Author Topic: FS:AE92 p/out. Engine, coilovers, panasports. 5mge turbo w/ megasquirt - $600  (Read 1772 times)
September 12, 2012, 09:40 PM #0
gameface Offline
  • Vehicle: X W/ JZ
  • gameface has no influence.
Corolla stuff
4age
Crower 298/288 cams, stage 4 or whatever. $250
1sz shimless lifters $100
HKS valve springs $100
NST Adjustable cam gears $120
Anodized red pullies $200
Smallport 4age cylinder head, has 5 angle valve job, ported on flow bench, has some journal damage from prev owner, more details for interested parties. - $150
Bigport 4age cylinder head stock - $50
4age ARP headstuds $100
4age ARP main studs $70
4age ARP Rod bolts $50
7afe block complete with new bearings w/ sick clearances and smallport high compression pistons. 4age oil pump. $400. Perfect for a 7age project.
AE92 Specific
Parting out entire car including D2 coilovers, basically brand new and driven on less than 3000km. $800
Open to offers complete chassis w/ coilovers and wheels or with stock suspension and
wheels. Looking for $500 w/ stock suspension and stock wheels.
Will part out chassis.
Has no heater, radio, carpet, rear seats, other stuff.
Panasport C8 3 piece wheels, 13x8 +25 offset, 4x100 bolt pattern, 54mm hub bore miata/corolla size
Brand new 215/50r13 sumitomo HTR tires
$900
Complete turbo 5mge setup w/ megasquirt.
5mge engine with ARP headstuds, 440cc injectors, and 1.6mm metal headgasket, engine was rebuilt, reground valve seats, etc. Exhaust manifold is from a 7mgte using a ct26 with a stainless divorced wastegate downpipe, using 7mgte coil packs. Currently running at 18psi, cheap quick setup right here, has no problem putting other cars in their place.
$600 for complete setup w/ megasquirt and engine harness
$400 for engine setup alone and no megasquirt
$350 for megasquirt n52 diypnp, for another vehicle you can always buy a jumper board to use it on you car. 3 coil drivers installed in unit($30 value!).
Inquire via email
andrewrcatton@gmail.com
Last Edit: September 28, 2012, 06:37 PM by gameface
    September 12, 2012, 09:52 PM #1
    Jaareedd Offline
    • Real Name: Jared Halpin
    • Vehicle: '07 Franken-Subbie, '06 FXT, '90 Swift - IceRacer
    • Reputation Power: 12
    • Jaareedd has no influence.
    Hmmmm... Considering the full engine setup :)  What do you guys think: Not sell my car, drop this in there, and have a beast of a machine?  Thoughts please!
    "If you want to touch my hair, just ask..."
    "Dem Tekkers be good..."
      September 13, 2012, 07:37 AM #2
      Corey Offline
      • Vehicle: Formula Ford & Mazda 3
      • Corey has no influence.
      My old wheels!  I wondered where those ended up after Joe P. sold them.  These things are stupidly light, something like 7 or 8 lbs each.  They're actually 7.5" wide though, measured inside the bead area.
        September 13, 2012, 08:50 AM #3
        Mr.SI2010 Offline
        • Real Name: David Demchuk
        • Vehicle: 2010 Honda Civic SI, 2013 Ford F150 FX4
        • Mr.SI2010 has no influence.
        yes!!! yes!!!! yes!!!!! i demend this to happen!! and i will help obviously seeing as i like like 3 blocks away from you
        poppin' vtec like jonny tran
          September 13, 2012, 10:27 AM #4
          stuntman5656 Offline
          • Real Name: Misha
          • Vehicle: R33, 300ZX TT, Stagea, 190E AMG
          • stuntman5656 has no influence.
          DO IT!
            September 13, 2012, 12:26 PM #5
            This is a great idea, Jared.
              September 13, 2012, 06:20 PM #6
              gameface Offline
              • Vehicle: X W/ JZ
              yea thought i did too
              so either 7.5 or 8" wide panasports
              Ill have to help too if someone buys the complete cressida engine w/ megasquirt due to the customizing factor of the diypnp. Could be plug and play to a celica supra harness if I change the internal jumps to work with the toyota ignitor again.
              Also for sale
              96-2000 jzx100/mark 2 chaser automatic transmission(a34 i beleive) has a broken output shaft guard as pictured. Not looking for much, open to offers, goes to best offer. Either I sell it or it goes in with the next scrap run. JZ bellhousing.
              Last Edit: September 13, 2012, 06:32 PM by gameface
                September 13, 2012, 08:26 PM #7
                Crazy_ivan Offline
                • Vehicle: A2 AAZ Jetta, GF Impreza, BE5 Lego B4 RSK Blitzen
                • Crazy_ivan has no influence.
                I'll take the bell housing from the jzx tranny...
                  September 13, 2012, 10:05 PM #8
                  gameface Offline
                  • Vehicle: X W/ JZ
                  give me an offer! I'll be pulling it off the engine this weekend.
                    September 15, 2012, 05:40 PM #9
                    gameface Offline
                    • Vehicle: X W/ JZ
                    edit:disregard, all is good
                    Last Edit: September 16, 2012, 05:42 PM by gameface
                      September 23, 2012, 06:10 PM #10
                      gameface Offline
                      • Vehicle: X W/ JZ
                      BUMP, ae92 will be going to scrap soon if none wants the chassis!
