Author Topic: Help! second gear troubles!  (Read 284 times)
November 09, 2017, 12:09 PM #0
PaulC Offline
  • Real Name: Paul Clarke
  • Vehicle: 2002 Subaru Legacy B4
  • PaulC has no influence.
Lately my car has been on and off with allowing Second gear to engage! Second gear has been engaging for about a month now and just today it stops again, only difference I've noticed is now if I try to engage the gear and the car is moving, the gear will grind. If anyone has any idea of what could possibly be going wrong, please let me know, a few mechanic shops I've gone to in the past has said it is probably my synchro.
    « on: November 09, 2017, 12:09 PM »
    November 09, 2017, 01:22 PM #1
    e7c Offline
    • e7c has no influence.
    this.
    can you shift into 2nd while car is not running?
      November 09, 2017, 01:28 PM #2
      PaulC Offline
      No I can't shift into second gear no matter what, it's not a grinding really I think vibrating is a better description.
        November 09, 2017, 04:35 PM #3
        Its most likely a synchro, you could take it apart and check it out, transmissions are complicated but doable if you take your time.
          November 09, 2017, 09:50 PM #4
          PaulC Offline
          Update;
          Second gear is working perfectly again, still think it's a synchro? Could it need an adjustment?
            November 10, 2017, 06:59 AM #5
            Have you tried changing transmission fluid?
            My guess is there was a small fragment stuck in your syncro that has magically popped out. Strain your old transmission fluid and see what golden nuggets you find.
              November 10, 2017, 10:08 AM #6
              PaulC Offline
              I changed my gear oil 2 months ago, should I take the transmission apart to go further in depth?
                November 10, 2017, 11:50 AM #7
                e7c Offline
                a lot of people recommending NOT changing gear oil in older/unknown history tx's, because it can dislodge bits and pieces that then go and jam things up
                  December 19, 2017, 07:29 AM #8
                  December 20, 2017, 05:31 PM #9
                  PaulC Offline
                  Update: started working perfectly November 11th, stopped going into second gear this afternoon.
                    « Reply #9 on: December 20, 2017, 05:31 PM »
