forester STI rear hub question  (Read 421 times)
May 01, 2017, 03:41 PM #0
PK-FXT Offline
  • Real Name: Peter
  • Vehicle: 01 FSTi 2009 FXT
  • PK-FXT has no influence.
As the title states, 01 STI forester with the 4/2 brakes. Sounds like one of or both of my wheel bearings are in the early stages of wearing out.
Tough to find information on compatibility but are they the same as a regular USDM forester or possibly WRX?
Hopefully someone has some information to guide me into finding a place to buy.
    « on: May 01, 2017, 03:41 PM »
    May 01, 2017, 04:52 PM #1
    Unger08 Offline
    • Unger08 has no influence.
    They are the same as a 02 USDM WRX. I did mine not to long ago
      May 01, 2017, 08:10 PM #2
      PK-FXT Offline
      • Real Name: Peter
      Awesome thanks. Took apart the rear today. Looks like my caliper is actually partially seized. Going to replace the caliper. Since it's the 1 piston rear caliper it should be the same as a USDM forester
        May 02, 2017, 05:14 PM #3
        @dano  is this correct?    What year impreza should this be from?
          May 02, 2017, 07:13 PM #4
          PK-FXT Offline
          • Real Name: Peter
          So I can confirm that the udsm rear caliper is NOT compatible, the gap from the piston face to the other side of the caliper on the JDM is 2", and the USDM is 1.75".
          I can't seem to find any information online that says what USDM caliper is the same as the JDM one. I thought it might be the same as a WRX or possibly a Legacy GT I have CTR bringing in some different calipers to compare.
          If anyone knows what is a compatable replacement that would be great. I bet it would be hard to source a reman jdm caliper.
          EDIT.  https://forums.nasioc.com/forums/showthread.php?t=916507
          According to this since I have a 10.5" diameter vented rotor with single piston caliper that a USDM Legacy GT should work.
          Last Edit: May 02, 2017, 07:53 PM by PK-FXT
            May 02, 2017, 09:21 PM #5
            Most engine parts are similar to the 2002 WRX. Most 02-07 WRX suspension parts fit gc8/gf8/sf5. But you learn something new every day.
              « Reply #5 on: May 02, 2017, 09:21 PM »
