Author Topic: Want to borrow: Rotary compression tester  (Read 152 times)
May 10, 2017, 12:58 PM #0
johnny Offline
  • johnny has no influence.
Hey looking for borrow a rotary compression tester for this weekend, driving out of town to check out a car. Would make it worth your while of course.
    « on: May 10, 2017, 12:58 PM »
    May 11, 2017, 09:16 AM #1
    Time Lord Offline
    • Real Name: John Jackson
    • Vehicle: Audi
    • Time Lord has no influence.
    Use a regular compression tester with the schrader valve removed. Won't be precise, but should give you 3 regular pules of pressure per rotor per revolution. Two high , one low is a failed rotor tip seal.
    Don't loose the valve - it's not the same as a tire valve.
      May 12, 2017, 06:43 AM #2
      johnny Offline
      Yeah that was the plan if I couldn't get a hold of one.. picked one up at princess auto, although it doesn't seem that there is a removable valve on it. I'm hoping I can just hold the pressure release button as I am testing and it will have the same effect?
        « Reply #2 on: May 12, 2017, 06:43 AM »
