Author Topic: FS: 06-13 XTD Stage 3 Clutch with Fly Wheel  (Read 80 times)
July 10, 2017, 01:57 PM #0
rbotz Offline
  • Vehicle: 06 Subaru WRX
  • rbotz has no influence.
I have a brand new still in box XTD Stage 3 Clutch with Flywheel i was going to install into my WRX, Had my WRX Written off this weekend.
Its an ebay special they are currently listing on ebay for $330CDN +Shipping, Willing to sell it for $300 Flat, Im located in Weston Area.
The specs of the clutch as follows
XTD 6 puck "MIBA" Copper Ceramic clutch is designed for the serious enthusiast with just Stock to considerable modifications.("Miba" Copper Ceramic Material is well known for AirCraft brake material.It is more Durable and hold 60% more Torque capacity than Cabontic or Kevlar Material also "MIBA" Disc grips 30% harder than Cabontic Disc) This disc features 12 high-coefficient ceramic pads for quick engagement and the extreme duty friction needed. Our specifically designed high torque disc delivers maximum holding capacity without compromise. The sprung retainer assembly boasts 6 dual springs and 6 severe duty retainer rivets, ensuring power and reliability.This XTD Stage 3 Clutch Kit Includes XTD High Clamp Long Life Pressure plate,XTD "MIBA" 6 Puck Copper Ceramic Disc,throw out Bearing, Alignment Tool,13.5lbs lighten Flywheel,XTD Clutch Installation Guide & XTD Logo Window Decal.This XTD Pressure plate Holds 30% more HP and Torque Than Stock Pressure Plate and This Pressure plate is made from ductile iron and heat Treated Which is about 20 % Stronger Than Just Stock Cast Iron Pressure plate. XTD Stage 3 Copper Ceramic Disc is designed for Ultra Racing Purpose and it Graps much harder than Carbontic or Kevlar disc also It will Increased Acceleration.However,It designed also Smooth Engagement and improved durability for Street so It won't make you difficulty on Daily Driving.This XTD Stage 3 clutch kit is Great for Just Stock or Modified Application.All XTD Racing Clutch kit Requied 500Miles Break-in Period.
    « on: July 10, 2017, 01:57 PM »
