Author Topic: Dumb person Wheel fitting question  (Read 364 times)
November 22, 2017, 03:33 PM #0
Gotrek Offline
  • Gotrek has no influence.
Not a wheel person so a dumb question.
I needed some new wheels for my Jetta because my summer wheels leak.  Not being careful/picky I bought some 17" BBS RK's from kijiji (the guy might even be on here) because the add showed them on a same era golf so I figured they'd fit.
Getting them home I realize they are factory Subaru rims (right bolt pattern, wrong offset and bore diameter)
Even if I got spacers(10mm would be = to the factory offset) and longer conical nuts I can't get around the bore size without machining them right?   There is 1mm difference.
So I'm wondering what he did to get them on his Golf (or maybe it was just a picture and he never actually ran them)  Do they make spacers that have a smaller bore size or no centering flange at all?
Last Edit: November 24, 2017, 09:00 AM by Gotrek
    « on: November 22, 2017, 03:33 PM »
    November 22, 2017, 08:22 PM #1
    You can have custom spacers made that can have two different bore sizes. There may be a minimum thickness but you should be able to just google custom wheel spacers. I can look for the site when iím not on a phone
      November 23, 2017, 09:36 AM #2
      Gotrek Offline
      I'm going to guess that probably costs more then it's worth but I'll look into it thank you.  (More then it's worth since I'm not a show guy just wanted wheels that don't leak :)  )
        November 23, 2017, 09:37 AM #3
        Itís about $100 for a pair if i recall correctly.
          November 23, 2017, 09:38 AM #4
          Gotrek Offline
          Oh ok that's not horrible
            November 23, 2017, 10:51 PM #5
            • Reputation Power: 66
            What are the offsets and bores for each vehicle?
              November 24, 2017, 08:59 AM #6
              Gotrek Offline
              Car is 5x100, 57.1mm bore and Stock offset is +38 to +35
              Wheel is 5x100 56.1mm bore and +48 offset
              Figure a 10mm to 12mm spacer would be perfect
              Ha ha just noticed I wrote dump instead of Dumb in the subject
                November 24, 2017, 07:30 PM #7
                yeah Run a 10-15mm spacer just make sure its got a big enough bore and run longer wheel bolts. These should work depending on how much your hub sticks out
                https://www.ebay.com/itm/4x-10mm-Universal-Wheel-Spacer-Adaptor-5x100-5x114-3-4x100-5x120-5x112-4-5-STUD/331655588381?hash=item4d3836aa1d:g:v9cAAOSwyvBV9~KZ&vxp=mtr
                  December 02, 2017, 04:12 PM #8
                  I would recommend using hubcentric spacers all the time on cars with wheel bolts.
                    December 04, 2017, 10:10 AM #9
                    Gotrek Offline
                    So a quick update.  I bought some spacers (cheap ones I don't plan on using but wanted to do some tests)
                    They are hubcentric to 57.1mm
                    I threw them on the lathe and cut 1mm out of the hub centric ring that protrudes and they fit the wheels now   they still look strong enough to work so I'm probably going to do that.
                    Will be hub and wheel centric that way,.
                    Last Edit: December 04, 2017, 11:08 AM by Gotrek
                      « Reply #9 on: December 04, 2017, 10:10 AM »
