Author Topic: Shaun's Two Wheeled Project - 1976 Yamaha XS500  (Read 9610 times)
January 24, 2013, 07:33 PM #75
Originally posted by Murderjetz
The acid in our stomachs is actually more acidic than vinegar. So we should be fine.
Edit: on the subject though, is there a reason why you shouldn't just fill up the whole tank with vinegar on the first go?
I did that only to demonstrate the effects of vinegar. Ive since filled it all the way and sealed the lid.
    « Reply #75 on: January 24, 2013, 07:33 PM »
    January 24, 2013, 08:12 PM #76
    Murderjetz Offline
    • Real Name: Eric St-Onge
    • Vehicle: I ain't got none
    • Murderjetz has no influence.
    I suspected as much.
      January 24, 2013, 11:10 PM #77
      vinegar is great... i used electrolytic rust removal... it seems crazy, but works amazing, and doesn't remove any materials other then rust.  good instructions here:
      Battery and Washing Soda/Electrolysis
      Electrolysis is a technique for returning surface rust to iron. The process actually alters the tank wall on the molecular level removing the oxygen that has oxidized (rusted) the tank. This method has advantages over old standbys like vinegar, Coke, muriatic acid, naval jelly, wire brushing, sand blasting, etc. because those methods all remove material to get rid of rust. These other methods also remove un-rusted material. The electrolytic method removes only the oxygen from the oxidized metal by returning surface rust to metallic iron, rust scale is loosened and can be easily removed. Un-rusted metal is not affected in any way.
      What do you need to make this work? Not much, really:
       Your rusted gas tank.
       A battery charger or other source of 12V DC power.
       Wires or cables to connect the electrodes together, heavier gauge better, less heat. make sure it insulated.
       Sacrificial electrodes - iron re-bar works great, stainless steel is very bad (and the result is illegal and dangerous). Go to your hardware store get some non coated steel
       Arm & Hammer LAUNDRY Soda, also known as washing soda.
       Some chains or steel wire to suspend the part in the solution - copper wire is bad and messy.
       Water
      The basics are pretty simple.
      Look in your tank. Get familiar with the inside of your tank you are going to need to fit the Sacrificial anodes in there and have them not touch the edge, because it will cause you to ground out and not work.
      Mix 1 Tablespoon of Washing Soda with every gallon of water to create an Electrolyte solution. (Don't go overboard with the washing soda people. It won't help.)
      Cut your sacrificial anodes to lengths that will fit in the tank. I drilled holes at the top to attach a wire. Now use electrical tape to tape the wired end and the other end thickly so there is no possible way you can ground out on the edge. You can use more then one at a time.
      Wire all of the electrodes together so they are, electrically speaking, one big electrode. Make sure all connections are on clean metal and sufficiently tight to work.
      Suspend your part in the solution using the wire/chains so it is not touching the bottom and is not touching any electrodes.
      Attach the battery charger NEGATIVE lead to the tank and the POSITIVE lead to the electrodes. Do not get this backwards! If you do, you'll use metal from your part to de-rust your electrodes instead of the other way around -the positive electrodes are sacrificial and will erode over time. That's how the water becomes iron-rich. THE POLARITY IS CRUCIAL!! The iron or stainless electrode is connected to the positive (red) terminal. The object being cleaned, to the negative(black). Submerge the object, making sure you have good contact, which can be difficult with heavily rusted objects. Get it backwards and your object will be relentlessly eaten away! Make connections on a part of your electrode that protrudes out of the solution, or your clamps will erode rapidly.
      Double check everything to be sure the right things are touching, the wrong things are not touching, and the cables are hooked up correctly.
      Turn on the power - plug in the charger and turn it on.
      Within seconds you should see a large volume of tiny bubbles in the solution - these bubbles are oxygen and hydrogen (very flammable!). The rust and gunk will bubble up to the top and form a gunky layer there. More gunk will form on the electrodes - after some amount of use, they will need to be cleaned and/or replaced - the electrodes give up metal over time. That's why re-bar is such a nice choice - it's cheap and easy to get in pre-cut lengths.
      The process is self-halting - when there is no more rust to remove, the reaction stops. This is handy because you don't have to monitor it, and because you can do large parts where they are not totally submersed at one time (aka, by rotating them and doing half at a time) without worrying about "lines" in the final part.
      Once you are done, the tank should immediately be final cleaned and painted - the tank is very susceptible to surface rust after being removed from the solution. There will be a fine layer of black on the tank that can be easily removed, and once it is removed, the tank can be primed/painted as needed.
      Safety Precautions
       You're playing with serious stuff here, so stay safe. It's not rocket surgery, but if you're new to this, you might not know all of this - so read up before you do any of this.
       This process produces highly flammable and explosive hydrogen gas, so do it outside, or in some other well ventilated area. Hydrogen is lighter than air (like natural gas), so it will collect near the ceiling - not sink to the floor like some other flammable vapors will (like propane and gasoline). If you have open flames near this (Hint: gas appliances like water heaters and furnaces have pilot lights!) you will most likely severely injure or kill yourself (and others near you)
       Assuming you used re-bar and steel wire/chain like you were told to, the waste water resulting from this is iron-rich - it's perfectly safe to pour it out onto the grass and your lawn will love it. Beware of ornamental shrubs that don't like iron-rich soil though, unless you like making your wife mad at you.
       Make sure the battery charger (or whatever source of power you use) stays dry. All of the usual cautions about any electrical device in a wet environment apply here.
       The solution is electrically "live" - it is a conductor in this system. Turn off the power before making adjustments or sticking your hands into the solution. You can get a mild shock if you stick your hands into the water with the power on.
       The solution is fairly alkaline and will irritate your skin and eyes. Use gloves and eye protection. Immediately wash off any part of your body the solution comes into contact with with plenty of fresh water.
       Don't use stainless steel for the electrodes. The results are toxic and illegal to dump out.
       Don't use copper for the electrodes and anything else in the water - the results are messy.
      If you are unsure of any of this or unsure about your safety - STOP! Get help before you do something stupid. Use common sense, be smart about what you're doing, and stay safe.
      pics on instructibles
      http://www.instructables.com/id/Electrolytic-Rust-Removal-From-A-Motorcycle-Gas-Ta/
        January 28, 2013, 09:41 PM #78
        Managed to beat off the rear caliper on this thing tonight, since it was decently nice out. Rear wheel now turns as well, so I pushed it into a different spot and put it on the side stand. Looks way cooler than the center stand, lol.
        Can't do anything but wait for warmer weather now. No point in ordering anything else until we see if it runs.
          November 19, 2014, 01:52 PM #79
          Matthew Offline
          • Real Name: Matt
          • Vehicle: '92 EH3, '05 Ranger, '00 Silverado, '00 EX250
          • Matthew is a force to reckon with.Matthew is a force to reckon with.Matthew is a force to reckon with.Matthew is a force to reckon with.Matthew is a force to reckon with.Matthew is a force to reckon with.Matthew is a force to reckon with.Matthew is a force to reckon with.
          Any recent updates available? Didn't know shaun had a bike!
          EH3 in the making.
          [May 26 14:52:31] ACiFiC:matt u r so cute i wish u were under my covers :3 :3 :3 :3 xoxo
          Been someones avatar count: 7
            November 19, 2014, 02:08 PM #80
            Nirusan Offline
            • Reputation Power: 217
            Wow, @Shaun I didn't see this in your garage when i was over. Where is it, in your basement?
              « Reply #80 on: November 19, 2014, 02:08 PM »
