Author Topic: Trucks/ Tow rigs / 4x4 Thread  (Read 75025 times)
July 07, 2017, 03:23 PM #1450
  • Reputation Power: 72
Originally posted by #StreetFocus
They don't get bad to add wear until you max them out. Stock keys don't let you go far enough. Its when people buy aftermarket keys which are clocked different, and they crank those. Puts way beyond stock keys will let you. That's when the wear starts happening and all the issues come up.
Guess that depends on vehicles. GM trucks you can max out stocks at 3" and definitely **** your CV's up, I went with Procomp Keys cause I got them cheap and did the whole front end at the same time.
    « Reply #1450 on: July 07, 2017, 03:23 PM »
    July 07, 2017, 03:37 PM #1451
    • Reputation Power: 93
    Yep. Rangers don't let you go far enough with stock keys to **** things up.
    And if you can go far enough with stock GM ones to mess things up, why would you need aftermarket keys...? Just crank the stock ones a little bit...
      July 07, 2017, 09:22 PM #1452
      I mean, those are only a 7" wide wheel. Not ideal to run a 12.5 on something lower than 8. Gives a funky wear pattern.
      Oh dang. Really? People online said it's more dependant on the tire pressure. Also it can act like a bead lock because of the pressure. So the max would be 33x10.50? I guess there's no real point to lift then, because we can fit those stock. I wanted the lift and 12.50s.
        July 29, 2017, 03:07 PM #1453
        Finally ordered some new heads/marker lights. I went ahead and siliconed them extra to make sure they wont fog
          July 29, 2017, 07:25 PM #1454
          Those look really sweet
            July 31, 2017, 08:29 AM #1455
            x2 those look real good.
              July 31, 2017, 07:40 PM #1456
              yeah not bad for like $115cad lol
                August 01, 2017, 08:26 AM #1457
                Ebay Special?
                  August 01, 2017, 09:21 PM #1458
                  Originally posted by jordisonjr
                  Ebay Special?
                  yessir, Couple buddys run them and have been great. Just run a bead of silicone around the edges where the lense meets the housing and theyre good to go.
                  Washed it earlier tonight. I need to spray my grill black and lower valence black too. Theres some white on my grill from cleaning the paint off the chrome grill bar and its pissing me off
                    August 03, 2017, 10:37 AM #1459
                    Such a clean truck. Looks great man. Always loved that body style.
                      August 03, 2017, 02:37 PM #1460
                      Had Costco tell me that if I want warranty on my tires I can bring the rims in and they can mount them on the rims, then they'll have warranty . Otherwise if they mount it on my truck itself they'll know what vehicle it's going on so they wouldn't warranty them. Pretty sweet . I didn't think they were going to warranty at all cause they're oversized
                        August 03, 2017, 03:04 PM #1461
                        That's odd. Shouldn't matter what vehicle they're going on.
                          August 03, 2017, 03:10 PM #1462
                          Well I was told before that Costco will only put the OEM size on , and that's it. So this was good news for me at least. They said it's their only way around the policy. Because according to Costco if you're putting larger tires on , you require a lift to run them safely. Or if you go smaller , your load rating must be the same. they won't install a lesser rated tire than OEM. But they said obviously most trucks can run larger tires, so bring the rims only in , and then they'll warranty them and put install rim only. Rather than install vehicle ________
                            August 03, 2017, 03:11 PM #1463
                            The joys of dealing with a large company. They have rules like that lol.
                              August 03, 2017, 03:28 PM #1464
                              Yeah, but the tires are a good price.
                              33x10.50x15 BFG KM2 for $1100 . Plus the other stuff, would come to just under $1200 I think.
                                August 08, 2017, 07:19 PM #1465
                                Do you have cranked t bars?
                                I'm going to be cranking mine in a couple days.
                                How much do I crank? Do I crank them all the way up? You said before that our trucks won't let us max them out anyways so if I go all the way up that's actually not the full amount right?
                                People also say that in a couple days they settle down. So if they're going to sink a bit too
                                  August 08, 2017, 07:22 PM #1466
                                  yes mine are cranked. crank them till its level. It wont take a few days. crank them, drive around the block, and see where it sits.
                                  park somewhere level, measure the back, top of tire to bottom of fender opening, in the middle. do the same up front and see how far you have to go. write these numbers down.
                                  start with two full turns of the bolt (tightening)  drive around the block and see how much higher it sits.
                                  make sure you're tightening the bolts with the front tires off the ground.
                                    August 08, 2017, 07:25 PM #1467
                                    Well I have the AAL to put in as well. So level really isn't the issue, just a safe amount of lift. I don't know if that same statement applies.
                                    The tires will be off the ground. It'll be on a lift actually.
                                    I'm changing both front CV axels. Front ball joints. Tie rods. Rear drums and pads. Installing the AAL and t bar crank.
                                    I bought all the best parts I could. Lifetime warranty on ball joints and tie rods so if the t bar crank blows then I'll get new ones . Hehe
                                    I even asked about that.
                                      August 08, 2017, 07:27 PM #1468
                                      yeah Id do all the other stuff, drive around the block then measure, crank two turns and see where it gets you. You shouldnt have to max them out at all, I'm still not maxxed out on mine.
                                        August 08, 2017, 07:28 PM #1469
                                        So two turns is 2-2.5 lift? Sweet
                                          August 08, 2017, 07:32 PM #1470
                                          well, probably not, I can't quite remember how many I did. but if you start with two, have your measurement from before, then measure after it will give you how much lift you gained, then you can figure out how many more turns you need to do.
                                          example with made up numbers:
                                          Rear after AAL: 15"
                                          Front before crank: 13"
                                          Front after 2 turns: 14"
                                          this tells you 2 turns gains you an inch, thus you need 2 more turns to be level with the AAL.
                                          these numbers are just made up as an example, but hopefully it makes sense.
                                          suggestion, mark the bolt so you know exactly how many turns you've done. and do the same amount on both sides.
                                            August 08, 2017, 07:35 PM #1471
                                            Rear after AAL: 15"
                                            You can be level with an AAL? Wow. Didn't know that.
                                            But hey that's smart! I'll definitely do that. Then I'll just keep adjusting it accordingly
                                              August 08, 2017, 07:36 PM #1472
                                              I mean I dont see why not. its not a 5" AAL is it lol
                                                August 08, 2017, 07:37 PM #1473
                                                I just know what I read on the forums lol . That's why I asked you since you legit have the same truck
                                                  August 08, 2017, 08:23 PM #1474
                                                    « Reply #1474 on: August 08, 2017, 08:23 PM »
