Author Topic: FS: CoolingMist CMGS With Autolearn Failsafe methanol injection kit  (Read 527 times)
September 12, 2017, 08:36 PM #0
tytanium Offline
  • Vehicle: 2017 Hyundai Tucson 1.6T SE
  • tytanium is a force to reckon with.tytanium is a force to reckon with.tytanium is a force to reckon with.tytanium is a force to reckon with.tytanium is a force to reckon with.tytanium is a force to reckon with.tytanium is a force to reckon with.tytanium is a force to reckon with.
Selling my CoolingMist CMGS With Autolearn Failsafe kit. The pump, tank, controller/gauge and failsafe box are from @Nirusan 's old ST so you know they were well taken care of. Since buying them I have not used them. The checkvalve, checkvalve fittings, tubing, nozzle holder and Devils Own D07 nozzle are all brand new never been used. Also will come with 100ft of 24 gauge wire and 100ft of 16 gauge wire. Online this kit goes for around $780 + shipping and comes with a solenoid instead of the upgraded checkvalve.
A little about the kit:
The Coolingmist Universal Water-Methanol Injection (WMI) kit with Autloearn failsafe is a system that was designed for the safety minded customer that wants an easy to install system with the most comprehensive failsafe on the market. Coolingmist spent many months developing a system that promises to change the way you think about complicated failsafes and hard to install systems. A traditional failsafe typically use flow sensors that often fail in the field and require the user to manually setup the safe operating range of the system. This causes many frustrating false positive triggers of the failsafe that forces users to shut off the failsafe altogether defeating its purpose.
The Coolingmist failsafe works by monitoring the pump duty cycle ('how hard the pump is working'), and this provides a reliable method of determining any potential problems with your WMI system without having to place a sensor in the water/methanol stream. In the event of a leak or burst line the WMI pump will require less power and the failsafe will recognize this thus triggering a fault code. If your nozzle becomes clogged the opposite will occur, the pump will need to work harder, and the failsafe will recognize the higher demands and trigger another fault code.
With the Coolingmist Universal Failsafe kit you are protected from low flow (25% duty cycle) to full system flow (100% duty cycle) and all points in between. In addition to that the Coolingmist system has an industry first AUTOLEARN feature. Install the system and it will learn your operation parameters automatically.
Looking to get $700 for everything. If you own a Speed3 or Speed6 I can include a Damond Motorsports throttle body spacer with injection ports for an extra $50.
Sale includes everything in photo
Last Edit: September 12, 2017, 09:10 PM by tytanium
former member of the #boostedhatchcrew
    September 22, 2017, 03:07 PM #1
    tytanium Offline
    BUMP Price drop to $650
      September 27, 2017, 12:33 PM #2
      tytanium Offline
      FIRST SNOWFALL SALE
      Dropping the price of the full kit to $500 until the first snowfall of the season then price will be adjusted back up! That is about $400 off the regular price for all of this.
      BUMP
        September 30, 2017, 10:31 PM #3
        tytanium Offline
        BUMP
          October 05, 2017, 10:46 PM #4
          tytanium Offline
          BUMP
            October 09, 2017, 01:47 PM #5
            tytanium Offline
            BUMP
              November 05, 2017, 04:42 PM #6
              tytanium Offline
              SOLD
                « Reply #6 on: November 05, 2017, 04:42 PM »
