Author Topic: Intermittent Stalling on warm starts.  (Read 1657 times)
June 07, 2017, 07:42 AM #25
@jordisonjr use an impact hammer bit like in this picture
http://i.ebayimg.com/thumbs/images/g/IXAAAOSwE0JY~6e7/s-l225.jpg
If you require help let me know.   I can pull them out for you.
    « Reply #25 on: June 07, 2017, 07:42 AM »
    June 07, 2017, 09:02 AM #26
    Thanks @dan
    I ended up soaking it with PB blaster 3 times, and then used a phillips socket on a ratchet and that cracked it fairly easily. The PB soaking must have really helped because with just a screwdriver the screw head was starting to warp. Not even strip but the entire X pattern was twisting.
    I'm going to cop[y this question from what I posted on a celica Forum incase anyone here knows, as there seems to be more activity here. But this might be Toyota/Celica specific.
    Now when it comes to cleaning the IACV, I was reading on a ToyotaNation thread, to remove the electrical plug, and the you will then be able to rotate the valve to completely clean the inside. There seems to be a gooey gum-leak sealant between the plug and the valve itself
    You can kind of see it oozing out between the connection here. Anyone know what type of sealant this is? I'd like to be able to re-assemble this after cleaning correctly to avoid issues.
    Or would the better option be to go from the opposite end, remove the end cap, and clean from this side:
      June 07, 2017, 09:20 AM #27
      not sure what kind of sealant that is, but iirc you cant do much from the cap end, its basically a guide for the pin to rotate on, the motor end would be easier to turn, but mine was held on with 5pt torx.
        June 07, 2017, 09:49 AM #28
        Hmm interesting. The sealant was pretty sticky. I don't want to pull it apart and have it not seal properly and have more issues than originally. Maybe Ill just stuff pipe cleaners in it and clean it as best as possible. It wasn't as carbon'd up as I had expected.
        Any chance I can grab some screws from you at some point tonight?
          June 07, 2017, 12:04 PM #29
          theyre at my house out in the middle of no where, I can bring them to work with me tomorrow if that works.
            June 07, 2017, 02:22 PM #30
            I didn't realize you lived in the boonies :lol:
            What time you there till? I could prob get there around 5 ish, if that works?
              June 14, 2017, 08:32 AM #31
              Finally got it all cleaned up and back together. Had to wait over the weekend for IACV gasket and TB gasket to come in to Toyota.
              Drove it for about a hour last night and it seems to run smoothly. However, got home let it sit for about 15-20 min. Engine was still warm, but not right at operating temp (middle of the temp gauge) and sure enough, it wouldn't start. Just cranked and cranked almost as if there was no fuel. About 10 min later of sitting, it did start up after giving it some throttle. Used the throttle to hold it idle for 10-15 seconds, and then it idled normal, as it should.
              Next up is to change the coolant temp sensor I suppose, as others have recommended on another forum
                June 14, 2017, 12:10 PM #32
                I was just gonna say coolant temp sensor is the next place id look.
                  June 14, 2017, 12:29 PM #33
                  That's what a couple people on 6gc recommended. Also I wasn't able to get a very accurate resistance reading on the sensor. Whether that's because it's not functioning properly, or because I was doing something wrong, I'm not sure. But my guess (and hope) is that that is the culprit.
                    July 11, 2017, 08:34 AM #34
                    Well I managed t replace the coolant temp sensor, and have been driving the car a few times a week.
                    I'm fairly confident that the issue has been solved.
                    I've gone on a couple long drives 1 hour - 2 hours, with a couple 10-15 minute breaks in between. This is usually when the car would have the most trouble, when it has had a chance to cool down a bit, but was still warm. And so far I haven't had any issues.
                    There was one instance right after changing it where the car had a bit of a rough idle upon starting, however I didn't need to use any throttle to get it to run, but a bit of throttle smoothed out the idle. This has been the only issue that's come up, and it was only once.
                    I'm not 100% convinced yet, that it's completely solved as i don't want to get my hopes up, but it seems to have solved the issue.
                      July 11, 2017, 09:46 AM #35
                      Woo, fingers crossed you got it nailed!
                        « Reply #35 on: July 11, 2017, 09:46 AM »
